Question about Magellan Maestro 3140 GPS Devices
Magellan 3140 wants to shut down even when plugged in
Even when plugged in, after awhile the screen asks if I want to stay on battery or go to sleep, I want it to stay on and it should not be on battery power as I have it plugged in. It is getting power because it will charge up I can plug it into my truck power and let it stay for days supposedly charging..It will power on but it will have a message that it does not have enough charge and it will go to sleep in 15 seconds..That it is recommended that i charge the battery up.... It will actually come on by it self and go through the same cycle about battery problem..Peice of ****. They sold it to me that way....Help...
    President:
  • 1,111 Answers
This is a very common problem with these magellan 3140 and als the 3100,2000,2200t,2500,4000,4040 and the 4050
most likely the power port is damaged and needs replaced.i have these power ports but often they just need resoldered..i can repair thesemagellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ...
to open the case on a 4040 you must start on the powerbutton side, otherwise youll break the unit
Posted on Jun 12, 2009
I have a 3140,kept getting blow battery message,bought new battery-same problem-charger is green Thank you Ralph Plechner
Hi ralfples
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Nov 03, 2010 | Magellan Maestro 3140 GPS Devices
Megellan keeps "counting down" to the sleep mode even when plugged in to the car adapter. Also tried charging it overnight in the house plugged into the wall outlet and still got the same result
bill
Aug 14, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Says battery is extremely low and will now go to sleep.
the folowing advice pertains to the following magellan gps systems.
bill
May 17, 2010 | Magellan Maestro 4000 GPS
Shuts down almost immediately after starting even on charge mode...in non-charge mode "battery level critically low"
Hi matchmakers0
this is a very common problem with your model gps
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
Bill
Apr 17, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3140 touch screen alignment
I have the same problem. It seems the only answer is to purchase another GPS. I am looking at the Garmin 765T
Jan 05, 2010 | Magellan Maestro 3140 GPS Devices
Magellan maestro 3140 wont power up/start anymore??? Is it dead?
hi ohh_bambino plug it in and let it charge for awhile using a know good charger, like the car charger. it has a indicator light to let you know its charging.
now press and hold the power button for up to ten seconds until it starts. if that fails
this is a very common problem for the models listed below.
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
or buy the port here
if you need further help, just let me know.
bill
Nov 19, 2009 | Magellan Maestro 3140 GPS Devices
Battery does not keep a charge. Can the battery
yes, the batter can be re placed, but i would verify its charging before buying a battery.
make sure green light is on the car charger (or a known good charger0 and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..
after its started, go to the system setting. the battery meter should be moving left to right. if its all green and turns off when unplugged, the battery needs replaced.
your part # for your battery should be 37-00030-001you can get a battery HERE but verify your unit with the seller.
if it only has a few bars and is not moving while plugged it, it is not charging.
Nov 14, 2009 | Magellan Maestro 3140 GPS Devices
We have a Magellan Maestro 3140 which will not charge up and keep shutting off even when it is connected to the DC charger on the car. Do we need to send it to the factory for repairs?
this is very common problem with this and many model magellans.
try the car charger2.gif.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
Oct 18, 2009 | GPS
I used this GPS for about an years or so butnow when I plug the Magellan 3140GPSit into the car sigarette lighter I get an messages pop up battery low level and it shuts off. I am able to put in my desired...
most likely the power port is damaged and needs replaced.i repair those magellan gps if you need help. if i cant fix it there isno charge. wmetz@comcast.netto open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Jun 10, 2009 | Magellan Maestro 3140 GPS Devices
Wants to shut down even when plugged in
this is a very common problem with these magellan 3140 and also the 3100,2000,2200t,2500,4000,4040 and the 4050 most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ... to open the case on a 4040 you must start on the power button side, otherwise you'll break the unit
May 24, 2009 | Magellan Maestro 3140 GPS Devices
Magellan Maestro 3140 GPS Devices Logo
102 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
