Question about IBM ThinkPad T20 2647 Notebook
Thinkpad t20 dvd error
I left my laptop on for about an hour or two while i was out of the house and when i came back home i noticed it was off.  i tried turning it on and would not boot up.  I then removed the ram turned it upside down and placed it in the oppisite port.  i then put in a different hard drive.  While the computer did boot up i got an error after the windows xp logo.  it says everything is ok but there was a dvd error.  i tried reloading windows on it but i cant get past the error screen.  it give me the option to enter ibos or boot device setup but dose nothing when i try them.   any help would be greatly appericated.  thanks -david
  • 5 more comments
  • dtkeys1 May 29, 2009
    and i did try to boot it with out the dvd drive and still no luck
    i havent tried that but the hard drive is form the same computer i just upgraded to a larger one and tried the old one first i going to try it right now
    no luck with the original harddrive but the original problem is i after the windows logo( i had xp on it ) i get an error message 0175
    ok i found out it isnt a dvd error but an 0175 error crc1 stop post?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Try cleaning the laser on your dvd drive with a damp q-tip, there could be dirt or even a smidge of dust that is affecting the drive or it could be a weak laser in your drive.
  • ksjon May 11, 2010
    when you boot up your computer. can you please F8 several times so you get you the boot menu. choose the option -> deactivate automatic reboot on error (or something similar)
    when/if the bluescreen appears, write down the top line that looks like this
    IRQL_LESS_OR_NOT_BLAH_BLAH
    and the line close to the bottom
    STOP: 0x000021 (random numbers i dont need)
    maybe a stupid question, but have you tried to put back in the original harddrive? what was the original problem?
    cause to me, it now seems you are trying to get the computer work with a harddrive with xp installed from another computer.
    Novelist:
  • 166 Answers
Unfortunately only few people know your problems solution but I'm happy that i can help you.
Its simply a problem of setting HDD ( Hard Disk Drive ) type which can be changed using BIOS setup. I hope your laptop must have SATA but if its not working on current settings then please change it to another options available.
Surely, your system will get booted after that and furthermore you can re-install your windows again...
Rate this solution if it was helpful to you.
With Regards,
Shyny
Posted on May 29, 2009
I am trying to restore my IBM Thinkpad 2647 model to factory settings but don't know how.
While switching ON your Laptop, press Thinkpad Access button(Blue colour) which is there in top most left side and select the option restore factory settings.
Hope the above answer solves your queries.
Revert back for further assistance or clarifications.
Dec 18, 2009 | IBM ThinkPad T20 2647 Notebook
Problem with ThinkPad T20
the internal coin cell battery has gone bad, it needs to be replaced.
Aug 04, 2009 | IBM ThinkPad T20 Notebook
Error 0175 on boot IBM Thinkpad T20
Error code Symptom or error Field replaceable unit or action, in sequence 0175 Bad CRC1, stop POST task. The EEPROM checksum is not correct. System board
Mar 27, 2009 | IBM ThinkPad T20 2647 Notebook
Error 0188 IBM Thinkpad T20
Only component tech/professional can fix it, not DIY.
Nov 27, 2008 | IBM ThinkPad T20 Notebook
Blue Button under right and left button on IBM Thinkpad T20
The blue buttons on the Thinkpad are designed to be used with the blue FN key ( Lower left ). Press and hold the FN key, then press the applicable blue function key.. I.E. Brightness, Volume.. etc.
Nov 19, 2008 | IBM ThinkPad T20 2647 Notebook
Need driver for 8x dvd drive for thinkpad
When a properly inserted and working drive is connected, it is automatically discoveredand installed. Specific drivers are not necessary or available. I will assume you are not talking about a DVD viewer application?
If the OS does not discover the drive, then the drive is likely defective, or not properly connected.
Oct 26, 2008 | IBM ThinkPad T20 2647 Notebook
Regional codes
The DVD region cannot be changed more than 5 times without 3rd party software which is very hard to find now as it has even been restricted in Europe.
You can look for "dvd region css free" online but you may not be able to get it anymore.
Dec 25, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 - 0190 Critical Low Battery - Will not boot
i know what the error is what it is is a wire labeled "MAIN" has disconected to fix it you need to put the wire back into the tiny slot in right bottom corner of the right hole
i had the same error and just fixed it like 2 minutes ago it now runs perfectly
Dec 17, 2007 | IBM ThinkPad T20 2647 Notebook
"Critical Battery Error" even with not battery in laptop
Do you have another power supply to use?
Also, is it keeping correct time and date?
Dec 14, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
152 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
