Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Underneath the crispers is full of water sometimes even freezes I also have water pooling in bottom of fridge, watched a DYI video that said clean out drain in back of fridge but can't see a drain in mine
  • jbrw138 May 29, 2009
    I took all everything out and only found a covered eraser sized hole that I don't see how anything could get down--tried taking the small cap off but it is attached and won't come all the way out. Now what
  • jbrw138 May 30, 2009
    whirlpool
    model # ET8CHMXKQ0 4
    President:
  • 1,136 Answers
Hi, I can help you through this. Please get me a model # so I can look this up and advise you further. The problem sounds like a plugged drain. We just need to locate it.
Thanks
Vic
Posted on May 30, 2009
  • Victor
    Victor May 30, 2009
    Have you checked the back outside wall and see if the drain hose is fastened there?
    You will need to remove the rear panel in the freezer section. The drain hole is located below the evaporator coils. If there is ice in the drain, use a hair dryer and tmelt it. Make sure all the ice is gone. Try and flush the drain hole out with hot water once the ice is gone.
    Now, if there is no ice ib the drain, you will need to remove the air duct inside the fresh food section and see if you can locate the drain hole.
    I hope this helps.
    Please let me know
    Vic
See solution posted may 30th by Maytag317. Whirlpool ET8CHMXKQ05
Three screws to remove the ice maker. Disconnect the electric connector. Push it through the hole before taking off the rear panel in back of the freezer compartment. There's a green ground wire that stays behind the panel that will come off if you don't. 2 screws to remove the rear panel. Look at all that ice! The drain hole is on the right side. You'll hear water hit the drip pan when it's cleaned out. Piece o' cake!
Posted on Feb 04, 2010
    Problem Solver:
  • 5 Answers
Look in the fridge compartment at the rear and you will see a hole usually above the glass shelf its more than likely tu be blocked with food, just insert a flexible wire of wire coathanger to clen it then pour hot water down the hole to clear any residue
Posted on May 29, 2009
Samsung refrigerator
The moisture has to be getting inside to pool. Check your door seals or leaving the doors open to long.
Aug 14, 2016 | Samsung RF265AA Bottom Freezer French Door...
My Whirlpool refrigerator, model GT22DMXGW00, leaks. Water is accumulating in the bottom-underneath the right hand side crisper. It then drains out onto the kitchen floor. Some is freezing too. It is...
check the ice door flap where ice drops into a glass.sometimes the flap doesn't close completely and allows heat to enter threw the flap.this causes frost to build and melt thus you have water you can't explain. hope this helps.
Dec 11, 2014 | Whirlpool Refrigerators
Condensation water build up inside refrigerator
The tray underneath your fridge is probably clogged, and overflowing. There is an evap tray underneath, and if it does not get adequate airflow, it will overflow, and leak out.
Clean the bottom front vents, and underneath the fridge to ensure adequate airflow.
Mar 31, 2014 | Sub-Zero Refrigerators
My fridge is leaking water down the back into crisper
The defrost drain is stoppped up. The easiest way to solve this is with a compressed air tank. At the back of the ref. at the bottom you will see a hose leading into a drain pan.Blow the air through the hose and it will unstop the drain.Hope this helps !
Sep 29, 2017 | Whirlpool GT1SHTXM Top Freezer...
Danby Designer All Fridge (no freezer) Model # DFF1776WE Water pooling underneath crisper drawers. Very full every couple of days. Then it leaks out the bottom door hinge. Not sure if drainholes are the...
Yes it is located in the refrigerator on the bottom in the back. I assume you know how to clear it, Hot water plus towel to soak up excess water should take several tries of very hot water until it clears. Good luck
May 26, 2011 | Danby Designer DAR1102W Refrigerator
Our refrigerator is getting a pool of water underneath the crisper bins. We do not have the ice maker hooked up. Water drips down and freezes into ice on the bottom of the refrigerator inside. I am not...
water is coming from the defrost cycle and is not making it to the drain pan on the bottom. try cleaning the coils and if you can locate the drain that goes to the pan and blow in it this will clear it out. thank you.
Apr 25, 2011 | Kenmore 64802 Top Freezer Refrigerator
Water comes off somewhere in the bottom of my fridge. what could have caused it?
When your refrig goes into defrost , the water runs down the back of the refrig ( inside ) and out to the drip pan thru a drain hole under the crispers . If water is under the crispers , remove the crispers and you should see a " cap " covering the drain hole . Sometimes crud will cover the slots where the water is supposed to drain , causing water to pool under the crispers . Just remove this cap , clean , and reinstall .
Mar 20, 2011 | Magic Chef Refrigerators
Bottom of fridge collects water
Hello there:
I have written a few steps for you to follow and try ok?
  1. Manufacturers have different ways to dispose of the water created during automatic defrost cycles. The most common design routes the water down a rubber tube on the back of the fridge to a tray beneath. This tube often gets plugged with breadcrumbs, peas etc. and can generally easily be removed and cleaned.
  2. Make sure the end of the hose is sitting in the defrost tray.
  3. If your hose was not plugged and you have found water running down the back wall inside the fridge or a pool under the bottom crisper has formed. Check if there is a small funnel located on the back wall near the top inside the fridge. It can also get plugged; you can use a small wire and work it in and out of the hole.
  4. Some designs do run the water down the back wall and have a drain hole under the crisper, make sure it is not plugged.
I hope that this has been verry helpfull for you
best regards michael
Nov 06, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
610 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
