Question about Epson Stylus Photo RX700 All-In-One InkJet Printer
COPY of B&W or colored photos suddenley started having overall yellow-green tint
Epson RX700...All of a sudden COPY of COLORED photos have overall shade of yellowish green...SCANNED photos also PRINT have same hue...COPY of B&W photos have same overall tint...PRINT of "old" internal colr or B&W photos are normal,,,QUESTION: The suddeness of this happening during run of COPY...Could be a change in SCANNING LANMP characteristics (light spectrum)????...Am very good at delicate mechanicals & electronics...(1)Should I purchase new LAMP and replace, or (2)(Hopefully) Find a new or good used COVER and swap same ????....(3) Possibly problem with voltage/power fed to lamp?...Lamp fed uncontrolled ac of some value ???? Or(4) Is lamp fed "pulsed" ac from an internal solid state controller ???....Would be nice to have a circuit schematic....EPSON no longer makes PRINTERS with built-in scanner for 35mm & medium format slides/negatives...Have to buy BIG scanner, or can buy a "tiny" 35mm dedicated scanner...HELP !!!!....
J PENGUIN
  • 12 Answers
SOURCE: Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
Posted on Dec 31, 2007
svenby
  • 66 Answers
SOURCE: Epson C82 & C84 Printers will not laydown any ink!
your printer is clogged and i think it is impossible to unclog. you can try to use the flllowing link( unclog solution) cost 10 usd!!
good luck http://www.fixyourownprinter.com/kits/epson/K89
Posted on May 09, 2008
SOURCE: blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Posted on Jun 13, 2008
  • 110 Answers
SOURCE: Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Posted on Aug 22, 2008
Mykel_N
  • 315 Answers
SOURCE: how to scan a slide
Hi Arlene,
Have a look here:
http://files.support.epson.com/pdf/per248/per248bb.pdf
This is the quick reference card that would have been supplied with the scanner, scroll through the information to page 5 which tells you how to scan film or slides.
If you want the full manual and information then have a look here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=41624&prodoid=46253280
I hope that helps.
Mike
Posted on May 12, 2009
How can i put 4 photos on A4 page-using an epson rx700
Go to your printers and faxes (xp), or Devices and printers (Win7) folder
Right click on the RX700 and choose Printer Preferences
Select A4 as the paper size
Select Page Layout tab and select Multi-Page and select 4 (default is 2)
Select 4 copies
Print away!
Alternatively, if you're using Windows, use the Office Picture manger, Picture and fax viewer of the like, and select the multi pictures setting. If you're printing one photo 4 times, remember to select 4 copies, as you're telling the app to print ONE pic in a 1/4 of the A4 page. You need 4 copies to fill the page with the same photo.
Hope this helps.
Aug 03, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
R1900 adds blue-green tint to my photo prints
Epson doesn't like Generic Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 22, 2010 | Epson R1900 Printer
Epson rx700, the black prints grey
replace another black cartridge the cartridge is factory defect
Nov 03, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
The colors are off. e.g. Orange turns out
most likely you are either using generic ink, the paper your are using is not towards epson specifications, or you need to go through a color calibration on the printer.
thanks adi
Sep 16, 2009 | Epson Stylus Photo RX680 Printer
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
May 21, 2009 | LG 37LP1D 37 in. LCD Television
Canon i860 won't print deep colors
I had similar problem: everything muted and with brownish tint. Tried everything, finally discovered that I installed wrong cartridge: 6PC instead of 6C. The "photo" cartridges are pretty much the same, make sure you have the right ones: 6C, 6M, and 6Y.
Nov 17, 2008 | Canon i860 InkJet Photo Printer
Greenish tint
Not sure if this is the solution, but I believe the color polarizer filters have been burned. I have a yellow haze circle on mine and I'm pretty sure that's the problem. In my case the blue filter is burned, leaving the red and green stronger yeilding a yellow blur.
Aug 27, 2008 | Epson - PowerLite S1+ Multimedia Projector
Blue tint suddenly appearing on all my photos
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo RX700 All-In-One InkJet Printer Logo
79 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
