Question about E-Machines M5105 Notebook
Emachine M5105 that won't boot up.
Have an emachine M5105 that won't boot up. ... would make sense because the cooling fan on the motherboard does come on when I turn it on. ... I got the BSOD and when restarting the laptop, it says it can't find the boot device. There is no CD in the CD-ROM drive. When I press F3 on startup the BIOS startup says there is no Primary drive IDE (the hard drive). Is the hard drive dead?
  • 197 Answers
I suspected the IDE cable is not properly connected to your hard disk. Check connections and boot up machine normally.
Posted on May 29, 2009
EMachines e728 cooling fan turned off, even after a ridiculous amount of screwing i can't get to it. How can i take it apart properly?
Hello
You may visit a computer tech to clean the cooling fan,it needs to be clean to avoid overheating or damaging your motherboard..
Dec 04, 2013 | eMachines E Computers & Internet
Why my e-machine t4010 shuttes off by itself
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Nov 03, 2012 | E-Machines eMachines Desktop PC
Lenovo ThinkPad X61 got "thermal sensing error" when it boot up
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Aug 04, 2012 | IBM Lenovo ThinkPad X61 Notebook
When i push the power button on my emachine the e screen flashes and it wont turn on what do i do to fix this?
If you just did a memory upgrade then the new chip is either not seated properly or the wrong type or even bad. Since it won't boot the problem is the ram in memory slot one. You need to rock it a bit to make sure it is seated before snapping it in. If it is the wrong speed or type you need to exchange it. It can also be bad but that usually means a counterfeit these days or you gave it a static shock and burned it out..
If you put your old ram back in you should be able to work again until you get the ram replaced.
Sep 02, 2011 | E-Machines 128mb memory upgrade for...
I am not hearing the fans on this computer and i notice it heats up very quickly
With the computer turned off unseat and reseat the fan connectors back to the motherboard. If the fans are still not turning on then try some other new fans. If new ones won't turn on then you know for sure at that point the motherboard is going bad because its not putting out a high enough voltage to turn the fans on.
May 21, 2011 | E-Machines eMachines Desktop PC
Cannot shut off & no display
The eMachines M5105 is notorious for failing to boot if left unplugged and powered off long enough for the battery to become mostly discharged. Plugging it in to AC power will cause the battery to start charging; and the hard disk drive to spin while the CPU cooling fan cycles on and off vigorously. THE UNIT WILL NOT BOOT UNTIL THE BATTERY IS NEAR FULLY CHARGED; then THE AC DISCONNECTED; and then THE (charged) BATTERY REMOVED AND RE-INSTALLED! Most units will boot after following the foregoing procedure.
Jun 24, 2009 | E-Machines M5105 Notebook
The laptop is in sleep mode. Take the battery out,then plug in the ac then as soon as you do hit the F3 key and wa la   it wakes beck up..
Best wishes enjoy.........emachines got to love em to play with em  !!
Dec 04, 2008 | E-Machines M5105 Notebook
Emachine doesnt turn on
contact me for support on these computers free of charge at compdoctor2005@btinternet.com
Chris
Jul 14, 2008 | E-Machines (308714) Motherboard
E-Machines M5105 Notebook Logo
319 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
