Question about Electrolux Refrigerators
Freezes food in refrigerator side
The food in the refrigerator side freezes up and ruins food
  • 38 Answers
The problem should be with the temerature controller in the refrigerator. ask for the nearest technicain to come and fix it.
Posted on May 29, 2009
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Ge electra series side by side refrigerator keeps freezing food in my refrigator
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 17, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Whatever temp I put the thermostat on the fridge is freezing the food and ruining it - any suggestions?
heatman101
Mar 14, 2011 | Bosch Refrigerators
FREEZE FOOD ON REFRIGERATOR SIDE AND NO WATER ON DISPENSER, MIGHT BE FROZEN ON FILTER
heatman101
Feb 06, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile refrigerator PSS27SGNA BS....unit's refrigerated section keeps freezing food. even after we've adjusted the temp up to 36 or 37(recommended) it stays at 30 and keeps ruining the produce.
Check the air damper at the back top left of the fresh foods section to see if the damper door has broken and thus not able to close. It is electrically operated, but if it breaks, you can have your exact condition occuer.
Feb 03, 2010 | GE Profile¿ 26.5 Cu. Ft. Stainless...
Kitchenaid side by side freezes food in the refrigerator side
The damper between fridge and freezer is most likely stuck open.
Oct 02, 2017 | KitchenAid (KSRD22FKST) Side by Side...
Jenn Aire refrigerator keeps freezing food.
Your thermostat is faulty, pure and simple.
If the thermostat fails to do it's job, your compressor continues to run thus freezing your produce.
Feb 02, 2009 | Jenn-Air JCB2280HES Side by Side...
Refrigerators Logo
281 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
