Question about Samsung HL-R6167W 61" HDTV
Problem with HL-R6167W green vertical lines
I have a SAMSUNG DLP model HLR6167w with a problem. I just changed the light hoping this would fix the problem. the PROBLEM IS No picture at all. I have white and black static on the screen that also has a green viritical lines. I have 5vertical evenly spaced lines. I can put the TV on air-antenna, Satelite, DVD, NindendoWii, and the greenish static follows all components. When I hit "menu"on the TV remote, all menu options are crystal clear. Set-up, channel,sound, etc...all perfect picture...Just a problem with the actua lpicture on all components PLEASE HELP email me at surfw77@hotmail.com if you know how to fix this problem. My menu's freeze and I have the green static.. BUT the picture is perfectly clear when I use my my HDMI input for my dvd player. It's only the cable/TV mode with the problem
  • surfw777 Jul 21, 2009
    The only solution I have found is to unplug the TV and plug it back in 1-5 times to reset it back to the normal settings, then it works fine. Is this bad for the TV?
    I've heard it may make the bulb pop or cause some type of power overload maybe, is that true?
    Is it OK if I just unplug the TV like this before I turn it on to begin with? Is that less risky for making the bulb pop etc. It also fixes it this way if I just unplug it a few times before I start the TV up.
    Problem Solver:
You need to do an aggressive reset on the TV. This solved problem completely for me. You must unplug the TV when it is on. Repeat this several times until the TV is jolted back into the factory default settings. The issue is actually with the programming I believe. The clue was that the display worked 100% perfect in HDMI mode, and the problem only existed in the cable setting, no matter if wires were attached or not.
Again, do an aggressive reset to the TV by unplugging it several times while it is on. It may not register the reset at first because after all, the actual problem is a programming issue and it's having trouble recognizing commands in the first place.
Good luck!!
Posted on May 31, 2009
Green vertical lines,minor. flashing goodback ground pic good sound . i have samsung dlp tv model hl-r4667w
the lines are from the vertical control, theres a minor short on the vertical board if not fixed the power supply will short and whole tv will go green call repair shop and get short fixed
Jun 11, 2010 | Samsung DLP HL-P5663W 56" TV
Green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
May 30, 2009 | Samsung HL-R6167W 61" HDTV
Samsung Model HLR6167W
Does the TV appear to be cycling on and off, like its attempting to boot up? Or, does it just not come on at all? Don't miss the lamp door interlock switch. Many Samsung DLPs have tempermental door switches. Try re-installing the door or manually hold the switch in the closed postion and try to power it up. If the lamp comes on and stays lit, you've found your problem.
michtech
Feb 19, 2009 | Samsung HL-R6167W 61" HDTV
I have a DLP Samsung HL-R6167w and it's not working
I had a bad digital board also. I went to parts.com to order a new part way cheaper than from repair service. the only problem I had was that after installation which is super easy 4 cables to unplug and replug. when I turned on the TV the picture came in upside down, not good. no one would give me the code to flip the screen as it is in a hidden menu, well after months of searching the web I found it!! It works for most all newer Samsung TV's. turn the TV off, hit mute then 182 and then power on button on the remote. the "hidden" menu will pop up and you scrool down to h-flip and flip the screen. I don't recommend messing with any of the other setting as you could likely really jack up the TV but at least you can fix it for a 3rd of the cost you would spend otherwise.
Jun 18, 2008 | Samsung HL-R6167W 61" HDTV
I have a SAMSUNG DLP model HLR6167w with a problem. I just changed the light hoping this would fix the problem. When the problem first occurred, I could barely make out the picture, and it was very green...
Good luck!!
Samsung HL-R6167W 61" HDTV Logo
607 people viewed this question
Jerry Greenberg
Jerry Greenberg
