Question about Lexmark Wheelwriter 1000 Typewriter
Ribbon Lift Eractic
The ribbon lift does not funtion properly. When you type it will jump up and stay up sometimes and other times will not move at all or sticks part of the way up.
  • Lexmark Master
  • 3,594 Answers
Try the unit without the ribbon installed if the mech. seems to operate properly you may only need a new ribbon.  If the condition continues you may need a new ribbon motor or board.
Posted on Oct 24, 2007
I installed the correction tape and it does not correct
Sounds like you have diagnosed the problem. Remove the correct tape and make sure that it's not the "sticky" type. (it will be hard to unwind if it is). Next try to manually lift the part that's supposed to move to see if it does. If it's sluggish (hard to move) put rags around it to prevent over spray and carefully clean all the moving parts with WD40. Make very sure that the WD40 does not get on any electronic parts! It will also mess up the platen. So, the more rags around the moving parts, the better. I used to work on IBM typewriters, and WD40 sometimes works wonders.
Jan 02, 2014 | Brother ML-300 Typewriter
I have loaded the ribbon on my IBM Selectric II and it doesn't move forward when I type on it. What did I not do correctly? I am unable to find the manual.
On the L. side of the cassette where the ribbon comes out there is thin finger sticking up the ribbon should be to the L. of it. Be sure you are turning the take up spool top nto the left. Sometimes the arm that swings into the ribbon and drives it gets gummy and won't move into the ribbon.
DickyO
Feb 03, 2011 | IBM Office Equipment & Supplies
Hi
Many brother type writers have two cam assemblies under ribbon holder. One operates the print hammer and the other operates the correction ribbon lift. sometimes they gets stuck or lock themselves up. turning on and off a few times will take care of it, but sometimes it needs to be worked on by a tech. If you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 08, 2010 | Brother EM-530 Typewriter
The ribbon won't advance on my IBM Selectric III typewriter. It's a new ribbon and it's on the outside of the shock wire and the lever is closed.
When the lever closes does the driver move to the right and aganist the ribbon, they get gummed up and stay opened. If this is a generig ribbon the top of the ribbon cassette will sometimes get in the way. If the ribbon isn't lifting you may be in stencil .
DickyO
Jan 29, 2010 | Lexmark Wheelwriter 15 Series II...
Nothing shows on the paper when I type.
Remove and observe the ribbon, wind the feedwheel to see if the ribbon if moving at all. Make sure that the correction tape is not in front of the printheel and installed properly. (electronic machines use non-sticky lift-off tapes).. Observe the hammer movement. The ribbon winder in the cartrige could be defective, the ribbon ffeed mechanism in the machine may need repair/replacement. Make sure there is a printwheel in the machine.
Nov 15, 2009 | Brother GX-6750 Typewriter
Swintec 4000; type writer ribbon will not stay on and when it stays on - nothing prints out, and the ribbon jams up
Hello- Of course the cheapest fix, is to try a second ribbon. If you need one we have them at FJAproducts.com
Most often the reason the ribbon cassette will not stay in place is due to not being seated properly. I am sure you have taken it out a few times and re installed it, but that is "normally" the only reason it "jumps up" one more thing to check in the lever near the daisy wheel. if it got bumped or unlocked the daisy wheel your ribbon will not seat properly.
Good luck.
Duane ONeil
FJAproducts
800-982-9989
Jun 09, 2009 | Office Equipment & Supplies
My typewriter doesn't type..won't display letters, but keys work.
alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
hth,
razors
Feb 27, 2009 | Brother Office Equipment & Supplies
Ribbon replace on ibm selectra 2
Lift top cover up.
Move the carrier to center of machine.
On the right hand side of the carrier there is a red lever. slide it to the left.
( it will lift ribbon arm's up & move the ribbon drive mecanisem out of the way.)
you now can lift the ribbon cassett out of the machine,
put the new ribbon in the machine.
there is a wire with a white plastic roller around it on the left side of carrier. make sure the ribbon goes on the out side of the that wire.
put the ribbon throuugh the lift arms
turn the knob on ribbon till the colored led is in to the ribbon cassett + a few turns of the black ribbon is around the spool.
slip the red lever to the right.
close cover & try typing
hope it works for you
Feb 08, 2009 | IBM Wheelwriter 30 Typewriter
Ribbon is sticking
You may have a wrong ribbon, sometime the small parts where the ribbon turn gear goes into does not match up correctly. Can you turn the ribbon manually by hand, if the ribbon does not turn it will not type....
Apr 17, 2008 | Brother ML-500 Typewriter
Getting back working
Did you lock the hamer in proper position? If entire ribbon lift asembly is up than the clutch that lifts it is locked up or broken.
Apr 08, 2008 | Brother GX-6750 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
55 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
