Question about Kenmore Washing Machines
No cold water on any cycle. hot water fine.
Kenmore 70 series heavy duty plus
    President:
  • 2,559 Answers
The cold side of the water inlet solenoid is not working.
Posted on May 29, 2009
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Kenmore heavy duty 80 model 110. rinse cycle at cold is down to a trickle, and seems to be lessening. Takes hour plus for a full water load if mixed alright flow for warm and hot
Your cold water line is clogged, kinked or the water valve solenoid is not opening all the way. First check the hose, then the screen on the valve for clogs. If none then replace the water valve assembly.
Dec 15, 2010 | Kenmore Washing Machines
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
No cold water, only hot
The cold water inlet line is either clogged (it has a filter screen in it) or the cold-water solenoid valve is malfunctioning.
Remove cold water line, check for obstruction -- if no success, inspect electrical connections on solenoid valve (where the cold water line attaches to the back of the machine). If valve is getting current, take it apart and clean it. If that doesn't work, replace the solenoid valve.
May 29, 2009 | Washing Machines
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
121 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
