Question about LG DLE5977 Stainless Steel Electric Dryer
LG Dryer takes way long to dry
LG DLE6977W model. The dryer works fine with a light load of clothes (weight-wise), but when drying heavier loads, especially towels, it takes FOREVER to dry, I'm talking around 2 hours. The door jiggles a little when shut, maybe that has something to do with it? Also, lint builds up around the rubber door seal, something that I never noticed before. I have cleaned all the lint from the dryer and the vent seems to be clear to the outside. Thanks in advance for any solutions given!!
  • kemsmarino May 29, 2009
    I also just realized that the cooling light is always on, from the time I select a cycle. The vent is clear as far as I can tell, so is the internal ductwork. How would I know if it's the heating element or thermostat? Thanks!
  • Anonymous Mar 20, 2014
    Dryer will continue to dry and seems very hot when I do open it to check. Does not stop on it's own even when clothes are dry. Dryer is vented to outside but lots of lint does seem to accumulate around the door rim. I empty the lint filter after every load.
  • 10,865 Answers
Let's work together to get to the bottom of this problem. begin with these thoughts
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on May 29, 2009
  • Joe Hogan May 29, 2009
    My recommendation is to replace the heating element. THe thermostat problem is rare.
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
How do i do drying only
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry button. • For most even drying , make sure all articles in the clothes load are similar in material and thickness. • Do not overload dryer by stuffing too many articles into drum. Items must be able to tumble freely • If you open door and remove load before dryer has finished its cycle, remember to press the Start/Pause button. • By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less" • Your dryer can handle a load of up to 9 lbs. (4 kg) dry weight of articles. • When drying cycle is completed, [Cd] (Cool Down) is displayed on the Multi display. • Cool Down is set automatically when the drying cycle is complete. • If clothes are not removed promptly when the drying cycle ends, wrinkles can form. • The Cool Down feature periodically tumbles, rearranges and fluffs the load to avoid wrinkles for up to 4 hours. • The message [Cd] will continue to display until the clothes are removed or the Start/Pause button is pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment Thank You Joe
Sep 06, 2011 | LG WM3431 Front Load Washer / Dryer
I think the moisture sensor is bad in my kenmore he4 electric dryer. It works well on timed dry but does not stay on when using the automatic settings. It is still heating fine, it just stops prematurely...
it is a problem with how you are loading the unit. you must use the same type and weight of clothes or the sensor will think the light items are dry and then shut the unit off.
try to do a load of all towels and see what happens on the automatic cycle. if it does well then you just need to sort your clothes better.
the sensor is just 2 metal strips and will never fail.
Mar 13, 2010 | Kenmore Elite HE4 Electric Dryer
We have a lg dryer and it takes very long to dry clothes, I have checked out the vents and still does the the same,please give advise thank you
  1. Separate heavy weight items from light weight items when creating loads. Heavy fabrics take longer to dry because they tend to retain more moisture. To help reduce and maintain more consistent drying times for large and heavy fabrics, separate these items into smaller loads of a consistent size.
  2. Use the appropriate control settings for the type of load you are drying.
  3. Please confirm that the lint filter is clean prior to each new load of laundry.
  4. Divide your larger load into a number of smaller loads.
  5. If you are only drying a handful of items, add a few extra pieces to help ensure proper tumbling action.
  6. Confirm that the exhaust venting ductwork is properly configured. Confirm that the venting is free of obstructions. Confirm that the outside wall dampers are moving freely, that the dampers are not pushed in, and that nothing has been set against the dampers.
Oct 23, 2009 | LG DLG5988 Gas Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Aug 21, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Heavier clothes coming out damp
First, make sure your vent to the outside is clean. Second, on auto cycles, clothes should be consistant. If a smaller item keeps hitting the sensor, it will think the whole load is dry. For mixed loads, used timed dry.
May 02, 2009 | Dryers
LG Stacking Dryer
To make sure it is a vent problem ,Do one load without the vent hose attaching to the wall ,keep in mind that it may blow out some dust, you may want to cover the end of vent hose with a nylon stocking for just this ONE time.Now run this 1 cycle on a timed dry cycle at the highest mark...60, 70,etc.If the clothes are dry at the final stopping point than you know your vent is blocked.Or you pinched the vent hose closed.It only takes a small blockage to create alot of waiting time for dryer to end its cycle.The faster the air can get out of the dryer the faster it dries.
May 21, 2008 | Dryers
LG DLE5977 Stainless Steel Electric Dryer Logo
1,251 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
