When I start computer, I get a messege - Procedure entry point _ismbcspace could not be located in the dynamic link library MSVCR71.dll. How do I fix this? when i try to open a media program such as nikon picture project or realplayer, i get a message that says : "The procedure entry point_ismbcspace could not be located in the dynamic link library MSVCR71"
SOURCE: Error messege on startup
Read the information at the following URL:
http://www.instant-registry-fixes.org/how-to-fix-msvcr71dll-errors/
If this just recently happened (usually due to software install), try running a System Restore back to before you started having the problem.
Go to Start > Programs > Accessories > System Tools and click on System restore.
Follow the prompts and select a bold date back before the problem occurred. You will be prompted to reboot.
If you still have the problem after rebooting, you can try to fix corrupted Windows file by running SFC /scannow from a command prompt (you will likely need your Window XP CD).
If all that fails, boot to your Window XP CD and run a repair. You should not lose any data, but backing up is always recommended..
Let me know if you have questions.
Honest1abe
