Question about Dryers
I have a similar problem. But I will provide a little bit of history first. My dryer just doesn't get hot enough (approx 100 degrees just prior to the exhaust vent). Three years ago, I had the same exact problem and resolved the heating problem by replacing the (2) coils 694039 and 694040, a thermo fuse and a thermostat. Today, 3 years later and additional research, I get the impression that the coils may need to be replaced again. The burner will initially ignite for approx 2 minutes and then cycle on/off every 30 seconds from that point on. Do you think I'm on the right track? Any advised would be greatly appreciated. Thanks in advance, Jerry
  • 1 more comment
  • gracht May 29, 2009
    Thanks. That makes sense. I was cleaning the lent out of the backside of the unit and I may have damaged the sensor. I'll post my results after I test/replace the sensor.
    I'm sure the vent was at least partially restricted prior to me removing a lot of debris. After cleaning the unit is when the problem began. And your correct, it is gas.
  • Collegeless May 11, 2010
    You said burner. So I am assuming this is gas?! Sounds like you vent is clogged up because the unit is short cycling. If the vent is clear both the duct in the unit and the vent pipe to where ever it leads then I would say your flame sensor is not operating correctly
  • 864 Answers
If the gas cycles on and off I do not think the coils are a problem.  Sounds like the flame sensor is not working correctly.  The flame sensor keeps the gas valve open after the ignitor shuts off.  Then the temperature sensor shuts off the gas when temperature limit is reached.  When the dryer cools down the gas cycle starts again (usually much more than 30 seconds).
Posted on May 29, 2009
Air conditioner electric circuit
Try disconnecting battery for two minutes to reset the system. Then start the car and check a/c operation.
Dec 22, 2013 | Oldsmobile Cars & Trucks
When it's very hot, the cold air doesn't stay on long enough. It's fine in 80 degree weather, but it's 100 degrees now, and my little place is an oven, even with the thermostat set at 60...
This sounds like a low voltage problem .. you can check all your connections AFTER you shut down the power and tighen them all the way back to the breaker.. When electrical demand is high it is common for voltage will dropp. Hope this helps
Jul 23, 2011 | LG Goldstar WG6005R Wall/Window Air...
I a have a kenmore 417 dryer that is not heating I followed the steps
Check to see if the electrical coils are glowing or not...... they are located right behind the cloths drum. (sounds as though they are NOT heating up) In order to see these coils...... first, remove all the cloths from the drum. second, while the dryers door is open 7 the drum is empty look all the way to the rear or the metal drum, it has a flat back in which you will notice there are quite a few holes. During the next step you will want to watch these holes as we check to see if the heating coils are lighting up (they will glow like the heating element in your oven... or burners on your stove top as they get hot.... ORANGE IN COLOR IS WHAT YOU WANT TO SEE) Now.... with the dryer drum empty & the door OPEN..... you will find a small pushbutton located somewhere around the outide of the drum opening thats activated (pushed in when you cose the door), depress this little button and hold it IN (this is tricking the dryer into thinking the door is closed... but its not, your holding the button NOT the door.... luckly the dryer isn't smart enough to know this) You must continue to hold the button in till the test is over.... if you let go it will IMMEDIATELLY STOP the dryer! Now, push the start button located on the console like you normally would do so during normal operation (it is recommended that the temperature be set to the HIGHEST SETTING during this test). As the dryer starts and the drum turns.... watch those holes located in the back of the drum! It takes a minute for the coils to get hot enough to glow so give it a few minutes before giving up..... after 3 minutes an ORANGE GLOW should appear through those little holes. The glow you see is the coils getting hot like the element in your oven. If after 3 minutes..... NO ORANGE GLOW can be seen through any of these holes..... the heating element needs to be replaced (this is a common problem & is usually inexpensive to replace..... $15 - $20) Replacement heating elements are available at most appliance stores..... remember to write down the manufacturers name, the dryers model number, and serial # prior to going to the store for a replacement. You MUST provide this information to the dealer for proper replacement parts! Once you've got the new heating element (it will look similar to a really long spring) you'll be Up & Running in No time!!!!) Just follow the instructions which are usually provided by the manfacturer to properly replace the broken element! Hope this helps...... GOOD LUCK!!!!!
May 15, 2011 | Kenmore Dryers
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
My dryer Mode LEQ2152eso is getting very hot in about 15 minutes. Approx 120 degrees on the right top side. Hot enough that you cannot keep your hand on it.I have cleaned the lint filter and remove the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 23, 2010 | Frigidaire AEQ7000ES Dryer
Can i use the tumble dryer in an unheated outside room
Good day,
No reason you can't use it. No harm to the dryer except.......
Domestic appliances including dryers, and refrigerators were designed to work in an environment comfortable to the inhabitants. I.E. minimum of 65 to 70 degrees.
For example, the dryer takes air in from the rear, and heats it to approx. 140 degrees. No problem if the air is entering at 70 degrees, a rise of 70 degrees.
If the air enters the dryer at 35 degrees, it would have to raise the temperature to 140 degrees, an increase of 105 degrees.
Questionable if it could do that.
The down side would be if you used automatic to dry. The timer runs only when the heat cycles off, and if it doesn't, it would never quit running.
The solution would be to set it on time dry and adjust as needed.
Easy enough to adjust to.
Worth a try. No serious problems other than that continuous running situation.
Thank you for using FixYa
Dec 29, 2009 | Dryers
T700 Dryer Won't heat
not turning off, is caused by a small stepper motor attached to the back of the timer, that actually moves the timer (if a mechanical knob, my memory for obscure (sorry) models isnt perfect) they fail and are replaceable, separately to the timer, or the timer can be replaced with a rebuilt one, at approx the same cost as buying a stepper motor,
No heat is caused by the failure of a thermal cutout(thermal fuse overtemp cutout or any of a dozen other names) a small device like this 5850e1d.jpg or this 4947033.jpg screwed on the ducting between the fan housing and the exhaust, with wires to the terminals.
when you stopped the unit while it was very hot, heat built up enough that the thermal cutout melted. test with ohmmeter or bulb and battery, no conduct -replace
Notes
There are only a few cutouts common to most dryer models the local parts guy will have one to fit, even if marked with a different brand name,
generic compatible timer available at local parts guy
saving a 100mile drive
Sep 09, 2008 | Asko T701 Electric Dryer
Gas dryer runs for 3 mins and then no more hot air
mjm_III1,I have the same problem and did what you did (replacing the gas valve solenoid coil). My problem is history.
Cheers!
Jun 28, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryer doesn't dry
no but are you sure your replacement parts are correct the cycle stat is usally running about 140 - 160 temps did you switch the high one and the cycling wires or parts?
May 12, 2008 | Dryers
Dryers Logo
115 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
