Question about Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Blue glow in the viewfinder of Minolta Maxxum 5
The first I heard about a blue glow in the viewfinders of late-model Maxxums was in an eBay guide written by J.D. Katz. Apparently Maxxums 3, 4, 5, GT, QTsi, STsi, HTsi, XTsi and probably the 50 and 70 are susceptible. All were assembled in either Malaysia or China and all have penta-mirror viewfinders. Both my Maxxum 5 and my XTsi just recently started doing it: the 5 has sapphire-blue streaks on either side of the viewfinder; the XTsi's viewfinder has just a faint blue haze. Probably some coating on the glass inside the viewfinder is breaking down with age. It's a shame because they are otherwise excellent cameras. While it is an annoyance, it is confined to the viewfinder and should not affect the images taken. Probably won't have much luck getting Sony to do anything about it either, since they're film cameras and they're getting old.... Does anyone have some further insight on this issue?
SOURCE: Minolta STsi Maxxum
i donn't know what is the part in the right zone is like a blsck roll and the another is a func is another roll but this one is silver with like a eye and "osi","wl"and func in the center
Posted on Dec 26, 2007
SOURCE: when I look through the viewfinder of my camera I see blue streak
This isn't really a solution, but when I check "I have  similar problem", it takes me to a different page all together. The first time I heard about a blue glow in the viewfinders of late-model Maxxums was in reading an eBay guide written by J.D. Katz. I didn't really believe him until my own Maxxums started doing it. Apparently Maxxums 3, 4, 5, GT, QTsi, STsi, HTsi, XTsi and probably the 50 and 70 are susceptible. All were assembled in either Malaysia or China and all have penta-mirror viewfinders. Both my Maxxum 5 and my XTsi just recently started doing it: the 5 has sapphire-blue streaks on either side of the viewfinder; the XTsi's viewfinder has just a faint blue haze. Probably some coating on the glass inside the viewfinder is breaking down with age. It's a shame because they are otherwise excellent cameras. While it is an annoyance, it is confined to the viewfinder and should not affect the images taken. Probably won't have much luck getting Sony to do anything about it either, since they're film cameras and they're getting old....
Posted on May 29, 2009
  • 302 Answers
SOURCE: when I look through the viewfinder, everything is dark....
First remove the battery. wipe off the battery contacts. reinstall the battery. Battery may be weak, replace.
If that fails, remove the lens. See the mirror in there?
If its stuck in the up position, you can return it by hand. But I recommend a toothpick. It won't leave fingerprints.
Posted on Oct 11, 2009
  • 302 Answers
SOURCE: Model QTsi Maxxum. Need a new battery chamber
The battery door on these models just hooks under a wire next to the battery hole. They can pop off rather easily as they are a small piece held in place by a spring, essentially.
You can often find the part on ebay for a few $ and snap it in place yourself. The same battery door is used by the XTsi, HTsi, STsi cameras.
Its very possible that you did not lock it properly the last time you put in new batteries. Hold the door down while you turn the quarter as you lock or unlock it. Otherwise the pressure of the battery spring will prevent a good lock.
LightspiritPhotography.com
Posted on Jan 01, 2010
  • 102366 Answers
SOURCE: Need battery cover door for Minolta Maxxum STsi Maxxum 35mm
http://uscamera.com/1min040.htm
Posted on Jun 14, 2010
Camera won't take pictures.
Go into the settings and select Clean CCD. It should be under the blue menu. The shutter curtain has a tendency to stick on this model. There was a recall on them way back when they first came out. 1a53cc1b-6da0-4b38-942c-78caadf51633.gif 1bcf9dee-9615-448f-a170-16ef0e446320.gif
Aug 18, 2014 | Konica Minolta Maxxum 7D / Dynax 7D...
When I install the battery in my 7000i it makes a noise the screen has two lines appear but the camera will not turn on.
I had a similar problem with my 8000i. Parts are getting scarce for these older Maxxums, but you can still get it repaired. Unless you are emotionally attached to this 7000i consider replacing it. You should be able to find another on Ebay for a decent price. You might also consider the subsequent generations which offer better AF performance. The 650xi, 700xi and 800xi are all good cameras and available on Ebay. Lighter versions like the Maxxum 70 and the XTsi are also available. The last of the film Maxxums was the single digit 7. It is generally regarded as the best of the Maxxum series, but still sells on Ebay over 150.00 typically. These subsequent models will take all your maxxum lenses and flashes. These newer models offer many other features and often less weight to carry around.
lightspiritphotography.com
Nov 12, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Trying to use a Phoenix 500mm telephoto lens and the shutter won't release
Some longer Tele lenses extend into the camera and prevent the mirror from moving up on some models with larger mirrors. One solution> get a 1.4 teleconverter It will add some space between camera and lens. Two solution> buy another Maxxum body on Ebay. Some Maxxums can be bought very cheap.
Oct 08, 2009 | Minolta Maxxum 400si 35mm SLR Camera
When I look through the viewfinder, everything is dark....
Oct 04, 2009 | Minolta Maxxum 400si 35mm SLR Camera
Minolta SLR Lens on Sony - Does it work.
As I understand it, Sony bought Minolta, lock, stock, and barrel. Theoretically the lenses should fit and may work on manual, but I'm very sure they will not totally work on sony digital cameras. I wouldn't even try to fit them as the autofocus system on the camera may be damaged.
Mar 22, 2009 | Tokina AF 100-300mm f/4.0 II APO Telephoto...
When I look through the viewfinder of my camera I see blue streak
Mar 01, 2009 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Subject too dark in viewfinder
It sounds like the infamous aperture control problem. I had mine fixed by this place:
http://www.garryscamera.com/
They had it for a couple of weeks, and when I got it back it worked perfectly.
Mar 04, 2008 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Can't see whole image thru viewfinder when len is on
Your camera either has no focusing screen or the screen is dislodged. Remove lens and look above the mirror : looks like frosty glass.
Jun 05, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Mode switch
my dimage z5 and see alot of problems on ebay the net ....anyways being a tech for 25 years the cover came right off and u can see the switch is surface mounted. there is supposed to be a plastic lever coming out to manually engage to outer switch but missing ...upon closer inspection i could see alot busted up chards of small plastic ...the insideof the switch was completely ruined for bits where falling out...its just stuck in main veiwfinder. cant find the part itself anywhere on net. heard sony bought out minolta. my only bet is buy a broken camera with different prob. on ebay. Larry
Jan 26, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Minolta Maxxum 5 / Dynax 5 35mm SLR Camera Logo
184 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
