Question about Olympus Photography
Film won't advance. But does when the back is momentarily opened
Olympus is-3dlx camera. Film won't advance after exposure. If I open the back it advances, but spoils the shot. Everything else works OK. Ideas? Fred
  • 256 Answers
Do you have fresh batteries in the camera. Batteries may be needed to set the exposure and trip the shutter. If the batteries are good, the back when closed may be jamming the film between the cassette and the body. Also make sure your fingers is not restricting the rewind knob on the left side of the camera.
Posted on May 29, 2009
I desperately need to locate an owners manual for the camera listed below
If you mean the Olympus IS-3 DLX, you may download a copy of the manual from http://butkus.org/chinon/olympus/olympus_is-3dlx/olympus_is-3dlx.htm
If you really mean the camera "listed below" then what make and model is it? You don't list any below that statement.
Apr 28, 2014 | Olympus IS-3 DLX 35mm SLR Camera
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
Nikon FG. Replaced 3V battery. On the M90 setting the film advances OK. On 'program' or other settings it will only advance once and after shutter fires it will not advance until put on...
M90 is a battery independent setting - it requires no battery power to function. If it won't advance until put on M90 from other settings, then either you're not allowing for proper exposure, have the settings incorrectly set (film speed, etc), or you have shutter issues. The shutter is electronically controlled on all settings except M90. In the auto setting, your lense MUST be set to the smallest aperture (biggest number). On any other setting, you can use it however you'd like. I'd suggest unloading any film, setting the shutter speed dial to 1/125 or so, opening the back and looking thru and firing the shutter. If it's not snapping open and immediately closed, theres an issue and you need to consult a repair technician either locally, through Nikon, or through KEH Camera online.
Jun 29, 2011 | Nikon FG 35mm SLR Camera
I have a pentax 67 camera and the film advance lever is jammed. it will not advance without putting undo pressure on it which i am not willing to do. i have read many forums that have said this is not an...
Try pressing the film release button on the underside of the camera. This should unstick the advance roller.
If possible, replace the watch battery for your camera (inserted in the bottom, right by the teeny black button I mentioned above).
Change your exposure setting to Bulb exposure and back.
If all else fails, take your camera into the darkroom (or at least a completely light-insulated closet, bathroom, etc.), and pop open the back and recover your film. Hopefully you won't have too much wasted film on your hands.
Good on you, however, for not forcing the lever. Nothing good will come of that.
May 06, 2011 | Cameras
When you put the film in the meter thats shows you how many exposures you have left stays on the s instead of going to one. The film is being pulled properly and is acting normal but even the sound doesnt...
I would definitely be concerned that the film is not advancing. I have a Minolta that has the same problem. I missed many a picture because I didn't pay attention to the meter showing the film advancing. I would just make sure the film is advancing by taking a couple shots with the back open before closing it.
If you are positive the film is advancing, it really doesn't matter what the meter says as long as the film is stopping after each exposure.
Finally, if the film is advancing , but the meter is not, and you want it to, you will need to see an experienced repairman to correct it.
Good luck.
Thanks for using Fixya.
Apr 27, 2011 | Minolta Maxxum 7000 35mm SLR Camera
My Pentax SPII shoots blank images
You can check the shutter without film in the camera. Remove the lens and open the film door. You will see the cloth curtains of the shutter in the center. Advance the film lever to **** the shutter and set the speed dial to a slower speed like 1/15. Hold the camera so it is aimed a a light source, (a window will do) and fire the shutter. You should see the light through the shutter for the time duration is is set to. (1/15). If you see the light source, repeat the process going up one speed setting until you reach 1/1000. If you see the shutter open and close as described, then try another roll. After you load the film and close the back door, make note of what the rewind knob is doing as you advance the film. It should spin counter-clockwise each time. That is a easy test to know that the film is traveling in the camera properly. Vary your exposures with the new roll at different speeds and f-stops. You should get exposures, but if not let us know.
Jan 31, 2010 | Olympus Stylus 850SW Digital Camera
Camera won't work, has an E on the display
If E blinks in the exposure counter, the film is improperly loaded. Reload the film.
Her is the link to the Olympus website where you can download the instruction manual
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=298
Feb 13, 2009 | Olympus Stylus Zoom 80 Wide DLX 35mm Point...
Product description of olympus XA1 Camera with Elec.Flash A9M
To open the camera, you need to close the lens, then with the rewind mechanism, flip open the handle and lift the whole rewind mechanism and the handle and it will open the back of the camera. I hope this helps.
Oct 11, 2008 | Photography
F4s film rewind problem
Hey mikki1,
One reason this might be happening is the multiple exposure lever is stuck to the select position which would not allow the film to advance. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 15, 2008 | Nikon F4s 35mm SLR Camera
Photography Logo
102 people viewed this question
Top Olympus Photography Experts
mbutkus
Level 1 Expert
Bart Pulverman
Are you an Olympus Photography Expert? Answer questions, earn points and help others
