Question about Frigidaire GLRS264ZA Side by Side Refrigerator
Not cooling or freezing
My fridge has been down for awhile.  It first started out as freezing up.  I would thaw it out for a few hours and it would work for awhile, however, the problem got progressively worse.  One day, the thawing out bit didn't work and the fridge just stopped cooling and freezing.  When plugged in, the lights come on and some motor in back is running.  There is also a clicking noise every minute or so that happens like something is trying to kick on.  Hopefully, this is nothing major.  I have read some of the troubleshooting and hoping its not a compressor problem or coolant.  Please advise on other possibilities.  Sheri
  • 236 Answers
As you've said that started it with freezing up, either the unit has a leak then the refrigerant escapes or restricted system.
In this problem you need a qualified technician to repair the leak or reprocess the system and flush out the restricted system or repair kink pipe that cause restriction.
Posted on Jan 12, 2008
My side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Nov 12, 2009 | Samsung RS265LABP Side by Side...
Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Aug 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Mar 14, 2009 | Samsung Refrigerators
Amana side by side
either compressor is jammed or the starting relay with capacity is faculty
Jan 13, 2009 | Amana ARB8057CSL Bottom Freezer...
Freezer melts then freezes again
hi thanks for the question is this a new fridge . if it is the fridge does shut down to enable the freezer to thaw. if it did not do that do that the freezer would ice up . not cooling the fridge part thanks for the question
Sep 28, 2008 | Kenmore Stainless Steel Compact...
Refridgerator is not cooling properly
Ours does this too; it says its 34 degrees but really its 53-58 degrees. . . The compressor coolant part of the machine freezes and then it can't circulate the cold air to cool the fridge. You have to unplug it for at least 24 hours to let it thaw, or you can take out the lower drawers and shelves, unscrew and remove the lower back pannel (from the inside of the fridge). We use a blow dryer to thaw out the ice block that formed on the unit. It goes faster if it is unplugged, this fridge is horrible we lost hundreds of dollars in groceries before we figured out the problem.
Dec 26, 2007 | Samsung Refrigerators
Kitchenaid superba side by side ice maker stopped producing ice
This is a picture of an ice maker module.  Which is behind the white plastic cover.  The cover just pops off.  Look at the two little tabs in the center of white wheel.  If yours is twisted, pressed together, or one is broken then the module is bad.  If not, take the icemaker out and let it set for a few hours to let it defrost.  Put it back in and see what you get.  The ice maker won't cycle and fill with water until it gets below freezing so you will have to wait awhile.  It can be started manually by inserting a jumper wire into terminal T and H.  Let it start to cycle for about 10 sec. then pull the wire out.  At the end of the cycle it will fill with water then wait for it to freeze.  Also, if door was left open check all vents in fridge for ice build up.  This cause cooling problems of they are plugged.  Let me know what you find.
Oct 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
80 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
