Question about Endless Summer (GA200209) Stainless Steel Open Flame Patio Heater
Burner will not ignite as pilot light goes out when knob is released
Pilot light continues to go out as soon as I release the knob to turn it to high.
    President:
  • 2,559 Answers
Are you holding the knob for 30 or more seconds,If so,Clean or replace the thermocouple/Flame sensor.
Posted on May 29, 2009
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
Need to light pilot light
You need to turn the knob on the gas valve (inside the heater) to the "pilot" position. Then, while holding a flame over the pilot assembly push down on the knob.
Gas should come out of the pilot and ignite. Continue holding the knob down for 10-15 seconds. Release the knob and the pilot should stay lit. If not the pilot generator may need to be replaced.
Turn the knob to the "on" position, close the heater and turn the heater on and turn the thermostat to hot. The heater should fire. If it does not fire and the pilot goes out, that may also indicate a pilot generator problem.
Nov 20, 2013 | Teledyne Laars Pool & Spa
My Delonghi Propane Heater will not stay lit.
this sounds strangely like a safety switch problem , ill bet the device that confirms the pilot lite lit before going to main burner has a problem
Jan 19, 2013 | DeLonghi SafeHeat Heater
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
Pilot light is ok burner will not ignite. the flame goes out soon as i release button.
You seem to have left a mixed message, as far as the problem is concerned. However, I think I have figured it out. But, first, let's go through the lighting procedure. To light the PILOT, you turn the Control Knob to PILOT and push the knob all the way in. While holding the knob in, you press the ignitor button. Once the pilot lights, you continue to hold the knob in for 30 to 60 seconds (which allows the Thermocouple to fully heat up), then you ease off on the control knob and the pilot stays lit. Right? Then you turn the control knob to ON and the Burner lights. But, that's not what's happening with your heater.
In a short version here's what I think you meant ... When you release the Control Knob from the PILOT position, the Pilot Flame goes OUT. It never has a chance to light the burner. Right?
If this is the case, couple off things can cause this. First, the Oxygen Depletion Sensor (ODS) is clogged with dust, lint and/or pet hair. Therefore the ODS sensor is reading the Oxygen level as Unsafe for operation. Secondly, the Pilot is dirty and is not allowing the flame to touch the Thermocouple as it should. The way to tell this, is the pilot flame curves upward, rather than being straight and lifts off the Thermocouple.
In addition to the two things I have listed which are the problem 90% of the time, there are 7 more. But rather than list all of them and how to fix the problem, I'm including a link to the Owners Manual for your heater. You can download and print is for now and future reference. Pay close attention to the Troubleshooting Guide. That's where you'll find the other 7 problems and their solutions.
http://www.desatech.com/manuals/Vent-Free%20Heaters/117001-01.pdf
Armed with all this information, I feel confident that you can Troubleshoot and solve the problem.
Please let me know how it works out for you.
Mar 08, 2011 | Desa International GWN10T Wall Mounted...
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
Pilot light does light , but as soon as you release the gas knob it goes out
Hi there. You must continue to hold the knob in for at least 30 seconds before releasing. If the pilot still goes out, the "thermocouple" is bad. It's the little tube in the pilot flame. To replace, remove the main burner assembly/pilot. You can get a thermocouple at any hardware store. Ask questions while you are there.
Thanks
Paul
Jul 12, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
When lighting one of the burners, the ingnition knob has to be held down over ten seconds for the flame to stay lit when the knob is released..
Lift the top of the Stove up.
Look for a Small line that goes to the Affected Burner.
At the end of that Line you will see a small Flathead Screw.
Turning That screw Clockwise Adjusts your Pilot Light for that Burner.
Be careful not to Adjust to High, it would just be a Waist of gas.
hope that helped.
May 20, 2009 | Gaggenau 11 in. VG 232 Gas Cooktop
Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Jun 01, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Endless Summer (GA200209) Stainless Steel Open Flame Patio Heater Logo
1,078 people viewed this question
Top Endless Summer Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
