Question about Lexmark X2600 InkJet Printer
Printer will not print multiple copies
I have sent documents to print to my printer. It only prints the last page, sometimes none at all. What am i doing wrong?
  • rjchretien May 29, 2009
    I have a small business that i need my printer all the time. Is it possible that we can solve this problem tonight? I have turn the printer off thinking it may reboot. Is this ok? I really need my printer.
    Ramona
  • 90 Answers
Go to start menu, control panel, printers and faxes, right click your printer, click properties, click the advanced tab and make sure your printer is set to spool print documents.
Posted on May 29, 2009
How do i cancel a printing on my laserjet 1100a
The document you sent to the wrong printer is still in the print queue. You need to go into the print queue and delete the document there. You may need to click to control panel, click on the laser jet printer and delete the wrong document.
Dec 15, 2017 | Office Equipment & Supplies
Hi i have Xerox 7760DN with both ps anc pcl enabled - there's a 68 page document getting prited everytime the printer is turned with bunch of gibbersih from startup. DO you know the resolution for
Sounds like a print job was sent to that printer using the wrong print driver. Unplug the printer from the network and see if it only prints the startup page. If so, then you need everyone to cancel the print jobs they sent to this printer. Then hook the network cable back to the printer and see if a print job can be sent to it (one that has worked in the past). I suspect someone has an old printer driver that is using this machines IP address to print to and it is confusing the Image Processor Board...
Apr 04, 2013 | Xerox Phaser 7760DN Laser Printer
I have a inpiron 530 with a Photo 926 printer. It will only print the last page of a print job.
Hello randy,
This is going to take some troubleshooting.
Please try the following, and test after each change. Hopefully we can get this working for you quickly Verify that when you hit print it under print range that only the last page is selected.
Try printing a different document, this is assuming you've been only having the issue with one document. Try printing a different type of document, using a different program such as word, notepad, or even a multi-page website.
If any of these has worked for you then it has either narrowed it down to the specific document, or the program, re install the program in question.
If none of the following has helped.
go to start/run type cmd to open the command prompt type following net stop spooler net start spooler this will restart the print spooler service.
If none of the above worked, delete the printer and reinstall. If problem persists install printer on a separate computer to verify that it works correctly.
Good luck, and I hope i was helpful.
Aug 14, 2011 | Dell 946 All-In-One InkJet Printer
When i ask to print all (pages), only the last page gets printed. I have to select and print each page separately to print out whole documents. I'm printing from an Hp using windows Vista 6.0. This...
some printers collate pages, which means they print from the last page to the first page. so that when you pick up the pages from the finished printing tray they are in order.
if you say it stops after the first page, there are a few possible reasons for this.
either you closed the application you were printing from before you finished printing (which sometimes cancels the printing job)
or the computer decided it wanted to cancel the printing on its own, this can happen if the printer has sometimes an error, this error or cause could be a lag between the data transfer to the printer.
try printing without collating the pages, while keeping the application/document open.
and make sure you have the latest drivers.
May 09, 2011 | Lexmark X7350 All-In-One InkJet Printer
I tried printing a document, and it printed all the pages except for the last page. I have tired to repeatedly print the last page and it will not print. The toner light is on, so does that mean I have...
hi,
first of all maybe your file has a problem. DO NOT CHANGE your toner. Try to print only last page, or copy the content of the last page in the new document and the print it. Sometimes the printer can not recognise some files correctly and that is the major problem
pifonski
Feb 18, 2011 | Brother HL 2140 Laser Printer
Single page printing
OK, well when printing from the internet it quite often only prints the screen you are on, I presume, because you likes what you read, you wish to print it, well as you are on Page 3 the end of the document, thats what get printed. You actually, need to go to the File Menu, select, Print, and actually select, the type of print, there are options, Print ALL, Print Page, Print Selection, you need to set that, it sometimes remembers a setting and perhaps 3 was the last setting.. In any event don't just "Hit Print" you have to do as related, I am not sure if you can set up special "Print Now" parameters, but I expect you can, choose a "Default" setting.
Mar 31, 2010 | Lexmark X5650 All-in-One InkJet Printer
Printing 'bookfold' documents
Does the print queue show that all the pages have been sent to the printer. Check the print screen to make sure that either page 1 or print current page are not checked. This type of problem is generally caused by the printing application rather than the printer.
Apr 15, 2009 | Brother DCP 115C All-In-One InkJet Printer
Printer continuously prints document sent last week
In this printer you can "CLEAR" the memory and cancel all jobs, do this first and see if this resolves your problem.
Apr 06, 2009 | HP LaserJet 4250n Printer
Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Jan 08, 2009 | Lexmark Optra T610 Laser Printer
Prints only a few pages
try to reinstall the printer driver..
good luck
Apr 03, 2008 | Dell Inkjet 720 Printer
Lexmark X2600 InkJet Printer Logo
1,688 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
