Question about Sony DCR-TRV 460 Digital 8 Mini Camcorder Pal system
Playback automatically switch to LP Hi8 when all tapes have been recorded at SP
When I want to playback my tapes on my Sony TRV 460 they will not play. Althought all tapes were recorded on this camera set at SP when I start the playback the camera automatically switches to LP Hi8 and they don;t play. It worked perfectly then all of sudden started doing this....
  • 169 Answers
SOURCE: Camcorder won't playback most Hi8 tapes
may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Posted on Aug 11, 2007
philipp
  • 217 Answers
SOURCE: Sony Camcorder playback problem
mechanical alignment! try to record for a minute and playback the result on another player/recorder, not on your camera, if the playback is not okay then your camera needs alignment, you need pro fix. You said that you've done manual cleaning already, maybe you dis aligned the mechanical parts accidentally, applying too much force on the mechanical parts of your small unit tends to bend, dislocate or move these parts out of alignment. defective videohead will never playback good video, and you said that it seems to correct only a few minutes of playback.
Posted on Sep 14, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Hi8 Playback Problem
Clean the tape heads and see if that makes a difference.  If that doesn't work, it could be the tape motor is going out.  Thats typical behavior when that happens.
Posted on Oct 07, 2008
welcomejee
  • 10594 Answers
SOURCE: Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Posted on Nov 24, 2008
quang123
  • 107 Answers
SOURCE: Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Posted on Dec 04, 2008
How do you switch tape speeds to LP on a Sony Handy cam TRV 240
You can set tape speed SP or LP in record mode only and can not change it in playback mode.
To set tape speed, turn camcorder in camera mode and go to Menu and set SP or LP in record speed option.
Jan 03, 2010 | Sony Handycam DCR-TRV240 Digital Camcorder
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Oct 07, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Setting the tape speed
Power up camera on Camera mode, go to menu, select camera settings, go to Record Mode and select SP or LP there. Now your camera is ready to record as per selection.
You can not change speed SP/LP during playback mode because its properties of signal set during recording.
Mar 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Sep 13, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Sony trv 460 camcorder and HC- 40 mini dv humming noise
The noise is probably the motor running. As long as it doesn't appear on the footage, it's nothing to concern yourself about.
Sep 14, 2005 | Sony Handycam DCR-HC40 Mini DV Digital...
Sep 14, 2005 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony DCR-TRV 460 Digital 8 Mini Camcorder Pal system Logo
67 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
