Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
Exploded view of Berings and washer HELP ME!!! GE WSM2700W
My GE WSM2700W had a bad seal and was leaking froom the bottom of the tub.
I pulled it apart and found the damaged parts bering, tub seal .
So
I bought the parts, it took a while to get them.
I am having a hard time figuring out thr order that the seals go back on.
I need an exploded view of the shaft and seals. The only ones I find are too small to see exactly what goes where!
Anyone know where I can go online to find this info!!
Help! Help! the wife is making me take cloths to the laundrymat
Thanks For the help!
t
  • arielchri767 May 29, 2009
    Hi Js thanks for the help the sears site is much better,
    Anyone know where the felt wasrer that you apply oie too, goes?
  • 5,911 Answers
Go to appliancepartpros.com and type in your complete model number. There are some excellent exploded view diagrams of your entire unit, complete with part numbers. Another source you can try is searspartsdirect.com. I hope this helps you.
Posted on May 29, 2009
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer?
The pump may be going bad...
Jul 29, 2014 | GE WSM2700W Unitized Spacemaker Washer and...
Sudsy water is leaking from the machine
Hello there and thank you for choosing fixya
The tub seal is the most common thing that causes Maytag washers to leak. This is unfortunate because the tub seal is an expensive repair job and not one I would suggest doing yourself. I say this because it is complicated and requires special tools to perform this job. To check if the tub seal is bad, first remove the front panel by removing the two screws from the bottom of the front panel. If you have a newer model, prize the bottom clips with a screwdriver. Then pull the bottom of the panel until the top clips release. Then start the washer and watch for a leak around transmission where it goes through the tub. If it does leak then the tub seal is bad and needs replacing. If you have the tool or willing to buy it click here for instructions on how to replace the tub seal. If the tub seal doesn't, leak you probably found the leak while performing this test.
Mar 07, 2011 | Maytag MAH6700AWW Neptune Front-Load...
The washer is leaking from the bottom
Your center seal is going bad or you have a bad hose, leaking water pump, or a cracked tub but GE is notorious for there center tub seals to going bad I would recommend a qualified service technician come look at it to rule out which one it is if your centers tub seal is bad I would buy a new washer but sorry for the troubles.
Jan 22, 2011 | GE WBSE2090A Top Load Washer
Leaking from the bottom from GE super capacity plus washer maching
Take the front off and if it is leaking from where the transmission meets the tub the tub seal is bad. When this happens you have to replace the seal and the transmissson. This page can help http://appliance-repair-it.com/GE-washer-disassembly.html
Jan 02, 2010 | GE WBSR3140DW Top Load Washer
Leaking water out bottom of front load washer
You will need to remove the lower toe panel directly below the door to gain access to the inside cabinet to see where the leak may be coming from. The panel comes off by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the two front feet of the washer up with something (a 2x4 works well for this) will give you better access to the screws.
The most common source of leakage on this washer is the rubber bellow around the door. It can develop cracks or tears over time and require replacement. A tell-tale sign is the front counterweight (looks like a concrete block on the front of the wash tub) looking wet. The counterweight will remain dry if the tub is sealed properly. From the inside of the washer, pull the rubber folds back on the door bellow and inspect the perimeter for any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If the bellow is intact, check the rear bellow seal where it connects to the front of the wash tub. If the clamp comes loose the bellow can shift and begin to leak. Tighten if necessary.
Check the drain pump and hoses to ensure they are not leaking. The drain pump is directly in the front under the wash tub.
Check the area directly below the wash tub. If the leak is coming from the wash tub iteself, you may have a bad tub seal. A replacement gasket doesn't cost much at all, but the labor involved is extensive.
Check the air dome on the lower right hand side of the wash tub. There should be a small air hose attached that runs all the way to the pressure switch. This small air hose is how the pressure switch senses the pressure differential in the wash tub and determines when to shut the water off. If the air hose comes loose, water will pour out of the air dome into the cabinet bottom. Reattach if necessary.
Another simple problem is the dispenser tube(s) that come through the door bellow. Sometimes, these small tubes will work their way behind the rubber in the door and leak when the washer attempts to fill or rinse. This is a simple matter of adjusting the tubes to ensure they are seated through the door gasket properly.
If you have any questions, or require additional assistance, please let me know. I hope you find this information helpful.
NOTE: You can refer to searspartsdirect.com for some excellent exploded view diagrams of your washer for reference in locating components. If y
Oct 23, 2009 | Kenmore HE2 Plus Front Load Washer
He3t washer leaking corner bottom
You will need to remove the lower kick panel directly below the door to gain access to the inside cabinet to see where the leak may be coming from. The panel comes off by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
Sep 03, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
GE WBXR2060V1WW leak_transmission shaft and tub
The tub seal is leaking, often this damages the transmission. A new tub seal comes with the transmission this page should help http://www.appliance-repair-it.com/GE-washer-disassembly.html
Nov 12, 2008 | GE WDSR2080D Top Load Washer
Water leaking where motor goes into the drum
there is a tub seal under the spin tub that proab needs replacing open the front panel then raise the top then grab the agitator and **** up on it hard it should snap out then unsnap the splash ring around the outer tub take the little bolt out of the agitator drive loosen the nut on the spin tub and remove it keep going down till you get to the tub seal replace it then reassemble
May 22, 2008 | GE WHRE5260E Top Load Washer
Washing machine while in the spin cycle sounds of balance very loud
I had this problem and replaced the tub seal under the agitator which solved the problem.
May 07, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
382 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
