Question about Apple 13.3 MacBook Intel Core 2 Duo 2.2GHz 2GB RAM, 250GB Hard Drive, SuperDrive - Black Mac Notebook
Mac book will not turn on.
Tried to restart mac book and it would not turn back on. i turned on my firevault but then decided to turn it off. Then i shut tdown the computer. This morning i tried to turn it on and a folder keeps flashing. I'm worried
  • 221 Answers
A flashing folder at startup means that the Mac doesn't recognize your system. This can be either a hardware or software problem. The hardware problem would be the hard drive, and the software the OS.
So these are the steps you should proceed: 1) Check your hard disk by using your install DVD (press the c key at startup), choose your language, go to the utilities menu and hit Disk utility. go to SOS tab and select your hard drive on the left. Click "repair volume" and check what happens.
2) reboot, if it does not recognize the system again, reinstall it using the "archive-install" option
Posted on May 29, 2009
My mac book is receiveing data but not printing
try uninstalling the printer drivers and install back in. restart your macbook and try to print.
Apr 30, 2013 | Apple Computers & Internet
My cannon sd1100 says to restart it, how do you restart the camera (i lost my book)
"lens error, restart camera". Except restarting (simply turning the camera off, and then back on again) rarely corrects the problem. Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 08, 2011 | Canon PowerShot SD1100 IS Digital Camera
I have no problem turning on my laptop but it gets stuck in the loading screen. The wheel under the Mac Book symbol is turning and everything seems to be running just fine but the system itself is stuck...
Hi This could be one of three things. 1. a corrupted file on your HD, or 2. the directory on the HD is corrupted, or 3 a failing HD
Try starting up from your installation DVD and then running disk utility. (Insert your DVD then shut down the Mac. Restart the Mac and hold down the C key until you see the Apple logo. Once you reach the screen that asks which language you want to use, select English and then from the menu bar chose disk utility and repair HD)
If you get a message to the effect that disk Utility cannot repair the disk, run it one more time. If you still get the message then you had better locate a service centre.
Sometimes letting the installation run its course and overwriting the existing system will fix it. In this instance, you select the archive and install option, otherwise you will erase your files as the HD will be wiped.
I hope you have your files backed up.
May 02, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
WHAT TO DO WHEN YOUR MAC BOOK PRO FROZEN AT THE START UP SCREEN ???
Get your Mac OS DVD out, restart the machine with the disk in your optical drive, and after you hear the famous mac chime, press and hold the C key while it starts. When you reach the install window, don't install but rather open the Disk Utilities App and run a verify of your hard disk, also repair permissions. Then restart as normal. This should get you back to operation.
Dec 14, 2009 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Frozen Mac Book now with blank screen and 3 beeps
Pull your ram cards and restart... see what you get. Then restart WITH them... you may just have an unseated ram card.
Nov 17, 2009 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
My mac book will turn on but it wont load up
Clicking sounds are usually the hard disk drive going bad. Replacing the drive is not for the faint of heart on the Mac Books.
-=/ Daft Tech /=-
Sep 29, 2009 | Apple MacBook Mac Notebook
Can't install mac osx 10.5.7 combo update on 10.5.2
The 10.5.7 update sometimes does several automatic restarts - depending on the mac and the previously installed OS version.
In my opinion the 10.5.7 update has been the strangest I have done.
Try this.
Hold down the power button for about 10 seconds. The MacBook should now be off - but it may restart automatically while flashing the sleep light at you - and make a long beep noise. Don't worry if that happens just let it do whatever it does. Watch the screen and follow any prompts that come up.
If the MacBook did not turn itself back on, hold the power button down again for about 10 seconds. What happens now?
Don't press any other buttons unless the computer tells you to.
If however, you end up with another 3 hour wait then something is definitely wrong and you need to take it in to a specialist.
Jul 16, 2009 | Apple Computers & Internet
http://www.ifixit.com/Guide try this location for a guide
re-set your pmu 1. disconnect battery and power supply 2. hold down start button for 5-6 seconds 3. re-connect battery and power supply try to start if nothing might be your dc-in board/ has failed good luck
Mar 28, 2009 | Apple Computers & Internet
Download not complete Leopard not working
Try to boot your computer with the Recovery disc, by turning on your computer and slot in the disc, and pressing the C key. If it succefully boot in, try to restore the Mac software.
Feb 06, 2009 | Apple MacBook Pro Notebook
When I turn on my Mac Book Pro
The flashing folder with hard drive symbol is telling you that the computer cannot find a bootable system folder (operating system). This could be because the hard drive is working properly, or the operating system folder has become corrupted. Try booting up from the system CD or DVD that came with your Mac Book Pro and see if it can repair your hard drive.
Mar 16, 2008 | Apple MacBook Pro Laptop Computer with...
Apple 13.3 MacBook Intel Core 2 Duo 2.2GHz 2GB RAM, 250GB Hard Drive, SuperDrive - Black  Mac Notebook Logo
667 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
