Question about Amana ABB1927DE Bottom Freezer Refrigerator
Freezer not freezing properly, ice on back wall
Our freezer is keeping the frozen food frozen, but not freezing new food very well, though the food does eventually freeze. There is ice on the back wall. What should I do? Fridge seems fine. It's a Roper.
  • Anonymous Mar 18, 2014
    I replaced thermostat in fridge but this did not solve problem
    Problem Solver:
  • 5 Answers
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
Posted on May 29, 2009
Freezer not freezing but still cold
you might have ice on the coil in the back of the freezer under the cover. move your food to a cooler. eat a lot of frozen food then unplug the freezer and leave the door open for a few days this will melt the ice hopefully with no effort on your part. then plug it back in and wait a few hours to see if it gets cold.
Sep 14, 2014 | Refrigerators
Samsung "Cool-n-cool" fridge freezer defrosting food
Is it "defrosting" the food or unable to keep it frozen? Probably unable to keep frozen. Many possible problems. 1. Defrost element bad and evaporator coil is iced over, or 2. Failed evaporator fan inside freezer, or 3. Low freon causing iced up evaporator coil....Do you see any ice build up on the back wall of freezer? Do you hear the freezer fan running or not? Take a look and get back to me.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Refrigerators
The freezer section of our Danby DFF8200W freezes well. However, periodically the refrigerator section freezes everything in it with the temp control turned as low as it will turn for me. The dial does not...
Make sure you clean the backside of refrigerator at bottom from dust. Make sure you have the recommended clearance from wall. Also make sure the food in freezer and frige have clearance to allow air to circulate around food. Keep playing with your controlls...The dails might be on wrong
Aug 11, 2013 | Danby Refrigerators
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
Frozen freezer water line
Odds are your temperature is too cold in your freezer. If when you moved you just plugged in your freezer without adjusting your temperate for your new location you accidentally froze whatever water was coming into your freezer.
First you will need a cooler for whatever you have in your freezer, unless you have wonderful neighbors who will let you keep your food in their freezer for couple of days.
Take note to see what your freezer thermostat is set to. Turn off your freezer. Take out all the food. Keep the door open. This would be a great time to clean your freezer. Let the freezer thaw out for at least one day. Check the line to make sure there is no ice. Once everything has melted turn your freezer back on. Turn your freezer back on but this time set the thermostat to three or maybe 4 levels below what you had it set to before.
Finding Freezing level:
Fill an ice cube tray or small plastic cup with water. Put it in your freezer and come back in about three hours to see if has begun to freeze. If it has not begun to ice raise your thermostat to make you freezer colder by half or 1 level. Leave the ice tray or cup of water that you originally placed in the freezer but add another one. Come back in three hours to see if the water has frozen or has begun to freeze.
You want to leave the original water because you need to make sure the new water does not freeze solid as fast as the original water. If it does your freezer is too cold again.
Repeat "Finding Freezing level" until the water begins to freeze but does not freeze solid. Once your ice begins to free you can put your food back into the freezer. Wait a couple of hours more to see how much more your cubes freeze. If they are hollow or still watery in the center you should go up another half level and check on it the next day.
Once your cubes freeze solid you should be all set. If you don't get at least one tray of ice per day from your freezer you could go up another half level so your ice freezes faster.
Be careful about making your freezer colder because you might end up with the same problem you started with depending on how sesitive you thermostat is.
May 03, 2012 | Maytag MSD2578VEM (254 cu ft) Side by Side...
Ice on back wall of freezer, food not staying completely frozen
Do you have the complete model number from the tag on the freezer, it should be either on the bottom rail visible with the door open or on the side wall near the front. I am trying to look this up to see if it is an automatic defrost model, if so you may need to do more than just unthaw and adjust
Thanks
Apr 25, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Amana ABB1927DE Bottom Freezer Refrigerator Logo
799 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
