Question about Mitsubishi VS-60603 60" Rear Projection Television
Lost inputs 1,2 and 3
A recent storm knocked our power out while the tv was on, when the power came back on the tv only had antenna A and B. Inputs 1,2,3 and the DVD input do not appear as options anymore. I have the same exact problem. A storm knocked out my inputs 1 2 3 and i am left with ant a & b. I can only watch tv through the picture and picture
  • Mitsubishi Master
  • 1,869 Answers
Check and, replace the fuses
Posted on May 29, 2009
Panasonic tv hdmi inputs not working
It appears that during the storm there may have been an electrical surge that damaged the electronics of your tv. If the tuner is working fine then the affected area (board) is the one that has the HDMI input sources.
Aug 30, 2015 | Panasonic Viera TC-P58S1 58 in. Plasma...
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
My tv comes on and has "unusable signal" floating on it
What is your signal source, OTA or cable? Did lightning or another type of power surge recently hit? Make sure you have the TV on the desired input.
If OTA check your antenna direction and that you have the Channel Setup (from the menu) set to Antenna. Also check if you have the right antenna to get stations in your area. Antennaweb.org gives the most likely channels and directions. tvfool.com will give more detailed information and more stations. Both sites assume outdoor antennas but the direction information is always good. Look for new construction or big trees that might block the signal. Do you have multiple TVs sharing the same antenna? You might need an amplifier.
If cable, check the Channel setup. Check for someone recently damaging your cable installation (cutting the wires, trying to split the signal to get it for free) Splitting the signal to multiple TVs may also be an issue, get an amplifier of the correct type. Some cable systems may require a bidirectional amplifier.
If you recently had a power surge, see if the TV works with other inputs.
Tuners can be replaced if the TV is worth the labor costs for you.
I hope this helps.
( My household had three tvs and a digital to analog converter that lost their tuners after a nearby lightning strike. We chose to replace the TVs since two were over 15 years old and the third was also out of warranty.)
Apr 13, 2010 | RCA L46WD22 Television
try reseting the tv to manufacture settings in the
menu,or unplug it and try a different outlet,it works sometimes
May 09, 2009 | Mitsubishi VS-60603 60" Rear Projection...
Rca television (f38310)
using your cable box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. If you do not have a cable box you can connect your cable to the antenna A or B input jack on the back of the set and set the tv input to antenna
Mar 23, 2009 | RCA F38310 38" TV
Dish Network HD Monitor HD 40-300
I have a Dish Network HD40-310 Monitor. When you turn power on the green power light comes on, then tv makes funny noise, then goes off again without producing any picture. Any ideas how to fix?
Aug 02, 2008 | RCA Televison & Video
Still won't work
Hi again,
This forum has much info re Mitsubishi PTVs. Nonetheless, an excerpt from there....
1.Set the Layer Switch at the top of the Mitsubishi Remote to TV.
2.Press and hold the POWER button, and while holding the power button enter 090.
3.Now the remote should function like this:
Power = Power On Discreet
Stop = Power Off Discreet
Pause = AV Reset
Pressing INPUT followed by:
PIP = DTV
1 = Input 1
2 = Input 2
3 = Input 3
4 = Input 4
5 = DVD / Component 1
6 = Component 2
SQV = Input STB
QV = Input VGA
PIP CH Up = Antenna A
PIP CH Down = Antenna B
4.When done, press and hold the POWER button and enter code 000 to return to the standard remote functions
Apr 17, 2008 | Televison & Video
Mitsubishi VS-50603, input is gone
happened to me also. Go to the menu, select setting, thrn av (home theater) and see if "locked to input 1" is "on". Mine was. then I set it to "off" and everyting works great
Dec 06, 2007 | Mitsubishi VS-50603 50" Rear Projection...
40H80 Problem TV will not switch to non antenna inputs
Sounds like you have a bad tuner. It is not uncommon for solder joints to deteriorate over a period of time and loose continuity. If you are handy with a soldering iron, you can try to fix it yourself but I really recommend leaving it to a professional.
Dec 06, 2005 | Toshiba 40H80 40" Rear Projection...
Televison & Video Logo
144 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
