Question about Abit Computer-model:AN78GS Motherboard
Help ok. I installed two graphic cards on my new evga nforce 730a motherboard.. running wista 32 bit.. it took me for ever to get the cards to work but both had the same problem.. when i reboot the computer they both dont work. i get a blank screan so i end up switching back to the onboard.. i tried installing a evga 9700gt and evga gts250. here is my steps. 1. install the card 2.turn comp. on 3.disabled onboard graphics card 4.restart 5.installed drivers. 6.restart 7.get yellow question mark on new graphics card 8.reinstall onboard graphics card 9.switch monitor connections to new graphics card and it works... 10.i restart the comp. and the graphics card does not display anything and im back at step one.
  • 2 more comments
  • car1osa1bert May 29, 2009
    the gts 250 has sli technology. I thought that was the problem with the 9700gt which did not have the sli. Thats why i returned it. i only have one card. and yes the power cable is connected to the card.
    well. that is what i did with both cards. install. plug power. plug monitor. but bios did not recognize either.. that's when i started taking the steps i posted. i even tryied it on xp cause i have dual boot. i also turn the cards off in bios. they are still not recognize in boot up.
  • ksjon May 11, 2010
    have you tried to skip your step3?
    the way i would have done it is simply
    1. insert card, connect power.
    2. boot up computer with the monitor connected to the new card
    3. install driver. be 100% sure you use the correct driver (download it from nvidia.com instead of using a cd.)
    4. have fun.
    the bios automaticly detect if there is a screen connected to the expansion card and will choose that one by default.
    tho, what you can do to be absolutely sure, is to go into bios and disable the onboard vga.
    are you running SLI?
    have you connected the bridge between the two cards? and is the powercable connected to each of the cards (if needed)?
    Sergeant:
    Champion:
  • 233 Answers
Asus motherboard p5ld2-vm nodisplay low hit in processor ram pin volte is ok but nodispaly? what soluion?
Hello download the manual here:
http://www.asus.com/Motherboard/P5LD2VM/#support_Download
Select your windows system.
Open the manual folder and click on global for download.
Unzip the file, and you need adobe reader to read the content.
Here is also a fault finder guide:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Good luck
Jan 18, 2013 | Evga nForce 730a Motherboard
P5PE-VM with Win7 has no display on PCI video cards-EVGA 2600 or EVGA gt 220. Both cards ran fine with Win XP. What do I need to do?
Hello here is the mainboards homepage:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Are you running 32 or 64 bit system ???
Make sure the video driver supports windows 7, 32 or 64 bit.
The video card can sure run fine on windows xp but not in windows 7 as it is a totaly different system.
The mainboard has a 1 x AGP 8X slot.
So now you maybe has to find a video card that supports windows 7
Try also to download a manual.
Good luck
Dec 04, 2012 | ASUS P5PE-VM Motherboard
I cant install drivers
Go to the manufacturers website (nvidia) and download the most current driver for your 32-bit machine. If you have upgraded to a 64-bit processor your driver would be IA-86-32 (x86). Make sure you download the correct bit dor the driver
You do need a new driver for the new gforce but only nvidia can give you the correct one.
Apr 04, 2012 | Evga NVIDIA GeForce 8400GS, PCI Express...
I need drivers for Evga motherboard 112-ck-nf75-k1. I can't find them on Evga website. Please help.
Click on the link below, and select Mainboard fron the left hand side, then select Evga 730i/730a/630i/610i from the middle and then your operating system from the right hand side.
Your board is the 630i model
http://www.evga.com/support/drivers/
Regards.
Dec 14, 2010 | Evga (131-K8-NF44-AX) Motherboard
EVGA GeForce 6200 512 MB card + mouse pointer
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
Jan 06, 2010 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
No display signal from desktop
Yeah, sounds like a lot of people have problems with that motherboard.
Here's some steps from EVGA to take:
http://74.125.155.132/search?q=cache:wPIKE94wjB8J:www.evga.com/forums/tm.asp%3Fm%3D100700746+site:evga.com+Evga+nForce+730a+3+led&cd=2&hl=en&ct=clnk&gl=us&client=firefox-a
Nov 11, 2009 | Evga nForce 730a Motherboard
Motherboards
This board should have everything you want and be ready for a 45nm architecture when you decide to upgrade your processor.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4399367&CatId=2874
May 19, 2009 | Computers & Internet
Proper jumper & BIOS settings for XFX 750aSLI nForce motherboard
You will have to access the BIOS and disable the onboard graphics from there. Before you install your new card, boot the computer. As it is performing the POST, enter the BIOS (usually delete or F2 gets you in.) Once you have disabled the on board graphics, save your settings and exit. Then install your new card and attempt to boot the computer. If it will not boot, locate the CMOS jumper and activate it to reset back to default settings.
Apr 05, 2009 | Computers & Internet
HI would you
This graphics driver is compatible only windows VISTA 32 bit,
and supports the following card:
  • Supports GeForce 6, 7, 8, and 9 series GPUs including these newly released GPUs:
    • GeForce 9800 GX2
    • GeForce 9600 GT
    • GeForce 8300
    • GeForce 8200
    • GeForce 8100/NVIDIA nForce 720a
    • NVIDIA nForce 730a
  • If you found any errors in this combination, please install the chipset drivers of the motherboard to become the system stable.
    more info about 174 here is the info: http://www.nvidia.com/object/winvista_x86_174.74.html
    May this help,
    melnavz
    PS:pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
    Apr 21, 2008 | Computers & Internet
    Abit Computer-model:AN78GS  Motherboard Logo
    185 people viewed this question
    Top Abit Computers & Internet Experts
    Alun Cox
    David
    David
    Jerry Umali
    Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
