2005 Mercury Mountaineer Logo
c
carolyn elliott Posted on Jan 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Car will crank, but won't start - 2005 Mercury Mountaineer
fordexpert
Level 3:
  • Mercury Master 5,692 Answers
  • Posted on Jan 16, 2014
fordexpert
Mercury Master
Level 3:
Answers
5692
Questions
Helped
1974171
Points
17063
One of the usual problems with Ford products is the Inertia switch. It has a reset button and is made to cut power to your fuel pump in case of a wreck. A bump, jarring motion will falsely trip this switch. Closing a door or cargo lid can occasionally create the right frequency to do just that.
You have a switch that has several locations listed. You can try under the dash to the right of the transmission hump. Another potential location is the Drivers lower rear cargo area, close to the Air-ride switch. A third place is the front kick panel area.
I would advise looking up this part under your Year and Model and get pictures of what you are looking for. Cannot say why many locations are listed. You will see when you read the search results.
2answers
Car won't start
Car won't start Ken, You did not give me much info, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Troubleshooting Car That Won Start
Engine cranks but won start Troubleshooting tips
Engine Won Crank or Start
Diagnostic flowchart for car that won start or stalls Troubleshooting for...
Engine won't run
Cranks but won.t run, Check the attached links,instruction and guides, Good luck
Troubleshooting and Fixing Car that Won Start
No Start Diagnostic Basics EricTheCarGuy
2003 lexus es300 won't start... radio lights and windows work. Tried a jump start, still doesnt work...
Are you saying the engine cranks but won't start, or the engine won't crank ?
If the engine does not crank, you would check for voltage at the starter, the neutral safety switch, and the key switch as well as the ground connections.
2002 saturn sl won't start, turn over but won't start
Done cars have a kill switch if they are low on oil. Check your oil. If the oil is good, it may be the ignition switch.
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
