Question about Epson Stylus 1000 InkJet Printer
Epson stylus R 310 "general error" message
I have just got my printer back after having the waste ink pads replaced, I did print 1 CD label & then colour bad on next so I replaced with Epson cartridges & printed another 12 or so, next day I changed cartridges to generic as didn't need best ink.  Tried to do CD's - the tray kept ejecting with message "not set correctly - reload & press maintenance button"  - I then tried to print on paper but the paper fed in & then I got message "paper jam etc.  Tried all I could think of, turned off & on numerous times, checked all - next got General Error,  told by friend  to hold power/maintenance/stop & get LCD screen message -
Also have removed far left ink pad, washed/dried/replaced
Hope you can help,
  • 382 Answers
Those generic refills are not worth i, plus they may void the warranty. Try removing them and cleaning the little circuit board sensor. Make sure leaked ink hasnt covered them.
Posted on Oct 23, 2007
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
Message "Service required. Parts inside your
You'll probably find that that the print head is worn out (according to Epson) and it needs to be replaced. It's cheaper to buy a new printer.
Mar 13, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
Probably the waste ink tank is full.Try to do this:
First of all download to your C drive. Run indoreset.bat, then follow the instructions.
After that right click AdjProg and select properties. Go to compatibility and select Windows XP.
Click OK at the bottom then right Click AdjProg and select run as administrator (if you have this
option). When working accept the agreement and go to
1. Particular adjustment mode,
2. Then waste ink pad counter,
3. Click Check
4. Tick both boxes.
5. Then initialization.
6. Then it's done.
Oct 16, 2009 | Epson Office Equipment & Supplies
Waste pad ink replace error in Epson Stylus Photo RX610
You can go to, and see if you can download the service manual from there.
Aug 19, 2009 | Laser 3115cn All-In-One Printer
Printer has ink BUT has stopped printing
It is your print head, not ink cartridge
It is reasonably easy to change yourself - google for Stylus C70 printer head
Aug 05, 2009 | Epson Stylus C70 InkJet Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset, Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
General error for epson stylus T10
green & red light blinking cant print epson t10
May 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
Reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
May 12, 2009 | Epson Stylus Photo 1400 Printer
Can't print with Epson stylus C67
It means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service
manual is available from a number of sellers - just Google "Epson C44 Service Manual". You will often find them for sale very cheaply on E-Bay. If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Nov 06, 2008 | Epson Stylus C67 Photo Printer
Epson Stylus 1000 InkJet Printer Logo
213 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
