Question about Avanti WC54 Wine Cooler
Unit was leaking at rear coil, sealed the leak but know it needs freon. Can it be added?
Avanti wine cooler needs freon, it takes R134 but I don't know if this can be added? Does anyone know?
You will need a inline piercing Valve similar to one of these:
http://www.enalt.com/pdf/cdz/componenti/Valvole%20Perforatrici.pdf
This will give you the service port you need to access the freon line
Posted on Oct 19, 2011
  • 44 Answers
All fridges, freezers, coolers, etc need access ports added to them before any refrigerant can be added to them. Makes you wonder how they do that eh?
Posted on May 29, 2009
How hard is it to add freon to a wine cooler?
Don't attempt it, need special equipment, seek additional quotes but if it's leaking them there is a gas loss issue. You should never need to add gas to a fridge that is sealed in the factory.
Askntechnician why it needs a gas top up? It must be leaking from the pipe work. Adding gas wont solve the problem, you need to find the sauce of the leak to remedy the problem longer term.
Mar 22, 2014 | Whirlpool Furniture
Needs freon. where do i put it
Oh no. Most of these systems do not come from the factory with service ports that allow you to add R-134a. You will need to buy a clamp on piercing valve then add the refrigerant. The leak is most likely in the evaporator coil where the wine is stored, and the R-134a will leak out again soon. Replacement or repairing the leak will take care of the issue, also the weight in ounces of refrigerant should be on the data tag of the unit next to the model number. Try not to exceed the recommended charge.
Nov 09, 2013 | VinoTemp 28Bottle FreeStanding Wine Cellar...
The unit is a Breezeaire wine cooler. The evaperator is freezing up.
MOST LIKELY A FREON LEAK ALMOST 90% OF UNITS WITH FREON LEAKS DEVELOP ICE BUILD UP ON THE FRONT COIL, AND AFTER A PERIOD OF TIME IT GOES AWAY AND THEN UNIT RUNS NON STOP GETTING WARMER AND WARMER TILL IT HITS ARROWND 70 T0 72 DEGREES.
Oct 02, 2010 | Breezaire WKL 4000 Wine Cooler
How do you add freon?
adding freon is not the answer unless you can prove you have lost some. The unit is hermetically sealed so should not lose freon unless you have punctured the system and the gas has escaped. you will probably need a fridge expert to test and check over the system.
May 17, 2010 | Haier BC112G Wine Cooler
Wine fridge is leaking an oil substance... is this safe to use... or should it be fixed immediately?
If in the compressor or evaporator and condenser area, Yes this is serious and indicates a Freon leak that will damage your compressor, Sea Breeze
Nov 29, 2009 | Avanti WC3200BG Wine Cooler
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
How do I replenish the Freon in my Sillouette model DWC283BLS?
you legally can't unless you are e.p.a. certified to purchase the type of freon in the unit and you have the equipment to do so,by law you need to evacuate the sealed system,then pressurize system with nitrogen and a small amount of r22freon,find the leak,recapture nitrogen/r22 and repair leak,then recharge unit with correct amount of correct refrigerant it needs,the equipment to do so is very expensive too
Nov 19, 2009 | Danby Silhouette DWC512BL Wine Cooler
Can freon be added
Based on what you are saying, when someone says it's a "Throw Away" unit, that means that it is cheaper to buy another one than it is to have the current one fixed.
Now, do you have a specific that we can try to address and possibly do a repair to?
Let me know and Good Luck on your project.
May 09, 2009 | Avanti WC400SS Stainless Steel Compact...
Uline 2075WCS not cooling
Hi!! I'm a uline authorize servicer and yes the repair man is right. you have a leak in the evaporator..remember make sure to call uline ans see if you have warranty on your seal system of the wine cooler..good luck..
Jan 03, 2009 | U-Line 15WC Wine Cooler
Avanti WC54 Wine Cooler Logo
327 people viewed this question
Top Avanti Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Avanti Furniture Expert? Answer questions, earn points and help others
