Computer display do not show display
  • 1 more comment
  • ayman010 Jan 19, 2008
    when i start the computer i'll hear the fan sound turning only without any displaying on the screen plz help
  • casey kent Dec 02, 2008
    same when i boot the computer it says window xp starting up then the moniter goes to sleep
    i think it might be XP in general because when i hook my moniter up to my laptop (XP) it does the same thing
I have the same problem.. makes really loud noise and nothing appears on the screen
Posted on Mar 01, 2008
  • 21 Answers
Could you give us more details, please? Does the PC starts and what happening after you press the power button? Can you hear the fan works? When the problem started and what was changed before the problem occoured? Have you checked the conection between PC and the monitor itself?
Posted on Oct 22, 2007
SOURCE:
I am trying to connect a computer to my tv, this model, but when I do I get the sound from the computer but only the screen background from the computer. Not the streaming event.
OK what that sounds like is that the computer is displaying dual screens - is this a notebook computer with its own screen? If so you may see the live action on the other screen and by default the 2nd screen will show the desktop wallpaper. If you want you could drag the windows over to the other screen simply by clicking with your mouse and dragging the content over. If you only want the TV then you need to go into the display settings and change the TV to be your primary monitor.
Right click on your desktop and select screen resolution, then from the display menu choose your TV, then from multiple displays menu choose - show Desktop only on 1 - and your TV should then be the primary display.
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 02, 2017 | The Computers & Internet
Display are not showing cleanless
Try connecting an external monitor to the computer and see if it displays better. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your video card inside the computer is good, but your lcd screen is bad. If the Borrowed monitor displays the same way with problems, then your video card inside the computer is bad.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
Jun 09, 2012 | Lenovo G555 Laptop
Reasons of y signals not going to the monitor
Is the monitor showing a blank screen or is it showing the message NO SIGNAL??
If you have a Desktop try the steps below:
If it is showing the message NO SIGNAL, then the video card in the computer is bad, because when the monitor is bad, it will show nothing at all. To isolate the problem plug another monitor on the computer and see if it displays. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original Monitor is bad. If the Borrowed monitor displays the same as your original, then the video card in the computer is bad.
If it is a laptop try the steps below:
May 24, 2012 | Intel Motherboard
6349 cannot display
Try another monitor on the desktop. You problem is either the monitor or the video card. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the desktop. If the borrowed monitor shows the display and works ok, then your original monitor is bad. If the borrowed monitor does not show the display just like your original monitor did not show a display, then the Video Card in the computer is bad.
May 05, 2012 | Computers & Internet
MY COMPUTER NOT SHOWING THE disply..... i checked ram and cables........but not showing the display on crt monitor............. the PROBLEM is happening from the mseb cuts of the lite... and after all...
First of all go to the Mother Board and remove the battery on that board and wait 10sec's and replace and start the computer it may help to get out from the problem of displaying.
Thank you
Keerthyinfo
Aug 31, 2011 | Intel D946GZIS Motherboard
My system is not showing display but monitor,cpu all are working but it is not showing display
hi pavantheloca
I think the display settings in your computer system prevents the monitor displays.
try to press f8 when you start the computer and then choose to enable vga mode
regards
Jan 17, 2011 | Intel D946GZIS Motherboard
My LCD shows display in safe mode but no display in Normal boot.!
Its the problem with your display resolution. In Safe mode set it to 1280x800 and restart..
Apr 19, 2009 | Samsung SyncMaster 152 B 15" LCD Monitor
Nokia 6233 mobile switch on but then hangup
Dear
When u connect to computer by data cable it shows three option, select data transfer option from it to transfer file like videos,music etc.
while in this process phone will not displays menu option it shows data transfering
if u want to display menu option u have to deattach usb data connection
Thanks
Feb 20, 2009 | Nokia 6233 Cellular Phone
LCD Computer monitor
This problem may occur due to wrong driver of display card or wrong display settings.
Solution:
1- Start you computer in safe mode.
2- Remove display card driver.
3- Restart you computer.
4- Install display card driver (if it does not pick automatically).
Now it should show default settings. I hope it would solve your problem.
