Question about Jenn-Air JED8430 Electric Cooktop
Control knobs split on jenn-air JEC8430ADS - Jenn-Air JED8430 Electric Cooktop
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    you can purchase new ones at repairclinic.com... great resource for parts with pictures so you can match up to the old ones...
    have your model number handy..
  • steve
    steve May 11, 2010
    Buy new knobs.
    Problem Solver:
  • 4 Answers
Buy new knobs
Posted on Jul 28, 2009
  • 10,865 Answers
You have two choices here. if you wish to repair the knob and you have both parts just get a tube of one minute epoxy at any hardware and "glue" the knob back together.
OR you can order the knobs you need at
http://www.jennair.com/content.jsp?name=local_service_repair
Posted on May 29, 2009
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Electric jenn air cooktop shocking me JED8430BDB
Knob is probably split/damaged and the hi voltage from igniter is running through it , remove knob inspect it and clean or replace it.
Mar 09, 2014 | Jenn-Air Cooktops
How to wire element
check the link it might help. Usually the Red or Blacks are Hot or Line the Tan and yellows are the heat range Lines for the inner and outer coil 03 Wiring Information Parts for Jenn Air JEC8430ADS
Dec 04, 2013 | Maytag MEC5430 Electric Cooktop
I have obtained a replacement element Whirlpool AP5653770 for my Jenn-Air JEC8430ADS cooktop. I have lost the secmatic I made showing the colopr of wires going to each position on the element. I have a...
This is the correct way to wire the right front burner on Jenn-Air JEC8430ADS cooktop. Let's do the red wires first. The red wire that comes from #2 on the switch goes to the common connection for the element that should be labeled 2a. The other red wire goes to either of the "b", hot surface indicator switch contacts and the black to the other. Use 1b or 2b for these connections whichever reaches easiest. The yellow wire goes to the inside loop of the burner and the tan to the outside element.
Dec 04, 2013 | Jenn-Air JED8430 Electric Cooktop
I have a electric Jenn Air cooktop and one of the burners does not work, but if I press down on the knob and hold it it will go on, but I can't release it or it will go off
You need to replace the control, under the knob. It is available at partselect dot com.
PartSelect #: PS2201441 Compare At: $43.46 Your Price: $36.22 You Save: $7.24 Availability: In Stock
Oct 29, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Have Jenn-Air 36" gas cooktop w. 5 burners, black. Mdl JGC8536ADB. Plastic knobs keep splitting, even if we remember to push down before turning. Have replaced two sets and now we're down to two working...
Hi
Thanks for using FixYa. There are a few things to check for. Make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and not a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it.
The switches or the range control knobs may have got wet and are completing the circuit to the spark module thus causing it to continuously click or fire off sparks continuously. Use your hair/blow dryer and blow some hot air around the spark module area.
This is a typical spark module wire diagram--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Why does my jenn gas cook top burners all flicker when turned off
hi im gerbee,i will sujest to clean the area were is the place of ur knob control try to remove the control knob then clean it by using a vaccium coz sometimes the problem is very dirt of the control knob.
Nov 30, 2008 | Cooktops
Jenn-Air Gas Cooktop Model CVGX2423
you will need to contact your certified local service tech.you might have a distributor problem at yor ignitor box.if the problem is not with your ignitors.
Jun 30, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air JED8430 Electric Cooktop Logo
1,255 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
