Question about Frigidaire FEB27S5A Electric Single Oven
Stove flashed F11 and then locked the oven door
Well it started a couple months ago when I was cooking and realized that when I tried to use the bake option on my oven it would come on but only the top coils would turn on and the oven wouldn't fully heat up. Then a couple days ago when I was using the oven like I normally do nothing different the range started beeping and flashed F11 so I tried to clear the screen and then it started to lock itself. I tried unplugging the oven and then plugging it back in but the oven door will still be lock after that.
  • 6,784 Answers
HI, this is control failure. the logic chip set is damaged. this is causing these erratic commands and the unauthorized locking of the oven door. you will need ot replace the control in this case.(EOC/clock)
Posted on May 29, 2009
Stove door will lock and self cleaning will start when door is shut while baking.
do not think so . but I would call a repairman asap .
Oct 19, 2015 | Ovens
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
Shortly after pressing the Bake button it starts beeping and F3 shows on screen. In the past, it would do this a couple times and then begin to heat and be fine. Othertimes, it would just stop cooking in...
F3 error code is telling you the oven temperature sensor has failed on the oven. You can access the oven sensor from inside the oven. The sensor is a stainless steel probe about 1/4 inch in diameter and several inches long. Disconnect the power to the oven and remove the screws that secure the probe to the rear oven wall and you can usually pull it into the oven.
Jan 19, 2011 | Kenmore Ovens
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Time bake
No, time bake is what time you want the unit to start cooking and what time you would like it to stop cooking. Or turning the oven on and turning itr off. the timer on the unit will just count down.
Jan 12, 2010 | Ovens
F-10 code and continuous beeping
Your board is going bad
Aug 25, 2009 | Ovens
Uneven rising & baking in convection oven
I repair commercial cooking equipment for a living. When a customer complains about uneven cooking the #1 thing that these manufacturers ask is..... are they turning (180*) the baking sheets half way thru the cook cycle. #2 are they staggering the pans front to back & side to side. It's kind of a pain but, works for the commercial ones.
Jul 24, 2009 | Amana AEW3530DD Electric Single Oven
Accidently started clean, food inside,hit cancel,can't open
you would have to disassemble the cook top in order to get the the locking mechanism to manualy unlockit
May 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire FEB27S5A Electric Single Oven Logo
221 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
