Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE 5 electric dryer, no power
I have a Kenmore HE5 electric dryer that is 5 years old. It has worked well but now it is completly dead. I have power to the unit (to where the power cord attaches to the back of the dryer). There are no lights or failure codes it appears as though it is not plugged in but as I said there is power to the back of the unit. Is there anything I can do to isolate or repair the problem??
Thanks in advance for anyhelp.
Jim
  • 5,911 Answers
With the dryer unplugged, remove the lower panel under the door. To remove, you will need to loosen the screws under the bottom fronyt edge. With the screws removed, the panel drops down a little, then comes off. Check the Thermal Fuse located on the blower fan housing directly under the drum. This is a white or gray plastic component with 2 wires. Take a resistance reading across the fuse. You should get a reading of 0 ohms (or very low resistance). If the fuse is bad, your problem may be solved. A blown thermal fuse will kill the entire dryer. In addition, if the thermal fuse is bad, it usually blows for a reason. Make sure your dryer ventilation is clean and clog free. A dryer that is clogged will overheat to the point fo failure which causes internal component failure. Not to mention, this is a fire hazard. Please check and let me know. If the fuse is still good, the problem may be with your main control board. The fuse is the more common and least expensive option to try first. I hope this helps you. Let me know what you find...
Posted on May 29, 2009
Replace the heating element
here are some results I found on youtube one might help you see how it's done
http://www.youtube.com/results?search_query=Kenmore+HE5+Electric+Dryer+Replace+the+heating+element
Nov 24, 2014 | Kenmore HE5 Electric Dryer
How do you replace the door switch? i have he5 kenmore elite
last on the list:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 02, 2010 | Kenmore HE5 Electric Dryer
I have a kenmore he5 electric dryer. We have
I am having the same problem. I think there is a design problem. They have tried to fix mine 3 times (replacing the dryer with a new one on the first try!) My dryer is only years old. I'm so disappointed with Sears and Kenmore.
May 23, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 inoperable and F70 error code.
HI, this error code represent a major control issue within the main control. simply replacing the main control will fix this issue. the logic chips are damaged.
May 30, 2009 | Kenmore Elite HE4 Electric Dryer
Decreasing Timed Cycle Setting in a HE5 electric dryer
I think you need to cancel and restart to change the time to less.
Jan 14, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore He5 dryer, a service code f22
just remember error codes are always going to be stored on every machine ,, shoukd not have a problem ,, but does it work
Nov 29, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
451 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
