Question about Toshiba TE2100 Notebook
No power i comletely isolate the hardware, the memory, dvd room, processor,battery... but the the result is still the same,,, but i connect the adoptor to the dc in, one led indicate the symbol ac plug,,, what kinds of problem is this?
  • shriv Dec 05, 2007
    I have the same problem. This only happened yesterday. I booted the computer and when the OS had loaded, put a disc into the CD drive. As soon as i did this the screen went blank and the power cord led began flashing. It has been flashing all night.
I had the same problem, basically as you said if you took apart the laptop, and put it back together and your sure you didn't screw anything up, unplug the cord from the laptop, and take out the battery wait 1-2 hours, more if necessary. DON'T plug the battery in, and just plug the AC in and try and turn it on. Hope this helps.
Posted on Jan 02, 2008
Laptop asus K70 only green lights and sound of harddisc and fan
Do you get bios beeps when you remove the memory all together? If no, then I would suspect processor or motherboard failure.
Feb 13, 2015 | ASUS Computers & Internet
My acer pc is not booting properly
there maybe faulty installed hardware on your PC. remove those hardware like sound & video card (if any), PCI modem, CD/DVD ROM, etc. turn on your PC without those hardware & if/ there's nothings change?..it means that there is no wrong with your PC's hardware. turn the PC off, re insert IDE & power supplies cable of your hard disk drive to make it sure that the HDD is properly connected & being detect by the system. remove the memory card and clean or wipe the connector surface of the RAM with tissue paper. (change new memory card if needed). check the mother board C-MOS 3 volts battery if it is volts sufficiently .turn your desktop on & wait for good results.( Reformatting your OS is also recommended.)GOOD LUCK!
Jul 09, 2014 | Acer X193W LCD Monitor
HP Pavilion m7330n: Possible corrupt bios, solutions anyone?
what OS? is this XP? with SP3 or not? needs it. if XP.
you never need to delete old hdd, drivers ever.
reg booster?
would not reboot. the HDD fails>?
its not really BIOS, corruption at all,
if the CMOS battery is above 2.9v then no corruptions happen.!
the ROM part will not corrupt but the ram part can , easy, Battery.
check this battery any time bios forgets things this battery is the
no forget feature (CMOS NVRAM battery backup)
Bios can boot to any dvd, or cd, if you plug it and and select it.
BIos can boot the HDD, or SSD, or USB stick. and more, F9 key?
never use reg booster, avoid it like the plague,
any reg modifying programs are nothing but trouble. !!!
m7330n circa 2005. a desk top (or media center) Athlon 64 X2
so what DVD are you installing,
Sata, or PATA
tell what you have and why you need and adaptor,(btw i have them all here, from you name it ,to what eva.)
the HDD is SATA.
but what is the DVD jacked into?
dvd drives come in;
PATA
SATA
USB
what is yours?
May 06, 2017 | HP Pavilion Media Center TV m7330n...
I installed new mother board M2N68-AM Plus. Unfortunately, the it won't turn on.
Hi there! Welcome to FixYa!
For you to further isolate the problem, you may need to follow the following steps.
First, check your power switch header if it matched the cables on the motherboard. check also the power cable for both ATX power (20 or 24 pin) and CPU power if they are firmly attached.
Second, run your system on a minimal hardware (power, processor and memory only) you need to remove Video Cards or other add-in cards if you have any and just run the system using onboard video (VGA)
If all else fail, then check individual hardware. (no need to check this if you are sure that they are working, but for the sake of isolation then you must.)
(1) Isolate the motherboard Check if it will work using other power supply (2) Isolate the power supply.
Check if it will work using other computer's motherboard (3) Isolate memory
If you are using 2 or more sticks or RAM, then try them one at a time. If all else fail then you may need to contact the vendor for possible RMA.
Sep 03, 2011 | ASUS M2N68-AM SE2 Motherboard
My problem with the Gigabyte GA-8I848P-G Motherboard is when i press the power button I do not hear the speaker beep I also do not see the display on my monitor screen after a few seconds my cpu is...
Hi, what you have not tested for isolation is your power supply, re-seating of processor for 20 minutes, cmos clearing or battery removal and mother board swapping. If all your isolation seems futile the worst is the mother board.
Jun 22, 2011 | Gigabyte GA-8I848P-G Motherboard
My hard drive clicks and the moniter turns off
Hi, you can isolate that problem to see what is the defective part;
1. Remove the hard disk connection from the board and its power then re-start the PC.
2. If the PC powers and initializes, then you can prove that the defective is the hard drive. If the same problem that it shuts down then. the next target is the power supply. If you change the power supply and it turns out success, then we have solved the problem, if not, next thing is,
3. Turn off PC, remove the battery/clear cmos, the memory and the processor for 20 minutes.
4, After 20 min re-install the battery, memory and processor. Without the hard drive when starting, lets see if it will boot without the O/S.
others, when you say the monitor turns off, does the CPU still working or not? Isolate also the monitor by powering it on and not attaching the communication cable to video port, lets see it the monitor itsel display by its internal video logo to be sure it is okay.
