Question about Hayward SAND FILTER, PRO SERIES
Hayward sand filter needs primed every time
I have had the pool for over 15 years. I just replaced the seal in the flow valve. every time I tern the filter off, the water in the lines runs back into the pool pushing any particals in the skimmer back into the pool. I have to reprime the filter pump when I turn it back on. The waste line is not leaking any water during filter mode and there are no visible leaks. What is wrong?
    President:
  • 1,489 Answers
The problem is a malfunctioning check valve. It'll be somewhere in the line on the pump output side. If it's not a separate fitting it'll be in the line, probably in an elbow.
Need further info, let me know...
Charlie
Posted on May 29, 2009
  • Chris Jun 04, 2012
    Charlie,
    I had the same issue after opening the pool last week. DE-3600 with 6 port valve. So you think it valve is wrong? Appreciate your early reply. Chris at
    cm9888@gmail.com
I have a Hayward s166t sand filter and no matter what setting I have it on tons of water is coming out of my waste line! This is my 1st pool and 1st sand filter!!
I used to work in a municipal swimming pool. 325,000 gallons!
It sounds like you have the sand filter on to clean if water is coming out of the waste line. That is called 'back flow'.
Basically, the water from the pool comes into the top of the filter and the muck settles on the top. You need to add Gypsum (Aluminium Sulphate) to the water which is a floculant. This makes organic material form into a layer on top of the sand. The flocculated layer further adds as a filter. You need to regulate the flow of water into the filter as too fast and you force sand into the pool.
When you clean the sand filter, you do a back flow. So by altering valves, you put the water from the pump into the bottom of the filter and the water lifts the muck and dirt off the top of the sand and discharges it to waste. It is important to also regulate the flow as too much will discharge the sand. That happened in our municipal pool and discharged 6 tons of sand in the space of 2 years.
your owners guide is here. Take a look at the pipes, valves and pump and work out where the flow is going to.
http://www.hayward-pool.ca/pdf/manuals/ProSeries-S166T-S166T1575XS-S166T1575XSN2.pdf
Jul 03, 2016 | Hayward Pool & Spa
Hayward 220T pool filter is leaking water; could it be the multi-port valve needs to be replaced?
if coming out of top where handle is yes if out backwash line yes make sure unions are tight also
Dec 30, 2013 | Hayward SAND FILTER, PRO SERIES
Installed new pro series sand filter model s244t. same size filter as we had before. bottom drain has been plugged and not in use. can prime pump basket and backwash with limited flow. same thing when...
check impeller may be worn might need replacing scuffing markers change orings too maybe bad seal on pump too push seal out with fingers try running vac on sucktion side of fittings some thing stuck in linerun hose thought it back wash and rinse not waste
Jun 12, 2011 | Hayward SAND FILTER, PRO SERIES
I dont kno how to operate to open the pool. Please help
You can go to the Hayward web site and download the manual and parts list. They also will trouble shoot basic issues over the phone. Here is the manual website: http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1_17009__I.htm
Here is the main page for help. You will need to register to get a live person. http://www.haywardnet.com/contactus/
Air leaks are the enemy here. Check all unions and valves. Also, if you are handy you can replace the impeller and seal on the motor. If you are getting sand blown into the pool, you will need to remove the sand and inspect the fingers inside the tank. Replace sand carefully so as to not damage fingers. If the pump will not stay primed, recheck for air leaks. That should be enough to get you started. Download everything and study it, then call tech support after you have tried the basics. Good Luck!
May 13, 2011 | Hayward SAND FILTER, PRO SERIES
How to open pool, fill sand filter with water?
I happen to have a copy of the users manual for this pool filter. These are the instructions for operating your filter.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
2. Depress Vari-Flo control valve handle and rotate to
BACKWASH* position. (To prevent damage to control valve
seal, always depress handle before turning.)
3. Prime and start pump according to pump instructions (be
sure all suction and return lines are open), allowing the filter
tank to fill with water.
WARNING: ALL SUCTION AND
DISCHARGE VALVES MUST BE OPEN WHEN
STARTING THE SYSTEM. FAILURE TO DO
SO COULD CAUSE SEVERE PERSONAL
INJURY.
Once water flow is steady out the waste line, run the pump for
at least 2 minutes. The initial back-washing of the filter is
recommended to remove any impurities or fine sand particles
in the sand media.
4. Turn pump off and set valve to RINSE position. Start pump
and operate until water in sight glass is clear—about 1/2 to 1
minute. Turn pump off, set valve to FILTER position and
restart pump. Your filter is now operating in the normal filter
mode, filtering particles from the pool water.
5. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten
connections, bolts, nuts, as required.
6. Note the initial pressure gauge reading when the filter is
clean. (It will vary from pool to pool depending upon the
pump and general piping system). As the filter removes dirt
and impurities from the pool water, the accumulation in the
filter will cause the pressure to rise and flow to diminish.
When the pressure gauge reading is 8-10 PSI (0.55-0.69
BAR) higher than the initial "clean" pressure you noted, it is
time to backwash (clean) the filter (see BACKWASH under
Filter Control Valve Functions.)
Apr 16, 2010 | Hayward SAND FILTER, PRO SERIES
Problem with vari-flo multipoer 1.5 and Hayward DE fiilter
You need a rebuild kit for the valve and possible a sand change. Sand should be changed ever 3 - 5 years or so depending on overall pool conditions.
The gasket inside the valve is out of place and therefore allowing water to leak out the waste port. Use a gokit to replace all the gasket/orings and you should stop the leak.
If the flow is still bad, inspect the sand and change it if necessary.
Jun 26, 2009 | Hayward SAND FILTER, PRO SERIES
Where can I get a seal for the flow valve on a Hayward s166t sand filter for a swimming pool
www.arrowmotor.net and use the contact button. You would likely want the rebuild kit that includes all the gaskets and o-rings.
Be sure to include the model number off the valve, which should have SP at the beginning.
Jun 21, 2009 | Hayward SAND FILTER, PRO SERIES
NOT FILTERING, NO SUCTION, CHANGE SAND,,,SINCE DAY ONE..WRONG HP?
You are correct. Your lines are extremely small for this system and the pump is to small for this system. You are going to have to do a total upgrade. from the pump to all the lines. I know this is bad news, but it is a common problem for system that where put in more then 10 years ago
Jun 01, 2009 | Hayward SAND FILTER, PRO SERIES
Multi-valves on hayward sand filter mixed up
Key Cover Assy needs new spider gasket. If it is a newer model the gasket is made into the key cover and it will have to be replaced
Apr 27, 2009 | Hayward Pro Series 18" Above Ground Pool...
Hayward SAND FILTER, PRO SERIES Logo
396 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
