Question about Maytag Atlantis MDG7400AW Gas Dryer
Dryer does not heat up
There seems to notheing else wrong- the dryer turns on it just wont heat up
  • jafeick54 May 29, 2009
    This dryer is 8 years old. Do you think it would be worth the money to fix either of these problems or should I replace the dryer. I don't want to put money into it if this is the beginning of mechanical issues. I will need to call a repairman. This is the first problem I have had. I apprecite your expertise.
  • jafeick54 Jun 01, 2009
    Thank you so much. You were right on with the diagnosis-it was an ignitor and I just paid the repairman 120.00. (much cheaper than a new dryer). I appreciate your help.
  • 864 Answers
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Posted on May 29, 2009
  • John Morganti May 29, 2009
    I think Consumer Reports figures typical dryer life to be about 14 years.  Based on that 8 years seems young.  I fix my own dryer so the cost is less but I have kept it running for 34 years.  My problem is that parts are becoming hard to find.  Parts cost for an ignitor should be less than $50, flame sensor less than that, and for a coil assembly about $100.  (I am trying to recall from memory and I have not bought those parts for several years but I have boosted the prices from what I remember.)  You could look online to get a better idea based on part numbers.  The cost of labor and time for troubleshooting will be the biggest cost.  Call around for some estimates and then compare the possible total to tthe cost of a new machine.  Don't forget to look for any energy savings or rebates taht will help offset the cost of a new dryer.
  • John Morganti Jun 01, 2009
    Great!  Please don't forget to indicate "Problem Solved" on the feedback page.
    Thanks.
Dryer wont heat. we have cleaned out all the lint, replaced the top thermostat and are frustrated. seems like it heats for a couple minutes then nothing.
Sounds like a bad heating element . Many dryers use a dual coil setup ( one coil for low to med, both for high heat). Also check your dryer discharge vent. A blocked vent will not allow the humidity to escape, which will result in your clothes not drying or taking multiple cycles to dry. Turn the dryer on, and find the vent discharge on the outside of your home and just hold your hand there. If you do not feel substantial airflow you have a blocked vent or blocked discharge tube. But from what you described, I would bet on either a bad heating element or failed heating element relay.
Sep 12, 2013 | Maytag Dryers
The pilot lights up, but when the thermostat is calling for heat nothing comes out. Basically the pilots on but the burners wont light.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | Dryers
My kenmore 80 series gas dryer heats sometimes, but other times wont heat. I can see the flame when it does heat. I replaced the thermostat. It seems to heat when it has been sitting unused for a long...
heatman101
Jun 25, 2011 | Kenmore Dryers
MY pye2300azw maytag dryer does not seem to be heating hot enough. can you suggest a solution please. Does it need a new thermostat, nothing wrong with the heating element.
Number 10 is the most likely suspect. The blower wheel tends to get wobbled out and won't send enough heat through the drum making it take twice as long to dry the clothes.themobilian_13.jpgthemobilian_14.jpgthemobilian_15.jpgthemobilian_16.jpgthemobilian_17.jpg
MORE HERE
Nov 02, 2010 | Maytag PYE4558A Electric Dryer
My dryer wont start i have power 220volt comming out of the outlet but nothing
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 06, 2010 | Whirlpool WED5300S Electric Dryer
Amana dryer wont work
I'LL let you know after the Amana repair man comes out.
Mine is doing the same thing and I can't figure it out
Jan 14, 2009 | Amana NDG2335AW Gas Dryer
Heating problem with stackable washer/dryer combo
check the duct work going out of the house if it is clogged the clothes wont dry. Birds love to build nest in a open dryer vent and if you have any bends lint will build up get these clean and it should get you drying again
let me know what you find
bill
Jan 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Electric Dryer
When you first start out with a cold dryer the dryer runs fine, then when you start a second load if wont?
It sounds like you motor is overheating, Your dryer probably needs to be cleaned, taken apart and all of the lint build up around motor removed. also so clean the venting and weather hood outside.
May 23, 2008 | Kenmore Dryers
Maytag Atlantis MDG7400AW Gas Dryer Logo
305 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
