Tried to update drivers. While updating .... I got a blue screen with a crash dump. Laptop shutdown and restarted. I chose the start windows in safe mode to check things out. I only saw one driver problem. Restarted laptop. It's moving slowly. Could memory be an issue? I've never upgraded the memory. My Acer 4520 displayed the "blue screen" and now it won't load up at all...the screen remains black. What can I do?
please remove battery and ac-power for a couple of minutes and then try to reboot the computer.
if it still doesnt work, shut it down, remove battery and ac. remove ram connect ac-power try to boot without ram remove ac power insert ram insert battery connect ac and try to boot again.
when the blue screen appear, please write down the top line that looks something similar to this:
IRQL_LESS_OR_NOT_EQUAL_ETC_ETC
and the line close to the bottom that says
STOP: 0x000021 (0x000+++alot of not needed numbers)
I have a samsung R519 laptop and the battery indicator icon has started to say it has 0% charge left...
(More)
I have a samsung R519 laptop and the battery indicator icon has started to say it has 0% charge left but I have fully charged it and the button on the battery says it has 100% charge. It seems to still be running but I now cant tell when the battery is low. when it is plugged in it says it is plugged in but not charging. Is there something I can do to fix this? CH
I have a laptop from Medion, where I got a problem with the touchpad. When I am in the windows...
(More)
I have a laptop from Medion, where I got a problem with the touchpad. When I am in the windows installation, the mouse works properly, but once it gets into windows, it constantly rightclicks. When i click on the touchpad and make a "markingbox" and releases the click, it pops up with the right click menu. When i tap the touchpad or click on the left click, it also right clicks all the time. But if i plug in an external USB mouse and right clicks and then leftclicks, the touchpad works with leftclicks, except then it cant rightclick.
presario cq50 i think may be stuck in hibernation ... i power on and i get power led and gharge led ...
(More)
presario cq50 i think may be stuck in hibernation ... i power on and i get power led and gharge led ( if i have charger in ) i have tried the HDD RAM and battery in another cq50 and all work fine i have managed to boot into windows a number of times and tried normal shut downs when i go to power on again im back to having leds and power but nothing on screen and HDD light flashes and then stays off it might be worth mentioning that when i managed to boot into windows i had the screen only half open so i could see my screen on my desktop while i googled for answers.. it may evn be something as silly as the hibernate pin being stuck but on cq50 it is hidden and although i did take this notebook to pieces i dont know where it is ( it is back together now and working as i managed to boot into windows after taking apart and putting together )
