Question about E-Machines eMachines Desktop PC
Loud racing noise from the tower e 3052
The tower runs loud and fast almost all the time, very uncomfortable sound, like a car racing its engine
    Problem Solver:
  • 17 Answers
Open up the side of the tower and you will be able to see the fans. You most likely have dust/hair in one of your fans or one of the fans is going bad. You can clean it out with a low pressure air nozzle or dust can.
Posted on May 29, 2009
Driving along makes a very loud noise like motor is racing, but continue driving, noise goes away then starts again???
Please take a look at your Engine's RPMs when this is happening and let us know, as it will help with the diagnosis. If the Engine RPM is stable (not high during the periods of the racing engine sound), then it sounds like your Radiator Fan clutch may be going out. The noise you are hearing is the fan kicking in and blowing a lot of air, which in turn sounds like the engine is racing.
If the RPMs are increasing with the racing engine sound, it could be the transmission/(clutch if manual trans) slipping.
Hope this helps!
Jun 28, 2015 | 1993 Mercedes-Benz 190
Tappets are constantly loud when driving 1993 BMW 318i
How is the oil level in the engine? Have you actually checked that? Also, what kind of oil (and what weight) are you running in the engine, and how many miles are on the car? You may be running oil that is too thin for the amount of wear on the engine parts! oil leaks cause low oil levels!
Apr 18, 2017 | Cars & Trucks
A loud ticking noise?
No I would not chase to the pistons, these vehicle were very comon in creating HLA noise hydraulic lash adjusting valves, meaning the valves pump up with oil as the oil gets thinner they dont pump up as fast and create a very loud ticking noise, I would not express a great concern over simplicity, dodge was famous for this, they really were.
Oct 22, 2009 | 2000 Jeep Grand Cherokee
I have a 2001 Ford ranger supercab that makes rattling noises. It has a 4.0L SOHC. It makes a very fast and loud metallic rattle wich softens anfter about a second or so when I first start it for the day....
4.0l's are notorious for valve rattle on cold start-up. There is really nothing you can do to make it go away short of completely replacing the valve train in the top end, and that isn't a permanent fix. It's is an top end oiling issue from the factory. Just don't race your engine on cold start-up until the rattle stops.
The rattle in the transmission sounds to me to be more of a loose dust shield/heat shield around the transmission or exhaust than a mechanical issue.
Oct 20, 2009 | 2000 Ford Ranger SuperCab
Loud knocking in my engine?????
It sound like you dropped valve seat on the head. Did you recently over heat your engine .
May 12, 2009 | 1998 Plymouth Breeze
Tower fan runs fast without stopping
either your computer is running too hot (clean it out physically, or clean out viruses) OR the fan is failing, and it sounds louder and faster cause the bad fan bearings are making that noise.
Mar 12, 2009 | Computers & Internet
There is a loud noise coming from my engine ..sometimes..
oh ok, you probably have air shocks and that is the compressor running... makes sense that it sounds with the engine off... it should not be a loud sound though, normally it's quite quiet and you only hear a faint noise... if it is that loud it's probably a bad compressor
Jan 13, 2009 | 2003 Lincoln Navigator
LOUD RACE CAR NOISES FROM MY 99 VW BEETLE
This seems to be a classic case of "disentegrating exhaust system syndrome." There is either a hole(s) somewhere in your exhaust system or there is a leak somewhere. Probably the easiest way to tell where the noise is coming from is to start your car and just listen around in the engine bay, under the car, and at the muffler. Also do a visual inspection of the exhaust system to see if you can see any holes in the piping. I have also seen hairline cracks in the exhaust header itself that can cause the loud ticking noise that can be a little tricky to track down.
Jan 11, 2009 | 2000 Volkswagen Beetle
Loud air intake engine noise on startup
I would guess it is the electronic fan clutch. It will cause the fan to run too fast (very loud) and the light will come on sometimes.
Nov 10, 2008 | 2002 GMC Envoy XL
1990 gmc k2500 new 5.7engine & turbo 400 ,power lose & noise.
sounds as if you may be looking in the wrong spot. If different gearing is drastically changing the symptoms you may want to check the trans. or torque converter. sudden pop with engine rpm increase and lack of power sounds like possible band breakage in transmission or impellor breakage in torque converter.
Oct 20, 2008 | 1990 GMC K2500
E-Machines eMachines Desktop PC Logo
244 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
