Question about Microsoft Xbox 360 Console
Xbox 360 Blurry/Fuzzy Screen
Playing Call of Duty WAW and after 30 mins the screen went fuzzy with white lines, the games still worked, but i turned it off. Tried again an hour later and after putting COD disc in, went fuzzy again. when i turn on my 360 blurry vertical lines run down the whole screen i can play and hear but extremely hard to see but i still can see the game working
  • Anthony Abbott May 11, 2010
    i think it might be your tv that is messed up... does your tv work on rlike cable tv?
  • Microsoft Master
  • 2,404 Answers
The machine is overheating and the graphics chip on the main board is acting up cause of it. Make sure there is no dust or dirt blocking the air vents that would cause the system to heat up more then normal.
If that doesn't do it then maybe think about getting a cooler for the system, here is a website that talks about a few of them. Click here.
If that doesn't help then your mainboard is going bad and would need to be replaced.
Posted on May 29, 2009
Basically fuzzy lines came from heat.. whenever I got this lines, i immediately turn on my airconto cool it up and then fuzzy lines just went away just like that.. TRY this, its free..
Posted on Aug 31, 2010
Maybe the check ur video cable's and monitors
Posted on May 07, 2011
2 Suggested Answers
  • 265 Answers
SOURCE: Xbox 360 Blurry/Fuzzy Screen
This means its most likely over heating and the GPU is on its way out...
you can try using a diffrent cable see if this helps.
if not contact microsoft as they now have 3 years warrenty on them :)
thanks
alex
Posted on Apr 06, 2009
Hi my problem is at first my xbox 360 went on fine then after 10 mins the screen started going fuzzy so i turned it off then back on was working fine for about half an hour then the screen started going...
If you hear sound but no picture then your graphic chip has got separated from your motherboard, this is not a simple fix. receommend you to look for a local repair shop that can handle game console repairs or send it to xbox.com
Thanks
www.1RepairStop.com
Sep 11, 2011 | Microsoft Xbox® 360 Core System Console
My Xbox 360 is fuzzy and has green dots all over the screen
I doubt it's the 360 since everything else is working just fine. The menu works fine, the game works fine. However if you downloaded one of these maps from the marketplace it may be corrupt, and you will have to delete and re-download the map pack.
May 15, 2010 | Microsoft Xbox 360 Console
Screen goes fuzzy when i play games but dvds work.
It's a problem with the GPU. You should contact Microsoft for support.
Nov 21, 2009 | Microsoft Xbox 360 Console
When playing games my xbox 360, the screen will
try this. unplug everything (power cord, av cables, wireless adapter, controllers) and take off the hard drive. dont plug anything in for about 1-2 minutes. when the time is up, put the hard drive on first then plug everything else in.
Sep 27, 2009 | Microsoft Xbox 360 Arcade
Xbox 360 makes televison screen fuzzy and difficlt to see
Firstly check the system configuration blade on your Xbox 360 startup screen and check your display settings, if you've got an Xbox Elite/New Premium and have HDMI cable then it should be set as Intermediate/1080i/p settings, if you have the component cables then it should all be set as default.
If that isn't the problem and your games are still loading up with a fuzzy screen then there is either something wrong with the cables in your Xbox or your TV can't handle the graphics that the Xbox is producing and you will have to go into display settings and try setting them as either lower settings or higher settings depending on the TV you have.
It will help if you can provide details to me on your TV too, I'm not as good with TV's as I am Videogame Consoles/PC's but it will help me if I want to solve your queries further.
Jul 21, 2009 | Microsoft Xbox 360 Console
thanks
alex
Apr 06, 2009 | Microsoft Xbox 360 Console
TV screen is fuzzy
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
This issue means that your xbox 360 console is having a problem with its Video Card.
Mar 28, 2009 | Microsoft Xbox 360 Elite Console - Black
There are fuzzy lines on the screen when i play any of my games
you could try checking the AV cords that connect your TV to you xbox 360 and making sure they are securely connected
Jan 28, 2009 | Microsoft Xbox 360 Console
The xbox 360 screen is messing up and pixelating
After a lot of calls and finally a return to MS for RMA, MS checked and agreed to change the motherboard... it seems quite common issue (full HD seems to be a stretch for the console for games or for movies...). So the only way is to return it for repair....
Nov 08, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
6,522 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
