Question about Northern Industrial 2 Hp Twin Tank Electric Air Compressor
Not pumping up to capacity, motor and compressor working fine,
The tank does not get up to full charge of about 115 psi. this is a four gallon, twin tank design. Oilless, compressor. My pressure gauge pumps up to desired psi directly off the compressor unit. check valve/
  • Samuel Charles Spriggs May 11, 2010
    I assume the motor is shutting off before the tank gets to 115 PSI -- is that correct?
    Have you checked the pressure switch? It should be set to come on at something like 90 PSI and off at 115 PSI. It could be that it's out of calibration and shutting off too soon.
  • 530 Answers
If your pump is shutting off before it reaches it's max psi. then you need to adjust you switch. Under the black case there are two adjustment screws. One is the high\low adjustment, the other is high pressure cut off.
The first will change when the pump turns on and off for your low psi setting and the high setting simultaneously.
The second will allow you to raise or lower just the high setting. There should be a diagram under the black cap to show which is which. Adjust the high side only and just a 1\4 turn then run the compressor and see if that takes care of the high setting.
Posted on Jul 29, 2009
I have a 2 gallon compressor , no air comes out?
Check if air intake is clogged.
Check if drain valve on tank bottom is open or closed.
Look at pressure gauge and see if pressure is zero.
Adjust pressure so tank will hold 80-120 psi.
Check air lines between compressor and tank to see if they are leaking. Listen for leaking air while motor is running.
Jun 24, 2012 | Campbell Hausfeld Air Tools & Compressors
Pressure switch adjustment problem...
I think I follow you... the adjuster over the large screw is used to set your tank pressure but also sets the cut-in/cut-off pressure. You have another regulator to control the pressure to and thru your hose but that doesn't insure that you won't exhaust the tanks supply and use more air than your pump can produce. It doesn't matter what pressure you set it at if your pump can't produce enough cubic feet per minute of air to keep up with your output. If your air use/output is within the pumps output, your idea will work just fine and you can set the hose regulator just below the cut-in pressure but Remember, even a little airbrush uses a lot of compressed air but sanders, grinders, sprayers and impacts use a Ton so don't try this without having somebody monitor the compressor periodically while you try it. It all depends on your air demand.
Apr 27, 2017 | Campbell Hausfeld G5396 7 Hp 60 Gallon...
My SS5 won't make any pressure. I drained the tank to around 10 psi to drain moisture out of the tank and it built the pressue back up to around 120 psi but won't build any higher. The shut-off point is...
Sounds like the pressure regulator has gone bad. That controls how much PSI your system is aloud to have. If this fails it will not fill to max capacity. I would replace that and all will work just fine.
Please rate
Jun 01, 2010 | Ingersoll Rand SS5L5 Ir Electric...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Valve on top of engine spews oily fluid
Drain the water from the tank, usually at the bottom of the tank, lowest point.... Be prepared for a flood!
Feb 11, 2010 | Astro Air Tools & Compressors
I have a model FP209501 Air Compressor 2 Gallon,
2 gallons is small to begin with u need to buy an in line pressure adjuster/regulator their a few bucks and can be attached to the paint gun or line and will keep the pressure at ur adjustment the regulator on the tank sets the tank pressure at 50 so when u us it will let it drop down to about 45 than start up to build the pressure up to 50 than shuts off than repeats it self the inline keeps pressure steady even if tanks are at 200 psi
Jan 18, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Hitachi twin stack problem.
You stated that the compressor started up fine. I'll assume it reached it's max psi then cut out. Then upon reaching it's cut-in psi the motor ran slowly for a few seconds, then kicked off. I also assume you mean check valve when you refer to the non return valve.
If this sounds about right then. The first thing I would do is bleed out all the air from both the tank and the pump supply line leading from the pump head to the tank's check valve. You can do this by simply loosening the fitting that attaches the line at the head or the check valve. Once done try running the compressor again.
The purpose of this is to check the unloader valve. This valve bleeds off the pressure that remains in the compression cylinder and the supply line up to the check valve. When functioning normaly it will bleed off this pressure once the motor shuts off. If it is not working correctly then when your compressor starts back up (once it is already been filled) the piston will be working against a psi close to the max psi.
If the problem reoccurs only after the compressor has reached it's max psi, then the unloader valve is most likely the problem. If however it will not start up at all even after a complete bleed then it has to be something internal to the pump and\or motor.
Please try this and let me know (or repost) your findings.
If it's the unloader valve I should be able to explain how to repair this valve.
Good luck.
Aug 11, 2009 | Hitachi EC119SA Twin-Stack Air Compressor...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Northern Industrial 2 Hp Twin Tank Electric Air Compressor Logo
293 people viewed this question
Top Northern Industrial Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Northern Industrial Air Tool and Compressor Expert? Answer questions, earn points and help others
