Question about Mitsubishi VS-60601 60" Rear Projection Television
Mitsubishi VS-60601 When I turn it on, the TV just make a click noise. but it does not do anything else. All the eigth fuses are good What could I do to fix that problem? I will apreciate your help. Thank you.
  • 2 more comments
  • badcrash Feb 24, 2008
    this tv was giving to me because she said it didnt work, we got it home plugged it up it took several times pushing the power button it would come on for only a second then turn off we took the back off blew out all the dust, it was bad checked all fuses turned it on and it worked great for 24 hours we left it on straight thru and it turned off you could leave it off for a couple of hours and it would work for 5 or 10 minutes, now it wont come on at all it just clicks on then off please help we live in a rural area and the closet place to take it is around 50 miles and it is heavy to move. thank you
  • stevenstreek Jul 31, 2008
    i have a mitsubishi vs-6026r 72in. i pushed the power button and the tv would click on then off.so i opened it up and listened for the clicking noise. it seemed to come from the center of the tv where the bulbs are placed. i'm guessing it may be a bad bulb. but theres no burning smell and the tubes seem fine. help!
  • Anonymous Sep 29, 2008
    I have a 60" Mitsubishi big screen T.V. and when I turn it on it only makes a clicking noise and shuts back off. Can I fix this problem and could it be the capacitor?
    Thank You
  • Diamond2007 Sep 29, 2008
    I have a Mitsubishi VS-6026R Big Screen Television, when I turn it on it makes a clicking noise then turns back off. how can I fix this problem and could it be the capacitor?
    Thank You
techman
  • 3130 Answers
SOURCE: Mitsubishi VS 60601 picture
You need to change the convergence IC's my friend. If you know how to solder and work on printed circuit boards, this is an easy repair, BUT if you have no experience, play it safe and let a pro do this repair for you. Good Luck
Posted on Aug 11, 2007
Slinteriors
  • 8617 Answers
SOURCE: VS-60601 Mitsubishi Problem...
That model is famous for the CRts leaking onto the chassis which causes all kinds of problems and can cause the main circuit board to short as well as destroy the solder. Try looking at the board for evidence of a pastey substance that would indicate CRT coolant leakage. Let me know what you find.
Posted on May 04, 2008
  • 395 Answers
SOURCE: 1998 Mitsubishi vs-60601 picture is dull and not as vibrant as it should be
the first thing I would do is to clean the lenses of the CRTs they may be coated with dust that will dim the picture. other than that the CRTs may be failing since the phospher of CRTs fade in brightness over time and the only solution is to replace all three CRTs. the CRTs I have discovered are no longer availible.
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi big screen model VS 60601 convergence adjustment
you need new convergence ICs. If you can respond to this same post and verify the model number of your mitsubishi, I wll post the correct ICs that your model needs.
Posted on Aug 17, 2008
SOURCE: Mitsubishi VS-60601 60 in.
I just encountered the same problem. What was your solution?
Posted on Jan 22, 2010
Where is the Convergence IC on my Mitsubishi VS-60601 1997 Serial #104094. You told me what the problem was with my TV and showed me what a Convergence IC looks like, but now that the projector TV is...
Convergence IC will be mounted on a big Aluinuim Heat Sink They are Big Black ICs and will have Parts # on Them example STK392-570 There is 2 of them together.
Mats Electronics has them 1-800-628-1118
Nov 04, 2010 | Mitsubishi VS-60601 60" Rear Projection...
Sep 12, 2008 | Mitsubishi VS-60601 60" Rear Projection...
VS60601 Picture yesterday, none today
That model will usually leak coolant directly onto the vertical output area and that will put the tubes into protective blanking and you will have sound but no picture.
Aug 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Trouble!!
sounds like a loose video cable. Check your connections
Mar 03, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
Jan 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Oct 24, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Aug 11, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Push Power button, green light goes on for a few seconds then nothing....
I would suggest taking a look at the power module if that can be replaced. The Fuse blowing may have only been the beginning of the problem. Any recent issues with under or over voltage in your home?
Jan 20, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Televison & Video Logo
129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
