Question about Brinkmann 810-8410-S Stainless Steel Propane Grill
The gas flow cannot be raised and a slight breeze puts out the fl
This is a brand new grill. brinkman 810-8410-s stainless
  • meo11 May 29, 2009
    thanks but my grill does have a blue flame and it does cook but I cannot raise the flame. It seems to be too low. Can this be altered?
  • 10,865 Answers
The new gas grills have a safety device built into the gas hose that can cause this problem until you get familiar with it. The flame on a gas grill should be blue. If you have a yellow flame it could be caused by a couple of different problems. First of all the burner might be worn out. If you have an older grill then you should inspect the burner to make sure that there are no cracks or holes and that all the burner holes are the same size. If you have a newer grill or burner, or your burner appears to be fine then the problem might be with the regulator. The regulator is a round metal object near the connector to your gas supply. Sometimes regulators get stuck. This can reduce the gas flow, make a yellow flame and keep your grill from getting hot. To solve a stuck regulator, turn off the fuel supply to your grill. Disconnect the main connector and open the grills control value. This will eliminate any pressure on the regulator. Sometimes this will reset the regulator, but sometimes they stay stuck. Take a small hard object like the handle of a screwdriver and give the regulator a gentle tap. Now you can reconnect everything and see how your grill works now. If you still have a yellow flame your propane tank might be low, the regulator may need replacing or you could have a blockage in the venturi tubes. So check your fuel level by pouring hot, not boiling water down the side of the tank. Feel along the side where you poured the water. The propane level is where the tank feels cold. If you have plenty of fuel, locate the venturi tubes. The venturi tubes are located along fuel lines right behind the control valves. These allow air to mix with the fuel before reaching the burners so they have a small open space. If that space is blocked it will restrict the fuel flow to the burner. Make sure it is clear of obstruction. If you have done all this and still have a yellow flame you may need to look at replacing
Posted on May 29, 2009
  • Joe Hogan May 29, 2009
    here is the link to brinkmann.net so you can ask them directly
    http://www.brinkmann.net/Customer%20Serv...
Have brand new 810-3330-s brinkman grill main igniter is receiving no gas, is there a screw to adjust flame?
BEWARE: DO NOT TRY SUCH HAZARDOUS TRICKS YOURSELF AS LOCATING A SCREW TO ADJUST GAS PRESSURE. CONTACT THE DEALER OR AUTHORIZED CUSTOMER CARE.
Mar 29, 2014 | Brinkmann Brinkman Barbecue Grill Gas...
We seem to be having the same problems as some of the others. Our sons bought this grill for my husband for Father's Day. I came assembled. There is a kink in the hose (the one that has to bend to...
Home Depot will not be able to help you with this. You should contact the manufacturer, Nexgrill, directly and see if they have longer gas lines as this seems to be common on this model of grill. There may have been enough complaints that Nexgrill has new lines available. This is also fairly common among all Chinese import grills that like to cut corners on costs.
Jul 03, 2011 | Brinkmann ProSeries 810-6330-W Grill
Brinkman gas grill won't start. Don't hear clicking sound. Hooked up new gas tank, but no success
Victor, are you sure you're getting gas to the burners after installing the new tank? You can try match lighting them to make sure. But, I suspect, that it's the installation of the new tank, that's causing the problem.
To test my theory, tune the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Ope the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, try lighting the burner that's farthest from the tank first and turn it to high. Did the burner light and does the flame height look correct? If so, light the remaining 3 main burners the same way. Did those burners light and the flame heights looks correct? If, so you solved the problem. Remember to always turn the tank valve ON VERY, VERY SLOWLY.
Hope this helped you solve the problem. Happy Grilling.
Jun 01, 2011 | Brinkmann 810-8410-S Stainless Steel...
BOUGHT A BRINKMANN 2545 GRILL LAST NIGHT. WE HAVE IT ATTACHED TO GAS LINE COMING FROM HOUSE. GRILL WILL LIGHT BUT IT IS A LITTLR FLAME AND THE OTHER BURNERS WILL NOT LIGHT?
If you have a high pressure 2lb LP Gas System feeding your house, you will need and inline regulator for you grill.
If you have Natural Gas, the grill will have to be converted to Natural Gas. You can do this by changing burner orifices. You can purchase them from Brinkman. That is, if Brinkman approves the change to Natural Gas. Some gas grills aren't convertible.
Feb 09, 2011 | Brinkmann Grilling
I have a new Brinkman grill and can only get a low flame and very little heat.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 17, 2010 | Brinkmann 810-2300-B Grill
I need instruction on how to put together model 8300 proseries Brinkman
Click on this Brinkman link for the manual you need. Scroll down to the 6th Brinkman model listed to find your model and click on it. You can then download this adobe file and print it up on your computer for free.
http://www.brinkmann.net/Customer%20Service/OwnersList.aspx?category=Gas+Grills
Have fun assembling it!
May 15, 2010 | Grilling
Genesis s310 stainless grill. Does not fully light.
Regulator is not bad, as I stated before new valves are designed to reduce gas flow if valve is opened to fast. This is so if grill catches on fire, the tank will shut itself off, thus propane will stop flowing causing fire to extinguish itself.
Dec 28, 2009 | Weber Genesis E-310 Gas Grill
Instructions on how to put a brinkman gas grill
It might be best to just contact Brinkmann's Customer Service Department first. They should be able to either send you a Manual with snail mail OR point you to a link where you can download a copy of the instructions needed. Good Luck!
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Jun 27, 2009 | Brinkmann Stainless Steel All-In-One Gas...
Brinkmann 810-8410-S Stainless Steel Propane Grill Logo
806 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