Jun 22, 2011 | Computers & Internet
When I turn on the PC, the fan on the CPU spins and the system turns off. This sequence takes less than a second. I replaced the power sullpy but nothing changed. The system does the same thing.
Hi, Lets try this to isolate the problem.
1. Hold down the power button just to check if the power button switch is not the one defective, if it continues with initialization then switch might be defective,
2. Second isolation was the power supply, since you had changed it already we proceed to next step,
3. remove/reset the cmos battery, the memory and the processor for 20 minutes and other cards in expansion slot.
4.After 20 minutes install the battery, memory and processor and video card. If it has the on board video, use it first before using the video card in expansion slot if any.
5. Power on the PC.
6. If still the same our last resort of problem would be the mother board itself.
Jun 21, 2011 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
Toshiba a50 specs
hi
if you need the specs for the toshiba a50 here they are. hope this helps please let me know
Motherboard chipset
Intel 855GME
Centrino
Yes
Processor speed
1.5GHz
Processor
Pentium M
Memory/Storage
Amt of RAM
256 MB (max 2048 MB)
Hard drive
40 GB
Optical drive
DVD/CD-RW combo drive
Connectivity
Ports
2 x USB 2.0, FireWire, Ethernet, modem, VGA port,
parallel port, microphone and headphone audio jacks
Bluetooth
No
Infrared
No
Modem
V.90 compliant 56K modem (V.92 ready)
Built-in devices
Type II PC Card slot, 802.11b/g wireless LAN
Wireless LAN
802.11b, 802.11g
Webcam
No
Display
Graphics hardware
Intel 855 GME integrated graphics controller 4x AGP bus
Amt of video RAM
16 - 64MB shared memory
Diagonal screen size
15 inch
LCD technology
Active matrix TFT
Screen resolution (max)
1024 x 768
Multimedia
Remote
No
DVD/MP3 without bootup
No
TV tuner
No
Sound hardware
16-bit stereo SoundBlaster Pro, Built-in stereo speaker
with SRS TruSurround XT Sound Technology
Jacks
mic-in, earphone-out
Software
Operating system
Win XP Pro
Software included
Microsoft Office OneNote 2003, InterVideo WinDVD, Sonic
RecordNow! CD/DVD Writing Software
Chassis
Weight w/battery
2.8 kg
Dimensions
338 x 274 x 38 mm
Power
Supply
Battery type(s) included
6-Cells Lithium-Ion
Mfr-claimed battery life
4 hours
Feb 11, 2011 | Toshiba Satellite A50 Keyboard
Aces Aspire M1640 desktop-pc starts but the monitor says NO SIGNAL. Tried various monitors and videocards without result. Can't find what mainbord is in it to have it changed. Regards, Toine
black out can be caused by series of things. Power supply is one. Second is the motherboard, memory and the processor aside from the video card. Motherboard and processor can be isolated,first is to remove the rest of the devices such as hard disk and cards and memory. Beep sound means your board is still doing fine. Re install all the devices and power on again. Good luck
Sep 12, 2010 | Acer Aspire M1640 Refurbished Intel...
1111111111111111111111111111111111111111
THE BATTERY FOR THE CMOS IS PROBILY THE PROBLEM 3-6V BATTERY PACK PLUG IN OR OPEN THE CASE ROUND DISC SHAPE SILVE IN COLOR SHINNY + PLUS SIGN ON ONE SIDE WITH NUMBERS AND OTHER SIDE MY BE BLANK,
BATTERY PACK BAY AT ANY COMPUTER STORE RED BLACK WIRE WITH PLUG ON ONE END AND THE OTHER END WILL HAVE BATTERY.
ON THE MOTHERBOARD WILL HAVE A 2-3 JUMPER ON IT IT MY SAY BATT. 1 HOT,
2 GROUND, 3 GROUND.
ALL MOTHERBOARDS ARE DIFFERENT
IF YOU KNOW THE MANUFACTURE THAN GO ON LINE AND TYPE IN MOTHERBAORD MANIFACTURES NAME AND FIND THE NAME OF ALL MOTHERBAORD MANUFACTURE LISTED AND THERE WEB SITES FOR MORE INFORMATIUON.
ROD
Jan 23, 2009 | Compaq Presario 5000 PC Desktop
Toshiba TE2100 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
