Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Works fine, but every couple of days I will notice that it will not be cooling, as the fan or compressor will not be working. I will turn the temp controler off, then back on and the compressor and fa
Whirlpool gold side by side. Works fine, but every couple of days I will notice that it will not be cooling, as the fan or compressor will not be working. I will turn the temp controler off, then back on and the compressor and fan will begin to work. It will work fine for several days then it will stop working again.
    Problem Solver:
  • 18 Answers
Check the condenser coil to make sure it is free of any dust, which will cause the compressor to overheat. The fan underneath may still be running, but until the compressor cools down it will not start.
If the unit always immediately begins running when you turn the control off and back on, then it may be you have a bad control. Have a servixe tech look at it, as you cannot repair the control...it's a throw away device.
Posted on May 29, 2009
Fan and compressor running but fridge not cooling
Your defrozed cycle seems to be not working. Means there can be problem with heater , timer or defrzed board or defrozed thermostat. You have to open panel from coil to diagnosed this.
Mar 03, 2014 | GE GSH25JFR Side by Side Refrigerator
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
I have a Weather King Heat Pump Outdoor Unit, Model 10PJA3101. I noticed that the a/c was on and working fine inside but the fan was NOT moving on the outdoor unit. There are no tripped breakers or...
If you are cool inside and the fan is not running then you are ok... I would however turn the temps. up a bit to eliminate more stress then necessary...
I am surprised that the fan is not working and you are still cooling though.
Was it a windy day? on a still day it may not work...
Are you sure the compressor was running but the fan not???
Some outdoor units do have switches that will turn off the fan if the head pressures are too low if the air temps. are low...
heatman101
Jul 06, 2011 | Weather King 10AJA2501AH Air Conditioner
Hi. I recently installed 1.5 T, 3 * Split AC, LG. Whole day the AC works fine and no problem in cooling too. But once in 2 day outdoor unit start making thudding noise continously and does not stop for 4...
Hello
Sounds like the compressor is shuting down on high heat.There could be a couple reasons for this.
1 Check that proper voltage is being supplied to compressor.
2 Freon level may be low.This would be a service call.
3 Bad or intermitent connection at thermostat.
4 Main contacts to compressor sticking,usually burnt or pitted.
Apr 08, 2011 | LG Heating & Cooling
About 36 hours ago our Whirlpool 25.2 cu. ft. Side-by-Side Refrigerator ED25CQXFW02 was not cooling (frozen was thawing, and refrigerator was not cold) the compressor and fan were running, I cleaned the...
depending on your model. if its just a reg, side by side, you more than likely need a relay/ overload which is located on the compressor,the relay only works after it cools down. unplug ref from wall, remove rear cover to see and touch compressor to see if it starts when you plug back in to the wall. if it doesnt start in three attempts. replace it. easy way to diagnose..
Jan 17, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
I have a Whirlpool gold conquest side by side model GS5SHAXNL00 that has a clicking noise coming from the rear. The freezer isn't keeping things frozen but the fridge side is nice and cold. I can hear the...
These models have two fans. One is located inside the unit. The fan inside blows air across the cooling coils. With the door open this fan is usually running other than defrost cycle. If this fan has stopped it will cause the compressor to overheat and the relay will cycle.
The second fan equally as important is located under a fiberboard cover accessible from the back of the unit at the bottom. This fan is usually noticeable by an air flow sound. Usually air flow is detectable out of the front grill. If this fan fails to operate, blocked due to a major build up of lint the compressor will overheat and cycle as you hear,
Hope this helps?
This is the fan inside the freezer.
Jun 25, 2017 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
My whirlpool side by side is getting warmer. Freezer was up to 45 F yesterday, today 55 F, Refrigerator getting warmer too. Fan on freezer and refrigerator vents blowing, but isn't that cool. What's...
check and clean the condenser coil under the ref , remove the back to the ref if the compressor is real hot you need to put a fan behind the ref for a couple of hours until the compressor cools down then plug it back in.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire Electrolux side by side fan not working
If teh fan had burnt out then there is every possibility that your contactor, the timer, the compressor must be checked. Replace the fan as you had confirmed and put the set on. If the compressor works and the cooling comes on fine then there is nothing to worry. But if you notice any smell or a different noise then shut off and open the back side to check from the contactor onwards to the compressor. However if the compressor works well then you are lucky . hope you get along to do this. Good day
Jul 31, 2010 | Frigidaire Refrigerators
Whirlpool side by side not cooling or freezing. Have already cleaned the condensor coils with no change. I did notice that the fan in the bottom back is not spinning.
that is most likely the problem. If this fan doesnt cool the condenser and compressor it will shut the compressor down. replace the fan and your problem will most likely be fixed.
Jul 11, 2010 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
172 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
