Question about 473L TX 3-Button Replacement TX Remote
I NEED TO KNOW HOW TO PROGRAM IT
I NEED TO KNOW HOW TO PROGRAM THE AVITAL 473L REMOTE?
  • 87 Answers
It should be
  1. open door
  2. turn ignition on
  3. press and hold valet switch until it beeps once let go
  4. press once more and press lock on fob
  5. let go of buttons
  6. turn off ignition
Posted on Jun 03, 2009
Need instruction for programing avital 473L
Turn the ignition on, press and release the valet switch then press and hold the valet switch. Press the lock button on the remote.
Feb 26, 2014 | Avital 4111 Remote Start System -
Have no idea what this is
Depending on the "brain box" used, this fob can lock/unlock doors, unlock trunk, and remotely start the car. the * button is used for the remote start....OR can be used to arm/disarm a security system. Only way to tell is to try the buttons and see.
Also, some are wired so that first you must hit the door lock button, then the remote start * button. Also may need to push * button twice to get the remote start to engage.
Somewhere - likely under the dash near steering column or ignition switch is the brain box. Give us the model numbers off that box and I can tell you a lot more about what it does.
Dec 13, 2013 | 473L TX 3-Button Replacement TX Remote
Avital 473L TX will start and keep the starter engaged
Sounds like the ignition or accessory output from the remote starter is connected to the starter wire. Has it always done this?
Mar 06, 2013 | Avital Vehicle Parts & Accessories
Avital 473L bought for a 99 Nissan maximal. How to program? Instructions say to press valet button? Don't have one that I know of. The Nissan instructions, put key in and out 6 times, hazards flash,...
Some of those cars did not have that option on them. You must frist open the drivers door. then press the lock button on the main switch oin the door. Then close the door and slowly insert the key 6 times within 10 seconds but do not go to fast and when the flashers blink then turn the key to the ACC potion and press one of the buttons on the remote.
May 28, 2011 | 1999 Nissan Maxima
How to reprogram a473 L avital remota
Avital FCC ID: EZSDEL1474S 473L how to program
Dec 14, 2010 | 473L 3-Button Mini Remote
Alarm too sensitive keeps draining battery unable too diagnose key phob settings
is the battery draining because the alarm goes off continually? if you can find the brain module, there is an adjustment knob for the shock sensor on the side opposite the main wiring harness. counter clockwise will decrease sensitivity.
Feb 21, 2010 | 473L 3-Button Mini Remote
Will not start car the battery is good it lights up but will not start the car
does your vehicle require a bypass module for the anti theft? also double check your connections for the power,hood kill switch and if equipped transmission park wire.
Dec 28, 2009 | 473L TX 3-Button Replacement TX Remote
2000 dodge ram. Instrument cluster not functioning. all gauges dead, tach, speedo, oil, etc. all dummy lights on. hi/lo beam ind. ok. blinkers ok. odometer and trip. blank. dealer says remote starter...
The alarm should not have anything to do with that, but the best way to find that out would be to have the installer hook the factory ignithion and starter wires back up and see if it fixes the problem
Sep 23, 2009 | 473L 3-Button Mini Remote
Truck starts without touching remote
I would get your manuel and take a look at the section on the automatic start, sounds to me that you may have accidently progrmmed it to start every so often. this is a useful feature during the winter months so that your car always stays warm, but a headache when you dont want to use it. so just check out the program instructions for your system.
Mar 08, 2009 | 473L 3-Button Mini Remote
473L TX 3-Button Replacement TX Remote Logo
2,715 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Colin Stickland
Colin Stickland
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
