Question about Frigidaire ATF6000ES Front Load Washer
Smell The musty smell is coming from the rubber ring surrounding the drum. If you have strong stomach, grab and pull the ring to full extension, looking at the drain holes in the rubber. If yours is like mine, you will be shocked by the growth of black mold in and around the holes. This exists even after a cycle of hot water and bleach. Twice!!!!
    Problem Solver:
  • 8 Answers
One downfall of the front load machine that it holds moisture causing musty smell in drum. Try leaving door agar between washes and use a cleaner specific for front load smells 1 every month.
Posted on May 30, 2009
Kenmore Elite H3 washer's loud in spin cycle & smells burnt.Debris & plastic in well inside washer.Pushed aside rubber ring & saw lg. gap btwn. metal drum & surrounding plastic.Parts needing replace?
It sounds like the drum has broken from the rear mount. This will chew up the outer shell. This is a very labor extensive job. The parts are expensive also. You will probably need a new outer shell and inner drum.
May 29, 2015 | Kenmore Washing Machines
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
Interior Smell, musty mold smell
run water over the winshield ..keep eye on the fire wall and sides. also check the florr if is wet. water is likin somewere
Feb 25, 2009 | 2006 Chevrolet Equinox
Very Strong Odor When Refrigerator Runs
Without looking at your fridge I would say the strong rubber smell is the heater element has dust on it or the heater contactor is closed and the heaters are staying on. Either way it would be good to get it checked out. I cannot think of anything else that would make a rubber burning smell.
Jan 23, 2009 | Frigidaire FRS26R4A Side by Side...
Mildew and Smells
pull out soap dispenser draw and look up to where water comes out. my mach was full of mildew. i removed the top of dispenser soaked in bleach. i believe this is where mildew problem starts and spreads to drum and gasket
Nov 24, 2008 | Bosch WFMC 3200 Front Load Washer
Musty odor
Washer tub is probably very dirty from excess soap suds.  These washers have no way of cleaning rinsing themselves off so they will have to be disassembled and cleaned out to remove the odor.  That's about a 2 to 3 hour job.  Be sure to replace the rubber seal and the shaft seal to prevent leaks.
Oct 26, 2007 | LG WM2688HWM TROMM SteamWasher
Frigidaire ATF6000ES Front Load Washer Logo
558 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
