Question about Imperial IFS40 Deep Fryer
Burner will not light
Pilot lights but when you turn it to on burner will not light. also is there a way to trouble shoot the high limit or some way to check to see if it is good?
  • Imperial Master
  • 8,220 Answers
What you need to do is simple. Check for continuity between the following links diagram and any open parts are gonna be the problem. The main suspect is gonna be the gas valve solenoid followed by the control thermostat. if the fryer got real freaking hot then check the fuse and high limit that is tied into the gas safety magnet.
anybody with any fryer experience can fix that puppy in a minute.
Posted on Jun 13, 2009
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
Sterling RF-45 Pilot light comes on and the burner won't fire. The pilot goes out and fan keeps running.
clean pilot check flame sencor is clean , jump high leval limit first see if it lights , if not try low limit , check thermocouple is tight if fitted ,
Sep 24, 2011 | Sterling RF45 Propane Gas Heater (45,000...
I have an old Kenmore 70 Series dryer, just this weekend, the drum turns but no heat..... after a little search online, I suspect the pilot light went out. Where is the pilot light located? I lost the...
The burner is on the lower right side of the bottom under the drum. See this manual pdf page 23 for location and access. https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
The burner uses an ignitor and a flame sensor vs a pilot light. See this link pages 12 - 14
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/c5c81d2c8f26b1b5852574f20055c20c/$FILE/4314010.pdf Note the M series burner has been in use since 1984.
The dryer must have a complete termperature circuit and no "high temp limit" failures for the ignitor to light. That means the door is closed, motor is running, and the cycle thermostat is less than 135 deg F and the High limit thermostat is less than 180 deg F just to provide power to the gas valve solenoids, ignitor, and radiant / flame sensor.
Thanks for choosing FixYa,
Kelly
Nov 28, 2010 | Dryers
I have a dyna-glo model rmc-40lpt, the pilot light is hard to light up, most of the timr I must use a match to light it....after its lit , the burner bar will fire up just fine , high or low but the flame...
are you saying it lights back to the orfice ?? if so i would say the pilot needs cleaning out a long with the burner which could be blocked with dirt or fluff and at the airports to the burner , and the ignition could need cleaning ,
Sep 26, 2010 | Dyna-Glo Heating & Cooling
Pitco Frialator SF14 pilot will light and the burners will light but within an hour it completely shuts off (pilot and burners). The high limit and thermostat have been changed 1 month ago.
Check the hi limit sensing bulb, it should not touch the fire tube, when it does, it will sense high temperature which will trip its mechanical contacts and will shut pilot and burner flames.
Make also sure that the thermopile is free of soot or any form of dirt and is properly heated by the pilot flame.
Jul 06, 2010 | Pitco Frialator SG14 Deep Fryer
Pilot does not turn on. Fryer was in use n working perfectly. We turned pilot off cause fryer was not gonna be in use. so now pilot does not turn on.
Make sure the high limit isnt tripped. There is a red button down next to the thermostat that you push to reset the high limit. If it will not light after that it is probably a bad thermocouple - This is the sensor located in the pilot flame.
Make sure it is well positioned in the pilot flame. If not adjust it into the flame, if so replace it. They are generally available at your local hardware store because they are also used in water heaters and home furnaces. They are pretty cheap and fairly easy to change. It ususally requires that you remove one or two of the main burners for easy access. Empty the grease first just to be safe. Remove the nut from the top of the drain valve handle and remove the handle. Look to the top of the main burner or burners in front of the pilot and there are two bolts on each burner that need to be loosened (not removed) and then lift the burner to remove the bolts from the slots and pull the burner down and out. Remove and replace the sensor (should be fairly straight forward), Replace the burners and valve handle, refill with grease, and try to light it again.
Jun 08, 2010 | Cecilware EFS-40 Deep Fryer
Pilot light goes out
The Tstat has a capillary that looks like a thermocouple but it isn't, its a bulb with liquid that expands and contracts based on temperature. A pilot can go out due to a high limit switch being week or getting to hot and that can be shaped like a thermostat capillary or can be simply a disc with a button if even there is a high limit on your stove. There likely isnt. So see the next suggestion.
I suggest lighting the pilot, turning on the main burners while watching the pilot. If the pilot shrinks in size, then check your gas pressures before and after turning it on and seeing if there is a wide variation. I would suggest the pilot is dirty or the pressure regulator is faulty.
Dec 19, 2009 | Grilling
Pilot will light but main burner will not light
if burner lights after jumping valve you have something wrong in thermostat loop. disconnect the 2 thermostat wires on gas valve and use multimeter on continuity setting. if all wires ,connectors and components are good,you will get a tone.since you have jumped out each component in thermostat loop with no success ,i would suspect a bad wire or oxidation on a terminal .
Sep 24, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light
Assuming that your make up air and exhaust hood are properly balanced, no negetive pressure conditions exist, your gas manifold pressure is at 4" wc, your air/gas mix on the burner set correctly, the your problem would be the pilot adjustment. If the flame is not intense enough flame to survive the sudden air shock, it will go out.
The pilot height should be about 1 1/2". Your Pilot orfice could also need cleaning. Eliminate excessive draft in your kitchen.
Here is the manual for your unit, it covers these topics.
http://www.frymaster.com/docs/uploaded/fry/products/OperationalManuals/819-5355.pdf
Jan 24, 2009 | Frymaster Dean H17-SC Deep Fryer
SR24
It could be a faulty high limit, you can also check the high limit probe to insure it is mounted securely against the through tube wall in the grease. Also check the burner, there are baffles that run through it and when they get old the flames don't move though the burner correctly and will cause the high limit to trip prematurely
Nov 09, 2008 | Frymaster Dean 2424G Deep Fryer
Imperial IFS40 Deep Fryer Logo
257 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
