Question about Whirlpool GD2SHGX Refrigerator
My ge refrigerator leaks water
I have a side by side ge refrigeratoe and water leaks from freezer side.
    Problem Solver:
  • 18 Answers
During defrost cycle, the water produced is suppose to drain away through a small drain hole located behind the racks in the freezer section where you'll need to remove the rear panel to see the drain hole. This hole it very likely clogged.
Be careful to unplug the refrigerator before doing any work on it!
Posted on May 29, 2009
I HAVEA GE SIDE BY SIDE, THE FRIDGE AND THE FREEZER ARE ONLY COLD IN THE BOTTOM HALF, FROST BUILD UP IN THE FREEZER, BOTTOM HALF,
HI you have a bad defrost heater, located in the freezer behind the rear panel at the bottom, the part cost around $50-70.00.
Sean
Mar 28, 2011 | GE Refrigerators
Leak under freezer portion
Check out these tips...they can help you figure out what is going wrong with your refrigerato
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
I have a water leak in the freezer part of my GE refrigerator. It's leaking inside and underneath the refrigerator. what could be the problem
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Dec 12, 2009 | GE Refrigerators
No water or ice
sounds like your door swith is not working. it wont let water or ice flow when door is open (even when door is closed it is not making contact)
Jan 12, 2009 | Refrigerators
Frozen water line
You have to take the bottom shelves out of the refrigerator and then towards the back of the refrigeratoer you will see the water resevour. Tale a hair drier and thaw out the resevoir. then adjust the temperature and make sure that there's good circulation aruound all of the product that ouy have in the refrigerator. Thanks for using FixYa
Dec 26, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Whirlpool GD2SHGX Refrigerator Logo
185 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
