Question about Phoenix Gold Octane-R 2.0:1 Car Audio Amplifier
It used to cut out for no more than 15 minutes, i thought due to a heat switch. Now it cuts out for a couple hours or even days at a time
Octane r 2.0.1 car amp randomly cuts out for a couple hours
    Novelist:
  • 131 Answers
Suonds like the amp is overheating, try turning the peak knob down about 1/4 turn and turn it on and see if it still does it, also see if the fan kicks in, if not that is normally easy to fix. any auto sound system store will have the replacement fan for it. if not take the fan out of it and take it to a radio shack, I know you are going to say " BUT IT IS A RADIO SHACK PART" well the main thing you pay for with everything is the names. the parts are all made over seas and are shipped here on the same container ships, all electronic parts are the same, all you are paying for is the name pioneer, sony, octain etc. they are all the same parts.... hope this will help you.
Posted on May 29, 2009
Refrigerator will not restart for a very long period of time after power cut.
there may be a faulty capacitor for the compressor motor
I would suggest a technician check it out as it should come back working within minutes of a power cut
there will be a short delay until the pressures even out as compressors have difficulty starting under pressure but you delay is extreme and needs checking out.
Apr 27, 2015 | LG Refrigerators
My Bosch Nexxt 500 dryer keeps tripping the hi-limit cut out.
Try checking your exhaust vent pipe for excessive bends and kinks, make sure there is good strong airflow coming out the exhaust where it exits the building.
Dec 12, 2013 | Bosch Nexxt 500 Dryer
My AC unit runs for 15 minutes the cuts off. Then there is no
Hello, if there is a condensate safety switch this will cut off power to the tstat if the comdensate line is backed up. Check the condensate line to make sure it is clear.
May 06, 2012 | Heating & Cooling
Could it be the fuel pump
i have a 2001 tracker 2.0 engine it did the same thing it run good but when i cut off i wud have to wait about 10 minutes and it wud start back up i put a new camshaft position sensor on it and its ok now the sensor cost me 289.00 dollars its easy to put on takes maby 5 minutes if u put that sensor on it u wont have anymore problems
Apr 29, 2012 | 2001 Chevrolet Tracker
My kenmore dryer 66512692 runs for approx. 10 minutes and cuts off. I can come back to it usually a couple of hours and it will run for another 10 or 15 minutes and stop. It will complete the Air Dry...
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
wer
Dec 25, 2010 | Kenmore Dryers
Dryer works and cut off
Sounds like heat over load switch is tripping due to lint build up , check around heating coils for lint build up if electric and make sure that you have free air flow from exhaust vent
Aug 05, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Peg Perego 800 Twin ATV - Only runs for 10 - 15 minutes at a time
Go ahead and charge it for 24 hrs. If it still does not run contact the repair department at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.htmlthese guys (and gals) help me out all the time.
May 31, 2009 | Polaris 800 Twin Sportsman Ride on Toy
Amp staying on but cutting out?
Hello Willb2396,
Actually you answered your own question in your paragraph. I draw your attention to your statement of:
"It will work for as long as I'm driving I will park my car, and when I turn it back on every thing will be working just fine and, then a couple minutes later, amp cuts out and won't hit for a couple hours or a couple days.... I have checked the sub multiple times and I don't see it being the sub or the amp"
You are correct it is neither the Sub nor the Amp. The problem is either your voltage regulator or your alternator. one and or the other is going bad.
Here is some advice check your ground wires, the buy a dual alternator kit, it contains the parts you will need to add an additional alternator to your car. This will provide the power you need.
I hope this helps,
Thank you,
Shuttle83
Nov 10, 2008 | Alpine MRP-M650 Car Audio Amplifier
Sound cuts off
OK,  That means there's some kind of crazy fault in the temperature sensing circuits. I'm afraid you'll have to take it someplace and have it looked at for a more thorough diagnosis.
Aug 31, 2008 | NAD C325BEE Amplifier
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Phoenix Gold Octane-R 2.0:1 Car Audio Amplifier Logo
99 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Matthew Spark
Matthew Spark
Mark Skinner
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