Aug 17, 2008 | Gateway FPD2275W LCD Monitor
DSC-N1 display different when downloading photos
You say 'When I attempted to download photos to my computer, it doesn't show the display USB Connecting or the Cancel button. All it shows is a big dot in the middle with four directional buttons.' Not sure where this shows. Does the camera still take picture and upload them OK? Come back
Apr 16, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Open Questions:
LYCOS password recovery phone number +1800 365 4805 KO RAJAN Get LYCOS 1800 365 4805 password recovery phone number easy steps to forgot or change LYCOS password recovery via phone number #1-************ just follow some steps to recover LYCOS password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure LYCOS with LYCOS or other microsoft account services. Their are many certified officer to suggest people that how to change or recovery LYCOS voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to recovery LYCOS password to recovery or change it quickly, if you have any of them so contact to get well LYCOS support form us. LYCOS password recovery not working LYCOS password recovery phone number LYCOS password recovery contact number LYCOS password recovery help LYCOS password RECOVERY support LYCOS password recovery wont work LYCOS password RECOVERY wont work LYCOS password recovery link LYCOS password RECOVERY issues LYCOS password recovery usa LYCOS password RECOVERY customer service. LYCOS email account password RECOVERY ' free LYCOS email password recovery ' cannot RECOVERY LYCOS email password ' LYCOS email password recovery ' LYCOS email password recovery download ' LYCOS email password recovery software ' free LYCOS email password recovery. LYCOS email password change, LYCOS email hacked password changed, LYCOS email hacked can't change password, change LYCOS email password on iphone, change LYCOS email password on ipad, change LYCOS email password on android, LYCOS email account hacked can't change password, how to change LYCOS email password on droid, LYCOS email password problems, LYCOS email password not working, LYCOS email account password recovery. LYCOS password recovery phone number.
Apr 26, 2019 | Microsoft Computers & Internet
RACKSPACE password recovery phone number +1800 365 4805 KO RAJAN Get RACKSPACE 1800 365 4805 password recovery phone number easy steps to forgot or change RACKSPACE password recovery via phone number #1-************ just follow some steps to recover RACKSPACE password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure RACKSPACE with RACKSPACE or other microsoft account services. Their are many certified officer to suggest people that how to change or recovery RACKSPACE voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to recovery RACKSPACE password to recovery or change it quickly, if you have any of them so contact to get well RACKSPACE support form us. RACKSPACE password recovery not working RACKSPACE password recovery phone number RACKSPACE password recovery contact number RACKSPACE password recovery help RACKSPACE password RECOVERY support RACKSPACE password recovery wont work RACKSPACE password RECOVERY wont work RACKSPACE password recovery link RACKSPACE password RECOVERY issues RACKSPACE password recovery usa RACKSPACE password RECOVERY customer service. RACKSPACE email account password RECOVERY ' free RACKSPACE email password recovery ' cannot RECOVERY RACKSPACE email password ' RACKSPACE email password recovery ' RACKSPACE email password recovery download ' RACKSPACE email password recovery software ' free RACKSPACE email password recovery. RACKSPACE email password change, RACKSPACE email hacked password changed, RACKSPACE email hacked can't change password, change RACKSPACE email password on iphone, change RACKSPACE email password on ipad, change RACKSPACE email password on android, RACKSPACE email account hacked can't change password, how to change RACKSPACE email password on droid, RACKSPACE email password problems, RACKSPACE email password not working, RACKSPACE email account password recovery. RACKSPACE password recovery phone number.
YANDEX password recovery phone number +1800 365 4805 KO RAJAN Get YANDEX 1800 365 4805 password recovery phone number easy steps to forgot or change YANDEX password recovery via phone number #1-************ just follow some steps to recover YANDEX password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure YANDEX with YANDEX or other microsoft account services. Their are many certified officer to suggest people that how to change or recovery YANDEX voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to recovery YANDEX password to recovery or change it quickly, if you have any of them so contact to get well YANDEX support form us. YANDEX password recovery not working YANDEX password recovery phone number YANDEX password recovery contact number YANDEX password recovery help YANDEX password RECOVERY support YANDEX password recovery wont work YANDEX password RECOVERY wont work YANDEX password recovery link YANDEX password RECOVERY issues YANDEX password recovery usa YANDEX password RECOVERY customer service. YANDEX email account password RECOVERY ' free YANDEX email password recovery ' cannot RECOVERY YANDEX email password ' YANDEX email password recovery ' YANDEX email password recovery download ' YANDEX email password recovery software ' free YANDEX email password recovery. YANDEX email password change, YANDEX email hacked password changed, YANDEX email hacked can't change password, change YANDEX email password on iphone, change YANDEX email password on ipad, change YANDEX email password on android, YANDEX email account hacked can't change password, how to change YANDEX email password on droid, YANDEX email password problems, YANDEX email password not working, YANDEX email account password recovery. YANDEX password recovery phone number.
Computers & Internet Logo
134 people viewed this question
Alun Cox
