Question about Microsoft ARC Mouse
Mouse issues arc mouse cursor jumps all over the screen making it nearly impossible to click on anything. Help!
  • jdo52 May 29, 2009
    i cleaned it...made all the difference in the world, thanks!!!!
    Problem Solver:
  • 17 Answers
You can go to : http://www.microsoft.com/enable/training/windowsme/mouse.aspx
That guide will give you directions to adjust your mouse properties. I am pretty sure your pointer speed is set to high.
Posted on May 29, 2009
    Problem Solver:
  • 6 Answers
This happens to me from time to time.  I'm guessing it's a laser mouse.  Check the window where the laser shines from; I'll almost be there's a hair or some other small object in it.  It may also be the surface you are using. Try cleaning it, and if that doesn't work and you use a mousepad, try using something else to see if it continues. I had a mousepad once that had a particular spot that caused the mouse to jump.
  • 6 Answers
Fairly old post but this answer might help someone in the future with a mouse issue I just had.
I came into possession of a used Dell laser corded mouse (one with a cursor adjust speed on it and a couple of side buttons which I haven't used yet).
It was pretty jittery (cursor jumping about 10mm in random directions) making it hit or miss to click on things and the buttons were erratic (when dragging with the left mouse button it would sometimes act as if I had clicked it or moved the scroll wheel).
I tried using it on different surfaces (multi-coloured mouse mats can cause issues especially if there is red on them) and blowing on the laser and into the housing with my breath and then "air in a can" in an attempt to clean it, all to no effect.
I moved the on unit cursor adjust speed to low and the Control Panel mouse speed to high and that kept the jitters to a manageable level but there was still the button issue.
Next thing that happened with it was the cursor started moving in a steady direction on its own. I stopped that by moving it but it started again (towards 8 o'clock both times) when I stopped moving it.
As the last act of a desperate man (prior to retiring it) I tapped the hand end of it firmly on a foam mouse pad a couple of times (once on each corner) and all the issues were fixed! Might have been some dirt in there or a loose connection. Still going strong after a week or so. Nothing wrong with it now - it is a good mouse - maybe it just needed to know who was boss lol.
Posted on Jun 19, 2016
Cursor jumping all over making screen scroling
If you're using an external mouse, make sure you have a single colour mouse pad as anything with different colours/lines on will cause the effect you're having.
You mention it's customised, could it be the customisation that's causing the problem.
Nov 21, 2013 | Apple Customized 15" MacBook Pro Laptop...
Unstable, jittery cursor
Lets give this a try: Click the Start button> click Control Panel> click Hardware> and then click Mouse. Click the Pointer Options tab, and then do the following: Uncheck the Hide pointer while typing box. Hope this helps you. Let us know either way. Make it a great day!
Apr 30, 2012 | Compaq Computers & Internet
Mouse cursor jumping problem, how to fix it?
A mouse is a vital component of your computer and allows you to control certain functions on the screen. When the mouse is not functioning correctly, it can be frustrating. There are a few different reasons why your mouse pointer may jump on the screen. You need to work through the possible causes and troubleshoot the problems to fix your mouse and get it working properly again.
1.
Examine the batteries if you have a wireless mouse and the cursor begins to jump. A low battery may be the cause. Change the batteries and check the mouse again. If it is still experiencing the same problems, proceed to the next steps to resolve the issue.
2.
Switch the wireless transmitter to a different USB port on another computer if possible. There could be problems with the port, causing the cursor to jump. This will resolve the problem if the issue is with the USB port. If the mouse is still jumping, move on to the next steps.
3.
Click on the "Start" menu in the bottom left corner of the screen. Right-click on the "My Computer" menu and click on "Properties." Click on the "Hardware" menu and click on "Device Manager." Locate the mouse entry in the list. Right-click on it and select "Update Driver" from the menu. Allow a few moments for the operating system to locate and install an updated driver for your mouse.
4. Remove dust or debris from the mouse pad and mouse with a soft cloth. Dust or debris could prevent the mouse from operating smoothly and cause the cursor to jump. Add a small amount of isopropyl alcohol to the cloth before you begin. Wait for the alcohol to dry on the pad and mouse prior to using.
5. Go to the "Start" menu and click on "Control Panel." Double-click on the "Mouse" icon and click on "Mouse Pointer." Decrease the speed of the mouse pointer. This could be causing the cursor to jump.
I hope you find it very helpful.
Thank you.
Aug 11, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Acer erratic and uncontrollable mouse clicking
use a external mouse preferably a PS2 mouse...after frequent use the mouse touch pad gets worn out and it does this joker work...even my 10 yr old DELL laptop had this issue after 4 yrs....
Feb 26, 2010 | Computers & Internet
USB mouse is jittery
Try the mouse on a different surface, also be sure you do not have any light directed at the mouse - this confuses the eye. Although no mouse pad is required for an optical mouse, sometimes it helps
Apr 01, 2009 | HP USB Optical Scroll Mouse
Jumping cursor
This is a really common problem thats not actually a problem.
Go to trackpad settings and make sure tap to click is off.
Most laptops allow you to tap the track pad to act as a mouse button, try it go to an icon tap the trackpad youll see that the icon highlights as if you are actually left clicking.
When your typing the trackpad senses your arm or wrist occasionaly and thinks your tapping the mouse, thus moving the cursor.
So go into trackpad settings and turn off tap to click.
Jan 19, 2009 | Acer Aspire 1690 Notebook
Jumping cursor when typing
Since you have a logitech mouse, lets just disable the touchpad. You should be able to disable the touchpad via one of these methods:
  1. Look on the top row of keys. You should have one that looks like a little mouse. If you do, hold down the "fn" key in the bottom, and press the key with the mouse on it. That *should* disable the touchpad.
  2. Go to the control panel, and find the keyboard and mouse settings. Digging through the menus, you should find a touchpad. You can disable it through there.
Steven
Sep 17, 2008 | Microsoft Windows Vista Ultimate Edition
A35-S159 keyboard problem
Try this first, Make sure the mouse cursor is further down the page or completely off the page you are typing on. Whith the problems of static electricity or stray energy if you are typing and go past where the mouse cursor is and stray voltage is present then the lightest touch of the glide pad or mouse could be interpreted as a click and your text will begin where the mouse cursor is.
Jun 05, 2008 | Toshiba Satellite A35-S159 Notebook
Jumping cursor
If you have a wireless mouse, you may need to replace the batteries inside the mouse. If it is a usb or ps2 mouse (wired), you can first try removing the ball from the bottom of the mouse and making sure you clean the rollers that are inside the mouse. Using a Q-tip works pretty good to remove all the dust buildup.
Second, you can go to the control panel, under printers and other hardware, click on Mouse, and make sure the slider isn't set on 'Fast'. Set it about half way between fast and slow for better control.
May 24, 2008 | Kensington Expert Mouse Trackball
Cursor jumps all over the screen
Try uninstalling and reinstalling the touchpad driver from device manager
Dec 03, 2007 | Logitech Wireless Access Duo Optical...
Microsoft ARC Mouse Logo
627 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
