Question about Smeg FR158SE 1 Compact Refrigerator
Thermostat replacing old thermostst but letter on old are c-h and ground on new its c-l and gound do i use the old H on the new l post
    President:
  • 2,559 Answers
Yes
Posted on May 29, 2009
How can I check thermostste on GE P7 before buying new one
wow much to high to pay? it can be checked for continuity with an ohm meter. u can buy cheap meters for like 5 bucks or so. are u sure their trying to charge them much for a thermostat? maybe they thought u meant something else? if its getting way to hot u have a bad oven sensor? it to can be checked with a meter. When ur thermostat goes out due to overheating , the oven will not operate. thermal thermostats are not resettable. oven sensor is located near the back along the wall it thin and may have a glass look?
Feb 12, 2015 | GE Ovens
How do i install a new thermostst on chrysler 300 2005
If this is the 3.5 the thermostat is where the lower radiator connects to the engine remove the hose and housing and replace the stat2_25_2013_7_23_42_pm.jpg
Feb 25, 2013 | 2005 Chrysler 300
I am installing honywell thermostat rth111/rth221 old thermostat has two wires that are yellow and need to know where to hook up
First things first. What type of system? Heat only, boiler or furnace? Central cooling.
Do NOT take wires off the old thermostat yet, or mark the color wire, to the terminal letter. Most times W,Y,G,R, terminals and maybe even a C terminal.
Your new thermostat should have the same letters. Sometimes they mix up color wire with terminal letters...... example (yellow wire to w terminal)
Also turn off power to equipment it is controlling. It is not high volts but you can short out the transformer. Hook uo wire color to same letter terminal on old stat, to new stat. Thats it.
Nov 12, 2011 | Honeywell Programmable Thermostat Heater
I need to locate my thermostat and change it
follow top rad hose to motor under housing where hose connects put new one in the correct way spring goes to engine side
Aug 05, 2011 | 1992 Plymouth Voyager
I need a diagram to replace the thermostat
I seriously doubt if you will find the diagram that you are asking for. The thermostat is very easy on most vehicles. Simply follow the upper radiator hose to where it connects to the engine. This would be the thermostat housing. The thermostat hosing is held on by 2 bolts. Remove the 2 bolts and remove the thermostat housing. The thermostat will be under the housing. Pull the old thermostst out and clean the gasket surfaces on both the engine and the thermostat housing. install the new thermostat and thermostat housing gasket and reinstall ithe thermostat and bolts. On some of the Dodge vehicles it is necessary to remove the alternator and/or power steering pump/ A/C compressor brackets to access the thermostat housing bolts.
Jan 22, 2011 | 1993 Dodge Dakota
Where is the thermostst for a 2003 buick rendevous located
in the thermostat housing. follow the top radiator hose to the housing, drain coolant from radiator, remove housing and voila ! replace with new thermostat and the rest is reverse procedure
Jul 05, 2010 | 2003 Buick Rendezvous
My 4.0 motor keeps over heating i change rariator water pump and thermostst and still over heats
these engines love to overheat, the original thermostat opens to hot, i always replace it with a ford 300ci 6L engine thermostat it opens at a lower temp and really helps to fix the problem, belive me try the thermostat it is the same diameter you only have to take the old oring off, hope it helps please rate
Mar 10, 2010 | 1998 Jeep Cherokee
Our 6 year old GE Fridge stopped making cold air. The fan and blower system still works, but it is just recirculating the air, not cooling it. Any ideas what that might be?
its likley to be the thermostat that stoped switching the compressor on and off if the compressor is not working there is no cold gas to cool the air try moving the thermostst up to full cold and see if that turns it on,,if it dont then fit a new thermostst first as its the cheapest part to replace
Nov 19, 2009 | Refrigerators
Looking for kelvinator n500t wiring diagram
My Kelviator fridge was freezing things solid, I was told that the thermostat needed replacement as we have no electrician availiable, I bought a new thermostat. I removed the two screw holding the thermostst/light control, took off the cover then made a diagram of the thermostat wiring. After I removed the old thermostat the light control sprung out of its position and I can't see where it should go. Can I obtain a picture of this.
richard.fuller@clear.net.nz
Oct 11, 2009 | Refrigerators
Newly installed Goodman GPG13 gas/electric package unit installed. Cannot get AC to cycle on. Unit produces heat at all thermostst settings.
new unit and old thermostat/wire? thermostat could be bad or bad thermostat wires. try putting in new of anything old. do this wiring practice with the terminals being the letters.
r- red (24 volts)
w- white ( heat)
y- yellow (cooling)
g- green (fan)
Sep 21, 2008 | Goodman Heating & Cooling
Smeg FR158SE 1 Compact Refrigerator Logo
71 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
ashburton
Mike
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
