Question about Whirlpool Duet GHW9150P Front Load Washer
Won't start Just got our new washer today - hooked everything up, plugged it in...it won't start
After reading some posts on this site, we checked the power cord since someone else experienced the same problem. Whalah! Problem fixed - our cord was severed and one line inside the cord was also severed. Called the store where we purchased it and they are coming out this morning to switch this machine out.
What a great website!
Posted on May 29, 2009
3 Suggested Answers
  • 219 Answers
SOURCE: washer won"t fill with water
check your lid switch if its a top load
Posted on May 22, 2009
rickead1
  • 1998 Answers
SOURCE: door locked, won't turn on. won't reset
Remove the bottom panel which would give you access to the pump area if you look up along the side that the door lock is on you will see a cord with a loop on it pull this cord and the door would open. The panel must be removed in order to locate this pull cord. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
p.s if after you open the door and you were to leave the unit unplugged for 7 minutes if the error did not go away or if the door once again locked up you would have no choice but to replace the door lock assembly on the unit Thanks again Rick
Posted on Jul 04, 2011
Testimonial: "Good advice fast! Thank you so much for your time and expertise!"
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How to check starter
Hook up 12 Volt to it, if it is 6 volt hook 6 volts to it. Just take a set of jumper cables and hook up the Red side of the cables to the + positive side of the battery then take the other Red side hook it up ot the on bolt/nut post on the starter this is the positive side of the starter. Then take the - negative Black side of the cable hook the negative - battery post. Important here.... take the other en of black side of the jumper cable and just touch the case or ground of the engine.
When this happen, the starter will spin or smoke. What is really ******* this small single engine starters is letting it crank because it won't start. This heats up the commentators in the starters armature then shorting them out. When this happens it time for a new start. Only turn the start switch on for a few second then let the starter cool down, then try to start it for a few more second and then and then.
Now, if won't start in a few start up attempts, then coke the carb, make sure you fresh fuel, fuel filter is clean or a new filter, make sure air filter is cleanded or a new air filter.. etc. GB...stewbison
Sep 11, 2011 | Briggs Stratton 020273 Elite Series...
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
Washer won"t fill with water
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Whirlpool Duet GHW9150P Front Load Washer Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
