Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Non-functional I purchased the dishwasher to replace a very old one. I plumbed and wired it exactly according to the installation instructions. When I started the machine to test it all i get is a blinking "wash cycle" light. There is no water moving, no pump noie, nothing. I pulled it back out and double checked everything and it is all in order. Any suggestions?
    Genius:
  • 1,003 Answers
CHECK FOR A FAULTY WATER INLET SOLENOID
Posted on Jan 18, 2008
My dishwasher is a year old and the buttons don't want to work right if I push on the cycle before it will come on but wont run that cycle what should I look for
your computewr panel is shot...i purchased this sAME MODEL AND LUCKILY i PURCHASED A 4 YR EXTENDED WARRANTY ON IT..BECAUSE IT HAS BEEN NON FUNCTIONING MORE THAN FUNCTIONING..:(..WONT BUY THIS MODEL AGAIN.
Oct 08, 2014 | Maytag Dishwashers
I have a Whirlpool ADP9000ix diswasher that will not power the front display/touch panel. Therefore cannot turn the dishwasher on. I have checked the circuit control panel. And power is getting to it....
If your Whirlpools over there are like the older ones here in the U.S., you may find that there is a thermal fuse mounted just above the circuit board. If there is one, turn off the power to the unit, pull off the 2 wires connected to it and check it for continuity with a multimeter. If that fuse is blown, nothing works as it controls all power to the unit. Replacement fuse kits (at least here in the U.S.) are readily available on ebay for a fraction of the price that an appliance parts store would want. By looking on ebay for "Whirlpool dishwasher fuse" you can see what the fuse assembly looks like, and if identical to yours, purchase one. If you do buy one, follow the installation instructions exactly by using the supplied wires on the new fuse and the screw terminal block to make the connections. If you don't use the new wiring and connection block and simply plug the new fuse to the old connectors, it will simply blow again in a short time.
Jun 07, 2014 | Dishwashers
Bell & gossett series 100 squeaks when it stops
Sounds like it is not getting oil. The bearing oil fill cover can be removed by lifting outer plate with a screwdriver. Ck that the wicks are covered with oil , if not oil them. Put 3 drops in motor oil fill tubes. If still squealing, replace.
Apr 27, 2014 | Bell & Gossett 106189 1/12 HP Series 100...
Hot water comes before cold water for Kohler Mixer Pressure Kit
If this is a tub/ shower valve, you installed the cart. upside down. Reversing it should solve the problem. You might have put it in according to instructions but the hot and cold might have been reversed when the valve was plumbed in.
May 03, 2012 | Kohler Plumbing
Hi this did not work. The pots and pans the normal and the power scour are still flashing all the time??? Is there something else I can do.
Ok the lights flash all continually because the control board is defective (as opposed to another component) the part number for the control board is 8564546 it could be purchased from your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
To replace the control board,open the door and remove the T10 torx headed screws and seperate the inner/outer door,remove the cover from control board ,remove old board with the wires attached...install new board and install wires on new board the plugs are keyed and will only fit on the correct terminals, a tip is to remove on and install it on new board so you doing only 1 plug at a time and its easy to tell where it goes since its the exact same place it just off of old board.
BEFORE ATTEMPTING THIS TURNOFF POWER TO THE DISHWASHER AT THE CURCUIT BREAKER
GENE
Sep 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I need details on how to install Maytag built in dishwasher
Hello Ted, Without the exact model number, it is difficult to provide the correct installation instructions for your specific Maytag dishwasher.
I can provide you with a link to the Maytag site where you can enter in your model number and download an owners manual and installation instructions/guide that will provide you with the step-by-step needed to properly install your dishwasher.
http://www.maytag.com/support/manuals_literature.jsp
The installation instructions will provide the proper wiring, water supply inlet plumbing and connection of the water discharge line, as well as all of the dimensions needed for clearances for the countertop and cabinets.
If you're trying to install an older dishwasher, you can also give them a call at 1-800-344-1274 and have your complete model number available, so they can provide you the correct manuals and instructions.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | Dishwashers
Particle residue on glasses in top basket for glasses at the corners
The oldest dishwasher I have replaced was a Kithcenaid installed in 1953. It was a 24" built in with a smaller door, a handle looked like it was for a safe, and it had an s-trap underneath. The 90 year old customer said it did the same thing. My advice is to run a dishwasher cleaner through a hot cycle according to manufacturers directions. Check the holes in the spray arms carefully for any debris. Our service guys advise not to use gel or liquid type soap as it leaves a tiny residue after each load which will eventually clog your internal plumbing. Always use the least amount of soap you can get away with and POWDER is prefered.
Apr 24, 2009 | Dishwashers
Water does not turn on. It is ok in sink area...it runs out.
You have 1 of 2 problems on this 35 year old DW...
1. The water solenoid is out.....need replacing.
2. The timer is going bad (has gone bad)...needs replacing....what happens over the years...with timers is that the teeth wear out , break,, wear down, and will not engage specific functions of the dishwasher as in activating the water solenoid. The odds are these parts will be cheap...but having been in the industry for 35 years...I have found that often when you install a new part in an old unit ....it places a load on all the old parts...that they are not used to...and other parts start to fail...you will probably be better off buying a new one....hopefully (and probably) the last you will ever need since you only use it once a week.
I hope this helped thanks ...the Fang.
Mar 27, 2009 | GE Dishwashers
How do can I change spark plugs?
hi hillardgarne,
1. Purchase a wrench for spark plugs
2. pull the tension wires from engine.
3. insert the wrench until wrench gets a grip of spark plug
4. turn until plugs are completely loose
5. do this for the rest of the plugs
6. replace old with new plugs.
7. do the same thing but now, you tighten the plug (like screws)
8. return the tension wires
important:
* remember to know exactly the correct location of each tension wires, return to it's exact location (length of wires will help)
* as you take out old plugs, cover the hole where plugs are placed for it not to get dirty.
* in replacing, make sure that plugs are tightly inserted (not to tight though)
hope it helps.
Jul 27, 2008 | 2004 Honda Accord
Trying to replace broken upper rack adjustment arm . . .
first off check to see if there is an endcap either the front or back of the track. if so remove the cap. check for end mount screws. if no screws the endcap opens up the route for popping the plastic cover off and exposing the screws.. see diagram(may not be exact model but it gives you an idea)
May 12, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
46 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
