Question about Seagate 1 TB SATA II Hard Drive
Harddrive has no Total size and Free space on my windows explorer
"Harddrive has no Total size and Free space on my windows explorer"
my 120 Gbytes Seagate Hard Drive can be detected but shows nothing when i try to retrieve my files. just wondering, where did all my files gone???? estimated 10 gigs of files.....gone.
Can anyone solve this???? thanks
  • CyberWolf May 31, 2009
    for crapiemael : I didnt changed anything for a year now.
    for ksjon : there's a drive letter BUT....no TYPE, TOTAL SIZE and FREE SPACE
    chkdsk wont work, I already tried that before including the dismount first before performing chkdsk....actually, this harddisk has a slave a 120 Gbytes and both of them have the same problem.
  • Crap Iemael
    Crap Iemael May 11, 2010
    Have you changed motherboard or hard drive controller?
  • 39 Answers
Yes, probably this can be solved.
does the harddrive still have a letter assigned?
if so. go into command prompt (start->run->type"cmd")
when the black window pops up write:
chkdsk x: /r (where x is the letter assigned to your 120gb disk)
please reply if your harddrive doesnt have a letter assigned.
Posted on May 29, 2009
320gb seagate hard drive showing only 2gb
total space 2 gig or free space 2 gig?
go to my computer right click on drive and report back what the balance of the drive shows for each color
May 24, 2012 | Computers & Internet
My brand new seagate hard drive is showing on 120 gb space on partition time?
it means your hard disk have 120 gb capacity, you can make partition according to your requirement.
Apr 02, 2010 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
My computer can't detect my external harddrive..
connect the drive, go to disk management and check if the drive is there. change the disk letter.
Jun 23, 2009 | Seagate FreeAgent Pro 1TB External USB...
Trying to copy harddrive to another harddrive. want to move to larger drive. problem is optiplex gx260 convertible desktop only shows 1 harddrive in my computer. only a c drive shows up. the secondary...
To clone a disc , acronis true image home is a very good software . A free software based on it is available from seagate called as disc wizard but it will only work with seagate drives. about hard drive not being detected , try upgrading your bios . Some bios dont detect new higher capacity harddrives. Do tell what is your drive capacity.
Mar 21, 2009 | Dell OptiPlex GX260 PC Desktop
Low capacity problem
Mostly this is affected by match used to construct the drive geometry. The narrative below is courtesy Tiger Direct of Canada and is their copyrighted content.
When we ask our customers if an Answer is satisfactory, the requested rating is four diamonds for a thorough answer. Hopefully, you will find the below content achieves that mark.
  1. The way size is calculated and displayed.
  2. Any "Partitions" on the disk will change the total in a specific partition.
  3. Hidden files and folders decrease available space.
  4. Compression increases the apparent size, but not the physical size.
  5. Drives larger than the OS or Drivers natively supports.
hddsizescreen.jpgFirst, the definition of a megabytes (or gigabytes) is a unit of data storage capacity measured in 1,048,576 bytes (or 1024KB). The larger the numbers, the more apparent the size difference will be when listing the size as megabytes (or gigabytes) versus bytes. Actually, both numbers are correct. The noticeable difference is due to the 1024KB definition of a megabyte. This is why a 95.3GB hard drive can also be listed as having 102 billion bytes of total space. Just think of it as "round off" In the screen shot at right: The first number is the total number of bytes, the second number is based on the number of megabytes or gigabytes.
Second, some computers have a non-DOS hard drive partition that is used for features such as Save to Disk, Hibernation, or Recovery. This partition is not normally reported by the operating system, although it can be viewed using a disk partition utility. This is very common on desktops and laptops. NOTE: Partition information will be created or formatted automatically during initial system setup and a system recovery.
Third, by default, all system files are hidden and cannot be seen. This may adversely affect the reporting of available hard drive space. You can set your Folder Options so you view system and hidden files and folders, but do be careful as changes to system files can adversely affect your system.
Fourth, if you turn on Compression for a drive, it will increase reported free space and used space, but since compression is based upon the actual contents, this number is not fixed, but will change as files are added or changed.
Fifth, older operating systems did not support some of today's larger drives, so the total space reported may be much smaller than the drive specifications.
It is also worth noting that bad sectors are corrected by your operating system and can change the total drive space, free space, or used space as well.
So as long as a drive is reporting a value approximately close to the specification value, you can be comfortable that you received the right drive and that you are getting to correct data storage. Of course, tuning of your drive's partitions and options can yield optimal values, but this is not something for the average user to explore.
Jan 15, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
221 GB Free on MyBook - Error states not enough space for backup
It may be due to the file system.  If formated as FAT32 files larger than 4gb may not transfer.  Try reformatting as NTFS to fix the problem.
Sep 21, 2008 | Western Digital 250GB MyBook External USB...
Maximum size of hard disk supported
Hi Bijay.
Neither is at fault. Please click on this Seagate link:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=How_To_Install_and_Troubleshoot_ATA_Hard_Drives&vgnextoid=559e5b1142aec010VgnVCM100000dd04090aRCRD
Scroll down to: Partitioning the drive in Windows XP / Windows 2000 (for systems where this is the 2nd drive in the system).
Follow the instruction on the web site.
This Seagate web site will help you setup the Seagate 160 drive.
If you feel the drive is still at fault you can run Seagate’s SeaTools. Click on the next link:
http://www.seagate.com/www/en-us/support/downloads/seatools
This software will check the 160GB drive.
(Follow the online instructions for), SeaTools for DOS.
In a Windows XP system & using a FAT 32 & a cluster size of 16kb instead of NTFS. Windows will see the total size of the drive but can only access 149GB of drive space. 11GB of drive space will be used by the FAT. File Allocation Table. The FAT is windows guide to every cluster on the drive.
XP uses NTFS & sets each cluster to 4kb. This 4kb size lowers the total usable GB size & uses more GB's for the FAT. You're 127GB size may be correct for a Win XP system using a NTFS file system. The FAT is using 33GB of drive space as a locator for every cluster on the 160GB drive.
Help with understanding the NTFS file system: http://www.microsoft.com/windowsxp/using/setup/expert/russel_october01.mspx
Bijay if you are still having trouble understanding please post any questions here.
Mike
Aug 12, 2008 | Intel D845GLLY Motherboard
Seagate 160 gb capacity problem
the harddrive size is in another measurement system and the actual size of the drive is exactly what you are seeing 152.
here you can see how my disks show
894a905.jpg 160GB disk - 152,66GB
1000GB disk - 931.51GB
that is correct.
Jun 15, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Is the drive formatted as FAT32?
If so, and your backup is more than 4GB, it will not be able to write the file to the drive.
Open a Command Prompt (Start | Run | CMD) and at the prompt type:
CONVERT V: /FS:NTFS /X
Where V: is the drive letter of your My Book.
That will convert it to NTFS and it will be able to handle files larger than 4GB.
Apr 28, 2008 | Western Digital My Book Essential Edition...
Harddrive not detecting
hi there
the space is still there its just has not been partictioned. Goto diskmanager and you will see the other 60 gig that has not been partictioned, use windows to create a logical drive then format it then you will see the other 60 gig.
good luck
smeags
Jan 03, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Seagate 1 TB SATA II Hard Drive Logo
174 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
